Results 1 to 15 of 15
Thread: exhaust heat shield rattle: is there a way to fix this?
  1. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    06-09-2008 01:52 PM #1
    ive noticed that potentially my heat shield or whatever guard that is 1 step toward the front of the car from where the inlet pipe connects to the exhaust system may be the reason for my rattle at 2k and 3k rpms. i think its a heat shield but im not sure. the thing is it seems properly mounted, nothing is cracked/broken/or loose. but when i do try and wiggle it it does make a slight creeking noise that sounds similar to the rattle i get. so i could forsee this as being my issue.
    but, is there anyway to fix this rattle w/out just taking off the part? i figure its there for a reason and it looks like its held on in 2 places. but theyre not nuts they almost look like spot welds or something. 1 on each side. any ideas on what to do?
    something to get you all in here:
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  2. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    06-09-2008 05:34 PM #2
    bumpage
  3. Member BoostdIndigo's Avatar
    Sep 26th, 2007
    atl
    06-09-2008 05:43 PM #3
    Hmmm. Some of the 2.0's that come into the shop with a rattle have the oil pan shield on them and they come loose or get broken and they sometimes rattle. Do you have any pics for reference on the heatshield?
  4. Member 03_uni-B's Avatar
    Sep 6th, 2005
    Lexington, Louisville, Bowling Green, KY
    bagged 03 24v, 65 Mustang Fastback
    06-09-2008 05:47 PM #4
    i have the same thing foinf on. its getting really annoying!
    1965 Mustang Fastback build
    BUY MY BBS'S
    Quote Originally Posted by Will@BagRiders View Post
    I really comes down to personal preference. Some like it fast, some like it slow.
  5. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    06-09-2008 11:43 PM #5
    Quote, originally posted by BoostdIndigo »
    an oil pan heat shield? ill have to check that out. if i jack up the front end nice and high is it easily accesible?
    the one im talking about is mounted to "can" object so to speak thats mounted right before the stock sleeve that the inlet pipe mounts into. is that my catalytic converter?
  6. Member TheRedMouse's Avatar
    Jan 21st, 2006
    L O A, IL.
    4-Motion mk4, and a mk2 GLI
    06-10-2008 12:02 AM #6
    the center exhaust hanger?
    you can have that re-welded.
    but a better fix is getting a 2.5-3" screw clamp, slide over and tighten down.
    I <3 C.O.R.T.
    LOA Member: #16
  7. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    06-10-2008 12:06 AM #7
    Quote, originally posted by TheRedMouse »
    its not the hanger. what im trying to describe is before that even. ill have to get a pic tomorrow. but anyway, ive had my gf get the rattle to sound in neutral when i was laying beside the car and its definitely coming for further up the car than that. ill have to check out that oil pan shield, never looked @ that yet. i just dont get why itd only sound at 2k and 3k rpms. unless its my catalytic converter...
  8. Member TheRedMouse's Avatar
    Jan 21st, 2006
    L O A, IL.
    06-10-2008 12:21 AM #8
    just something else to check when your down there...
    take a rubber malet or dead blow hammer and tap on the cat converter, sometimes the insides will get blown apart and rattle around.
    I <3 C.O.R.T.
    LOA Member: #16
  9. 06-10-2008 02:14 AM #9
    when i had that issue, my mechanic did it for free, really only took like 5 min. piece of cake. Just bring it to any mechanic, it is a common, easy fix.
  10. Member
    Sep 7th, 2007
    Southern MD
    92 gti 8v, 04 bmw 530i
    06-10-2008 03:46 AM #10
    when i lowered my car....my heat shield stopped rattling, i dont get it, but it works for me lol. maybe if you lower your car more your will stop
  11. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    06-10-2008 06:27 AM #11
    Quote, originally posted by minionkid256 »
    not a bad idea but im already pretty much as low as i want to be for my daily driver. maybe i can stop by my mech on fri and see if he'll at least offer to find the problem for me if i look under a bit more throughout the week and still cant come across the culprit.
  12. 10-27-2009 02:52 PM #12
    I had the same problem on my jetta, it was the oil pan heat shield clips, they break apparently. It was 5 bucks for the part, just get it done on your next oil change.
  13. Member dremhmrk2's Avatar
    Sep 19th, 2003
    Fort Lauderdale FL
    2001 Mojave GTI GLX
    10-27-2009 02:58 PM #13
    The heat shield above the cat can come loose, they are held on by these threaded posts, the washer that pushes onto the post can become corroded and wont hold on anymore, a zip tie around the post fixes it.
    "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
    All the custom, none of the cool.
    "Trying to be the cool kid is so cool." - MkIV Scene
  14. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    10-29-2009 02:14 PM #14
    Quote, originally posted by norman18 »
    turns out this was my exact problem too, 1 of the clips/pins and its rubber grommet went bad. soooo happy to have it gone, cant believe i put up with it as long as i did.
  15. 12-11-2009 03:51 PM #15
    I have a 2010 Jetta Wolfsburg which is 2 months old, and has less than 2000 miles. My car is in the shop as I type this post. The tech at VW told me they couldn't hear a rattle between 2k and 3k rpm, however heard the noise of the resonator. I guess that makes sense but never thought about it, and to be honest, it's a poor design. I traded my G35 couple which had an exhaust note of angles to a tech on the other end of the phone saying, "that's what it's suppose to sound like."
