VWVortex.com - How To - Installing OEM rings and new rods
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 55
    Thread: How To - Installing OEM rings and new rods
    1. 05-21-2008 12:44 PM #1
      Since most people who are upgrading 1.8t's these days haven't built motors before, I thought I'd throw together some pics of how to install aftermarket rods and new OEM rings on OEM pistons. If you are uncomfortable with anything contained in this post, pay to have professionals do the work, but most people's hesitance to get in there and do the upgrades themselves just stems from a lack of experience, so hopefully these pics will help some of you out.
      First off, this covers installing brand new OEM rings on OEM pistons. I do not file OEM rings, simply install and drop in, but technically you should measure ring gap and adjust accordingly. Secondly, this install covers a freshly honed block. I would NOT reuse OEM rings or install new rings in a block that hasn't been freshly honed. Third, this install does not cover measuring rod bearing tolerances, and this should be done accordingly as well. This is mainly to introduce people to the internals of the 1.8t so you know what you're looking at when you get in there, but in reality this is very general info that applies to all engines. On to the pics.
      Here is the aftermarket rod, a 19mm IE rod in this case.
      Here is the used OEM pistons, 19mm wrist pin version, still attached to the OEM rod. Note the retaining clip inside the bore for the wrist pin.
      This is my tool of choice to remove the wrist pin clip. BE CAREFUL as the wrist pin clip is essentially a spring and will FLY OFF INTO WHO KNOWS WHERE upon removal. I always place the tool in position, then cover the piston with a rag, then apply pressure, so the pin will be trapped in the rag when it shoots out of place.
      Said wrist pin clip removed. DO NOT LOSE.
      Wrist pin clip removed. Scratches on this area of the piston don't really matter, obvoiusly don't go nuts.
      Wrist pin being removed.
      Piston and pin seperated. Marks on the pin here are varnish, the motor that these pieces came from ran on non synthetic oil for its life, which will leave the brown stain of varnish everywhere. Motors that run synthetic don't do this.
      Relube your wrist pin, insert, and prepare for rod install.
      Insert rod.
      A 10mm socket with a tap from a rubber mallet will force in a stubborn pin (tolerances are tight here).
      A little lube preparing for wrist pin clip reinsertion.
      Inserting the wrist pin clip can be tricky. Again, cover the clip with a rag so as not to lose it, use force to "compress" the clip so it'll pop into its groove. Once you get the hang of it, it's really simple to do, but the first one will be a PITA if you've never done this before.
      Clip in its new home.
      Half of the rod and piston assembled.
      This is the OEM oil scraper ring set, three pieces.
      Two flat rings and one "corrugated" ring, the two flat rings will sandwich the third.
      Slide the first ring down over the ring lands (the three grooves around the piston that contain the rings), careful not to scratch the skirts of the piston. The rings have some flexibility but can and will break with too much force, so be careful. Obviously, the ring lands should be cleaned to remove any carbon buildup before installing rings.
      Put the scraper ring into the third groove.
      Insert the lower flat ring.
      And then the upper flat ring
      This is the second compression ring.
      Notice the orientation.
      First compression ring.
      Work the compression rings into place.
      Now, you're ready to rotate your ring gaps so they are 120* apart, and insert the piston rod into the block. As usual, I'm not responsible for any damage you do as a result of this post. I hope this helps out the community and gets more of you to build your motors while saving a little money and learning how to do it yourself. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by Adam@Unitronic.ca at 10:50 AM 5-21-2008
    2. Member NOLA_VDubber's Avatar
      May 23rd, 2007
      New Orleans
      98 M3
      05-21-2008 01:13 PM #2
      Great write up [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      As a recent first-time rod installer, I can say that it is not that difficult as long as you take your time and have the right tools for the job. I def lost my first circlip, though, but they can be had from the dealer for $0.79 a piece. i wish this was around a couple weeks ago
    3. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      05-21-2008 01:19 PM #3
      Quote, originally posted by Adam@Unitronic.ca »
      Move the opening of the clip to the window in the piston.
      Otherwise [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member inivid's Avatar
      Aug 24th, 2003
      OLY, WA, USA
      08' A6 S-Line 4.2 quattro & 09' Tribeca (current), 04' GTI 1.8T (pdx), 85' Mini (germany)
      05-21-2008 01:25 PM #4
      just great! now there's going to be a ishtload of noobs with fully assembled rods and pistons, but no idea how the hell to put it in the motor.
      i keed, i keed. nice job adam.
      Quote Originally Posted by Travy View Post
      error404: Stance not found.
    5. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      05-21-2008 02:17 PM #5
      Keep these DIYs coming!
    6. 05-21-2008 02:20 PM #6
      Quote, originally posted by inivid »
      like me.
      Now someone make a rod bearings + rod cap install!
      but seriously. do it por favor.
    7. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      05-21-2008 05:00 PM #7
      ahhahahhahahahhaha
      nice write up adam.
    8. 05-21-2008 11:20 PM #8
      Wheres part 2? DIY of putting em in
      Always love seein my name on the rods.
      Modified by themachasy at 5:48 AM 5-22-2008
    9. Member AllofurVWRbelong2me's Avatar
      Jul 12th, 2004
      Stony Brook, NY
      2001 VW GTI 1.8T, 2003 Subaru Outback 3.0 H6, 2006 Subaru Impreza WRX STi
      05-21-2008 11:43 PM #9
      Quote, originally posted by themachasy »
      =Ian.
      Speaking of which, am I sensing some "How-To Testosterone"
      Good ish, D-man. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by AllofurVWRbelong2me at 10:44 PM 5-21-2008
      2001 Rave Green GTI-Sold but not forgotten
      2003 Outback VDC 3.0 H6-Traded but not forgotten
      2006 Subaru Impreza WRX STi-Current and loving it!
    10. Member GTI3309's Avatar
      Apr 11th, 2006
      Garage NC
      GTI 20th Anniversary
      05-21-2008 11:55 PM #10
      Nice [IMG]http://*****************.com/smile/emthup.gif[/IMG] I'm tackling this myself in the next few days
      Destiny cannot be changed. But it can be challenged.
    11. Awaiting Email Confirmation PhilW's Avatar
      Jan 3rd, 2006
      05-22-2008 07:33 AM #11
      Add to FAQ?
    12. 05-22-2008 08:32 AM #12
      good effort putting these together guys. wish there were more of these in one place!
      tip: position ring no's 1 and 2 gaps at opposite sides of the piston and do the same with upper and lower scraper rings.
      this will maximise the seal
    13. Member
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      05-22-2008 10:19 AM #13
      Good job adam, wanna install a set for me for free and save me money?
    14. Member Volar's Avatar
      Jan 2nd, 2007
      Philadelphia pa
      To many of them
      05-25-2008 11:05 PM #14
      im having a hard time getting the wrist pin in the 1st rod i did it slid right in and it was all free moving the other one i did didnt move so freely in the rod is this normal?
      Frankenturbo f4, 3" tb exhaust, cai, front mount intercooler, revo stage 2, forge splitter, 034 track density mounts, 14 lbs flywheel stage 1 clutch keep it quick not fast doesn't look cool going fast with a car seat in the back
    15. 05-25-2008 11:22 PM #15
      Quote, originally posted by Volar »
      no. the proper way would be to have the pins, pin-fit to the piston/rod. you can check the clearences with a micrometer, and have a machine shop dust them to offer proper/same clearence across each set. don't force them in as mentioned in this diy. they should always be checked. my machine shop charges me 1 hour labor, to pin-fit and balance them. as for the clearences, well....
    16. 05-25-2008 11:34 PM #16
      What rods and pistons? If you're reusing OEM pistons and pins like I did, then you don't need to have them balanced or clearanced. If you're using new aftermarket pistons, then again, you don't need them balanced or clearanced as they should be close enough out of the box. The only time you'd be balancing or even weighing them would be if balancing the rotating assembly. The pics from the DIY are from the motor I'm currently using, dyno in sig, over 15K on the bottom end, no problems. Hetzen did have a problem with pins fitting a set of Scat rods, and had to have them machined accordingly. That wasn't needed for these IE's or several other sets I've assembled.
    17. Member Volar's Avatar
      Jan 2nd, 2007
      Philadelphia pa
      To many of them
      05-26-2008 12:10 AM #17
      same pistons and ie rods for now this is gonna be my temporary motor till i get a 2.0l built but the 1st rod i grabbed the wrist pin slid right in it was tight but still spun freely then the next 3 didn't fit for some reason i don't know if maybe i got a bad batch or something they all have the same weight and all the hole just doesnt seem to be right with me having to knock the wrist pin in the hole then it being hard to move and even take out and im usuing moly lube to do this not doing it dry
    18. 05-26-2008 01:23 AM #18
      Fitting pins is just part of the game. They are machined extremely tight on purpose, that is easily fixable with a quick hone, loose is a whole other story. I've had to fit pins from virtually every manufacturer.
    19. Member
      Sep 24th, 2003
      Rhode Island
      05-26-2008 01:50 AM #19
      Most pin fitment problems with Scat and IE rods are from the holes in the wrist pin bushing not being deburred and sticking up a bit. They are a bit tricky to smooth out without touching parts of the bushing, but can be done.
      When installing pins that don't want to go into the piston itself, I suggest mildly heating the piston with a propane torch rather than driving it in.
      Nice writeup- how about something on setting the ring gap?
      Performance and replacement parts, engine building www.qedpower.com
      bobqzzi@cox.net
    20. 05-26-2008 11:45 AM #20
      Quote, originally posted by bobqzzi »
      No, I don't file OEM rings, but Issam just did a writeup on filing rings.
      http://forums.vwvortex.com/zerothread?id=3849749
    21. Member Pisko's Avatar
      Jan 14th, 2006
      Norway
      05-26-2008 12:25 PM #21
      may I sugest, for those( like me) who is in the learning fase and want to learn more about installing rods, get a copy of the dvd called
      `BoxWrench Basic Engine Building`.
      They use a v8, but the principle is the same.
      It covers every aspect of rebuilding a engine and its only like 29$. A cheap investment to get it right IMO..
      https://boxwrench.3dcartstores....html
      Great writeup on the rings btw..
    22. 05-26-2008 01:13 PM #22
      If we're using OEM brand new rings on stock pistons, we don't have to worry about ring gap, right? just a quick hone and we're good to go?
      For the bottom end, are you guys replacing the main bearings as well?
    23. 05-26-2008 04:03 PM #23
      i've never had to file fit the rings on an oem bore/piston/ring combo. but, i always check. depending on power, i open them up a bit too.
    24. 05-27-2008 12:12 AM #24
      Yea I had to take mine to a machine shop. I asked who's fault it was, the rods or the pistons and he gave me a wierd look saying you should always machine them when putting rods and pistons together. It was only 50$, so it's kinda why not.
    25. Member DK_GTI_racer's Avatar
      Oct 4th, 2007
      Denmark
      2000 mk4 1.8T - AGU
      06-03-2008 03:56 AM #25
      This is great writeup [IMG]http://*****************.com/smile/emthup.gif[/IMG] , so why hasen´t it been added to DIY thread?
      One thing do, would like to see the last part of this build, putting rods and piston back to place
      APR stage 3+ 393bhp & 466nm at 24psi - baby GT2860rs 0,64
      APR intake manifold, Aquamist 1s, milltek 2,75" with VES cutout, HGP IC - software by RH motorsport of denmark - EBC with remote and 2 boost settings for high low boost run.
      Goapr if you want your fast to be faster then everyone else
      www.goapr.com, www.inaengineering.com, www.qedpower.com, www.jvk-tuning.dk
