I was excited for more boost but not today. I put the steels back on yesterday. Like them better![]()
#141
Did some cruising today with d-bot
... and then changed out the wast gate spring for a more better one. Wont be needing this anymore.
It's not running 100% anymore at WOT and it's not making it all the way up to the new 10 psi, it's gotta be a boost leak - I'll have time to properly take a look at it tomorrow though.
#142
#144
Quote, originally posted by Noobercorn » the last time i fed Punk a Rougue beer (dead guy)... I have that same exact growler.
#145
Has anyone installed one of these yet? I'm at a bit of a loss.
#146
isn't that the tool for cutting MSD wires??
#147
Quote, originally posted by s.l.c. » isn't that the tool for cutting MSD wires?? This is the Gruvenparts.com hood cable clip.
#148
Quote, originally posted by corrado-correr » Has anyone installed one of these yet? I'm at a bit of a loss.
step 1: smooth and polish to a mirror shine!
#149
Quote, originally posted by corrado-correr » Did some cruising today with d-bot
When are you guys going to cruise again? Maybe you guys could help change my ignition switch and I'll help put that hood cable clip on
Greg
Buy my tries: 2 x Cooper ZPT 215-40-17. PM me if interested
#150
Quote, originally posted by 359Bailey1320 » When are you guys going to cruise again? Maybe you guys could help change my ignition switch and I'll help put that hood cable clip on
Dude, hit me up - i'd be happy to lend a hand.
Today I think I found the problem with the the head lights.
I'm just glad non of this decided to catch fire.
Modified by corrado-correr at 6:57 PM 9-9-2008
#152
I'm just glad non of this decided to catch fire.me too
is that masking tape
#153
Quote, originally posted by brilliantyellowg60 » me too
yeah thats scary.
#154
Raven –You slide the billet hood clip onto the hood release bracket, after removing the stamped VW clip. There is no need to remove the whole cable , but you need to remove the VW clip (by cutting it if its not already broken).
Slide the billet hood clip onto the hood bracket where the old clip mounted such that the lower slot (NOT the 1 that the 2 mounting screws go thru) is facing passenger side. You then slide the sheathed hood clip cable thru the billet clip and let end of sheath rest against end of slot. This will hold the sheathed end of cable, while allowing the steel cable itself to slide freely and mate with the hood pull handle.
To attach the billet hood clip to the hood release bracket, tighten down the 2 set screws. They will bite into the steel hood bracket and secure the clip in place. Its not necessary to tighten them down all that far. Just enough so it wont move.
I will put up a DIY on http://www.GruvenParts.com shortly with some detailed pictures. I know it can be confusing laying upside down looking at that hood release bracket. Once you get it in, you will see it literally takes a few minutes.
Thanks again for buying our products, I think you may have motivated me to install turbo on my 92 SLC, although Ive got OBD1 so Im not sure yet what options I have…seems like turbo would be more reliable and more powerful for a track car, and also less expensive than a s/c. Need to do more searching …
Modified by GruvenParts.com at 10:47 AM 9-10-2008
#155
Thanks for the reply. My problem installing the clip was that I didnt think to remove the factory clip... looked at it for a few minutes... the blood rushed to my head and i went - "ugh, i dunno."Turbo track car? Do it Paul!!! I'm still OBD1, but admitadly OBD2 or stand alone is the way to go.
#156
do you ever go to the exceed meet at the chili's on M59 and Adams?
Greg
#157
Quote, originally posted by 359Bailey1320 » do you ever go to the exceed meet at the chili's on M59 and Adams? If i do anything organized its mostly MIVE events and gtgs.
#158
I think they have a thing for VRT's....
#159
I fixed my ignition switch this weekend so if you and dbot get together this week lmk I'd really like to come over and meet you guys![]()
Greg
#162
ya just a bit
Are you swimming yet?
Greg
#163
Planning any work soon?![]()
Greg
#164
found my self screaming out VR6 WHAT!!!!
everytime i saw ur ride at h2o lol
#165
omg those wireswhy do people do things like that, reminds me of my friend, I understand when people don'tt solder and use heat shrink ,but when people twist wires and then tape them WTF, go to local store and buy some wire connecters and crimp the ****.
#166
Quote, originally posted by dworkz » found my self screaming out VR6 WHAT!!!!
everytime i saw ur ride at h2o lolsweet!
Aside from wearing out a set of tires (they were already almost bald) the car made it with out a single issue on the 1500+ mile round trip to H2O.
One more thing, and pretty important. At 8+psi I was reaching a situation where the boost was causeing ignition cut out. The simptoms were hesitation when warm under woot and full boost. This was especially the case at higher rpms. I imagine it like a candle in the wind, only the candle is a small blue spark and the wind is pressurized at 8psi.
Per recommendation from the Mcnoodle
i cut the spark plug gap in half, down to a 0.024". The results are incredible, the car feels stronger than ever. It's the fastest thing i've ever driven and its finally consistently fast, rather than being fast only until it warmed up.
Conclusion: set plug gap to 0.024. Thats all for now.
Modified by corrado-correr at 11:44 AM 10-6-2008
#167
Yesterday I went in to get new tires for the Corrado. I made a special request that they be careful pulling the car in due to the low hanging intercooler, the guy I talked to assured me that they would use floor jacks and not the lift. That didn't happen.The guy ends up pulling into the bay at a good 5-10 mph and then there was a great noise as the scoop of the intercooler smashed into the lift. The welded 1/4" aluminum scoop was torn almost completely off, and 2 of 3 of the steel brackets that hold the intercooler in place are essentially missing. The scoop actually got STUCK in the lift. Luckily the core does not apear to be damaged and with a new scoop and a new bracket or two I should be back on the road.
Discount will pay.
The only saving grace about the whole ordeal was the tech that did the work. Very cool guy.
On to the pics, it was bent back into place a good 6 inches so I could get home. Notice the rippling in the metal - its just crazy the force this guy hit the lift with. If you look closely you can see the red paint from the lift.
One of the brackets, bent and broken.
We had to replace the entire scoop. The metal was cracked and bent beyond repair. "Fabricadabra" Matt said, and PRESTO!
Still need to re-do the brackets.
#168
Looks like you're making headway, still going to be at Chilifest?Shoot me a PM or call me next time you work on your car, I'd like to help!
Greg
#169
Its winter in Michigan, the Corrado is not going to see any more of this white stuff. So its in the garage for some winter shenanigans.
Oh noes DANGER TO THE MANIFOLD!!!!!!12!!
^^ so thats what they look like inside.
Modified by corrado-correr at 2:34 PM 12-5-2008
#173
Checking in for my annual Corrado forum visit.*here*
Let's get some tasty duces this weekend and tear apart the old rocco 1 to welcome the new rocco 1 shall we?
#174
Bear Republic Racer 5 mmm mmm good!and yes they come in 22oz's And as usual, Great work!!!
Modified by jds92slc at 9:13 PM 12-10-2008
#175
Matt's always complaining that nothing ever gets done, well... I got some work done to the manifold. This is really coming together.
Infact its more than just beer, smoke and mirrors - there's even a plan!!! Here's a rough sketch of where a new air to water intercooler core will sit. The remaining section of the intake will effectively become a short runner intake manifold. All of this is aft of the throttle body. So when you're looking at this sketch, the blue bits are the valve cover, the top is where the throttle body goes and the bottom are the runners that curve down into the intake ports of the head. The sections sketched in red will be the custom parts and area where the new intercooler will be.
and some more pictures from tonight:
