Looks like the start of a great project! Have you checked out ATP's manifold? It looks like they have an external wastegate option.![]()
#1
garrett t3 turbo, .42 cold, .48 hot side. I only want 10-15 psi of boost and a moderate 180-200 hp out of it.
I will be buying 42lb injectors, tial 38mm wastegate, tial 50mm BOV, ebay intercooler, and I'm still looking for a manifold. obviously the downpipe and the charge pipes will be done at my friend's shop.Other than kinetic's manifold, are there any others that have the flange for an external wastegate? preferably cheaper?
Modified by broko at 4:50 PM 5-3-2009
#2
#3
zornig makes a real nice log manifold for not much money, look him up at racecraft fabrication![]()
also, i think that turbo is pretty darn small...but not bad for the price i suppose. since youll have a t3 flange on your manifold you can always upgrade later...
#4
Quote, originally posted by ValveCoverGasket » zornig makes a real nice log manifold for not much money, look him up at racecraft fabrication ![]()
well, its only an 8v
and I couldn't find a log manifold for 8v applications listed. I'll send him an email though.
#5
i think hell pretty much make you whatever you want...
sometimes he takes a couple days to respond too, so dont get discouraged![]()
#6
well, money has been short and will be for the next few months. I will be getting my stuff slowly but will allow me to make things right.I got my ebay intercooler a week ago and since my car pulls to the side when I press the throttle (ball joint) I decided to start on the intercooler mounting. since the car is going to be sitting for at least a week.
heres a pic of the ebay intercooler
So I already have turbo and intercooler.
next thing on the list is 440 injectors and oil supply.
i'll update as soon as I finish the intercooler mounting.
Modified by broko at 7:59 PM 7-8-2008
#9
I have a SRI for sale if your interested?
#10
you wont make close to 200whp with that turbo on anything less than 15+ psi
NWG Vw repair/parts/service Bradenton,Fl
PGprecisionCNC,welding,and we like prototyping
NWG941.com for more info
my Koupeborgwarner is in..video
#11
nobody said anything about whp. turbo might not be very efficient but it will make a difference
Quote, originally posted by Daskoupe » you wont make close to 200whp with that turbo on anything less than 15+ psi not at the moment. thanks
Quote, originally posted by demonmk2 » I have a SRI for sale if your interested? ![]()
#13
few pics of some goodies. not what I originally wanted. but again, money is short.forge DV
turbonetics evolution WG
bosch 42 injectors.
#14
well, heres a few more pics of random stuff i've gotten. I finally finished gathering all the bits and pieces to finish this project.
Right now I'm rebuilding my coupe's engine so it will be about another week till I can start putting everything together.downpipe goodies
oil return
and
#15
Cool. ID like to see some dyno #'s when you finish up man![]()
#16
Where are you going to weld that external wastegate flange? I am looking to convert mine to external.
#17
Quote, originally posted by PhunkFX » Where are you going to weld that external wastegate flange? I am looking to convert mine to external. top mounted.
#23
Quote, originally posted by broko » top mounted.
That will fit? Weld around the outside?
#24
I love aba turbos. I wish for an abaT on 8-10psi as a daily.maybe one day
#25
you gotta put the turbo on it first and see where your exhaust and intake piping will be that way you know where to put the wastegate. you don't want to get it done and find out its going to be in the way.
#26
Quote, originally posted by Flipdriver80 » you gotta put the turbo on it first and see where your exhaust and intake piping will be that way you know where to put the wastegate. you don't want to get it done and find out its going to be in the way. Truth, this man speaks it.
#27
Yea def a good idea, so I should probably buy a flange and a wastegate. I already have this setup in my mk2 except with a g60 block and mk2 head. Mine has a T3 Super 60 with an internal wastegate on the side and I hate it. I need something better.Thanks!
#30
that turbo is a bit small but it will work, i have an aba turbo and my god does it go at 16 psi it spins the tires in 3rd with a dif! build looks good!
#32
Quote, originally posted by Flipdriver80 » you gotta put the turbo on it first and see where your exhaust and intake piping will be that way you know where to put the wastegate. you don't want to get it done and find out its going to be in the way. already did that. hehe, I've been thinkering with this project for about a year now. finally everything is coming together.
pic of my ugly welds,
wastegate dumptube
downpipe (no, it wont rub
and my dv
I'll take out the oil pan tomorrow to weld the return flange. More to come !!
#35
Intercooled, 440's, good turbo, c2 programming?... you should be able to run 20lbs of boost.
-Andrew
