VWVortex.com - DIY cam positioning sensor (hall sensor)
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: DIY cam positioning sensor (hall sensor)
    1. 05-31-2008 01:35 PM #1
      A few people have asked me how to do this. So i'll make a short write-up. This is very simple to do. Shouldn't take more than 10minutes. I was throwing a cam positioning sensor fault code, this fixed it.
      1. Remove engine cover, and remove timing belt shield, there are two tabs.
      2. Notice the bolts, i think they are 13mm. Also pull the clip out of the electrical sensor making sure not to drop it.
      3. Remove/replace, install in reverse order.
    2. Member kaipyroami's Avatar
      Feb 21st, 2008
      Moorpark CA
      2001 VW GTI 1.8T
      06-02-2008 05:44 PM #2
      cool
    3. Member ruetzal's Avatar
      Dec 17th, 2007
      Wisco
      '13 WRX, 2009 A3 sold, '03 GTI sold
      06-13-2008 01:47 PM #3
      save just in case.. pulled this code after my timing belt and waterpump were replaced and started with not everything back together, so cleared the code and we will see if it comes back
    4. 06-13-2008 02:16 PM #4
      For the connector, you don't have to remove the clip, you can actually push it in to release and it'll stay attached to the connector. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. 06-13-2008 02:32 PM #5
      that sensor have my initials on it?
      nice write up.
      Modified by mirror at 10:38 AM 6-13-2008
    6. 06-13-2008 05:13 PM #6
      Quote, originally posted by mirror »
      nice write up.
      the one coming out did [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member jettaturbokid30's Avatar
      Nov 30th, 2004
      ABQ, NM
      2008 VW GTI
      06-13-2008 08:29 PM #7
      I'm getting code related to Cam Positioning Sensor. My local shop wants close to 1k to replace both the sensor and hydraulic unit.
      When I asked them to replace the sensor first, they insist that both parts are sold as one from VW ($399 to $450 alone for the two parts) ...is that true?
      I'm dying to give this a shot.
    8. 06-13-2008 09:26 PM #8
      Quote, originally posted by jettaturbokid30 »
      not true, i bought the sensor from mjm autohaus for like 80 or so.
    9. 06-13-2008 10:38 PM #9
      your getting hosed. I know because this is the work I do.
    10. Member jettaturbokid30's Avatar
      Nov 30th, 2004
      ABQ, NM
      2008 VW GTI
      06-13-2008 11:42 PM #10
      Luckly, I have not committed to having my car fixed by them. BTW, how difficult is it to swap out the hydro unit?
    11. 06-14-2008 01:29 AM #11
      depends on who does it. Lets just say it cam be done removing only one cam. Most won't do it that way though. I would say 2.5-3 hrs would be fair shop time on that
    12. 06-14-2008 01:49 AM #12
      I think you may have re-installed the 2 bolts backwards.
    13. Member CamaroSS's Avatar
      Jun 17th, 2009
      Severn, Maryland
      2001 GTI 1.8T, 2001 Camaro SS
      07-28-2009 08:26 PM #13
      Just bought a 01 gti 1.8t. It has a light on and the code is for the cam sensor. Is this the same procedure for replacing it? How would i reset the light in the dash?
    14. 07-28-2009 08:30 PM #14
      Quote, originally posted by Rippinralf »
      Yeah, the 2 bolts are 10mm, and the single bolt holding the actual wheel on the camshaft is a single 13mm bolt.
      I'm sure whoever is doing the install can figure that out though.
    15. Member CamaroSS's Avatar
      Jun 17th, 2009
      Severn, Maryland
      07-28-2009 08:33 PM #15
      Ill be doing the install. Im just asking because the vw dealer said it would take 2 to 3 hours to replace at 100 bucks an hour plus 170 for the sensor. if all it takes is 20 min of my time i see no reason to pay a vw dealer to bend me over and have their way. how do i reset the light?
    16. Member CamaroSS's Avatar
      Jun 17th, 2009
      Severn, Maryland
      07-29-2009 01:11 PM #16
    17. 07-29-2009 01:51 PM #17
      Quote, originally posted by CamaroSS »
      vag-com
    18. Member CamaroSS's Avatar
      Jun 17th, 2009
      Severn, Maryland
      07-29-2009 07:27 PM #18
      if i dont have vag-com. how can i reset it?
    19. Member alleghenyman's Avatar
      Nov 20th, 2003
      Pittsburgh
      2003 Wolfsburg, 2008 Fit Sport, 2010 Kizashi S, 2012 500 Sport, 2000 4Runner, 2015 CX5, 1975 MGB
      09-22-2009 12:18 AM #19
      You can reset it if you take it to autozone and scan the code - they will let you use the code scanner for free.
      Quote Originally Posted by BetterByDesign View Post
      The dark side of Japan is really appearing through Lexus designs if we can call it that.
    20. Member Ltownhockey17's Avatar
      Apr 27th, 2007
      Concord, NH
      2001 TT 225, 2005 Kawasaki Z1000
      09-24-2009 02:35 PM #20
      watching. im also throwing a code for a cam postiion sensor
    21. Junior Member Aldeezy's Avatar
      Mar 23rd, 2011
      Miamiii
      '02 GTI 1.8T
      05-16-2011 12:45 AM #21
      same code comes up for me; i've been looking for this FOR A WHILE! had no idea it was right there lmao thanks man, idk what i'd do w/o everyones write ups and VWVORTEX!!!
    22. Member G-Shock's Avatar
      Jun 14th, 2002
      Chandler, Arizona
      2002 Relex Silver 1.8T VW GTI
      12-06-2011 12:01 AM #22
      Thanks for the write up finally going to get that code fixed.
    23. 12-16-2011 11:48 PM #23
      My engine doesn't look like the one pictured above, I have an 01 GTI Vr6. Yesterday I put octane boost in the tank for the first time, and today the engine made a different sound, and threw a code for camshaft position sensor. I'm wondering, a) are the two related? and b) where is the sensor??? I've heard that it is near the timing belt (left side of engine) and I've heard its on the distributor side (right side of engine.)
      Any help would be much appreciated.
      Jen
    24. Member 20vnick's Avatar
      Mar 28th, 2011
      Kitchener, Ontario
      Jetta 1.8T, Honda s2000
      03-10-2012 06:26 PM #24
      take offf the ground!!!!
    25. 10-15-2012 10:34 PM #25
      I recently bought a 2003 Gti. The previous owner had the camshaft position sensor as well as the timing belt and some other work done totaling over 3k. However it is still throwing this code for camshaft position sensor.
      I took it to Pep Boys and they cleared the code only to have it return about 25 driving miles later.
      Any thoughts?
