VWVortex.com - 001152 - Coolant Fan Control please help
    Results 1 to 14 of 14
    Thread: 001152 - Coolant Fan Control please help
    1. 06-09-2008 08:08 PM #1
      Was hoping you guys could help me out...
      My wife got the Exhaust System malfunction indicator on so I scanned and got the following:
      2 Faults Found:
      006481 - Radiator Fan 2 (V177): Movement Restricted / Jammed
      P1951 - 002 - Lower Limit Exceeded - Intermittent
      Freeze Frame:
      Fault Status: 00100010
      Fault Priority: 0
      Fault Frequency: 5
      Mileage: 96010 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 08:43:58
      Freeze Frame:
      RPM: 701 /min
      Load: 32.1 %
      Speed: 0.0 km/h
      Temperature: 75.0°C
      Temperature: 36.0°C
      Absolute Pres.: 980.0 mbar
      Voltage: 13.843 V
      001152 - Coolant Fan Control Circuit 1: Electrical Malfunction
      P0480 - 004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 0
      Fault Frequency: 3
      Mileage: 96032 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 05:44:40
      Freeze Frame:
      RPM: 746 /min
      Load: 26.7 %
      Speed: 22.0 km/h
      Temperature: 91.0°C
      Temperature: 49.0°C
      Absolute Pres.: 990.0 mbar
      Voltage: 13.716 V
      Readiness: 0000 0000
      Please help ..
      Joe
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      06-09-2008 08:34 PM #2
      Sadly you didn't give us the engine details (part numbers, software versions etc.) so we need to guess now... 2.0T? 2.5l? Checked all fuses already (especially those in the engine compartment)?
    3. 06-09-2008 09:34 PM #3
      Fuses looked good in both areas and my details are as follows
      Thanks for the reply
      Monday,09,June,2008,18:39:16:14302
      VCDS Version: Release 805.0
      Data version: 20080529
      Chassis Type: 1K0
      Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
      Mileage: 96170km/59757miles
      00-Steering Angle Sensor -- Status: OK 0000
      01-Engine -- Status: Malfunction 0010
      02-Auto Trans -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door,Rear Left -- Status: Malfunction 0010
      Address 01: Engine Labels: 06A-906-032-BGP.lbl
      Part No SW: 07K 906 032 AN HW: Hardware No
      Component: 2.5l R5/4V G 6738
      Revision: -------- Serial number: VWZ7Z0E2926662
      Coding: 0000003
      Shop #: WSC 00066 000 00000
    4. Member
      Feb 11th, 2004
      Magdeburg, Germany
      06-10-2008 01:28 PM #4
      Updated our WIKI... still suggest checking the fuse(s)...
      http://wiki.ross-tech.com/inde...01152
      http://wiki.ross-tech.com/inde...06481
    5. 06-10-2008 06:54 PM #5
      Thanks Theresias
      The problem went away and then came back today late. It has happened before when I first got it in 06. They said they replaced the coolant fan...It only has happened in extreme heat 90 degrees +
      I should have bought the manual months ago,
      thanks again
      joe
    6. 06-10-2008 07:28 PM #6
      Sebastian
      I have tried to purchase the Bentley through the VAG site but it is charging me an extra 20 dollars because of reg..I know I reg. and was hoping you could help out ..
      thanks
      joe
    7. 07-05-2008 11:23 AM #7
      Hello Sebastian
      http://forums.vwvortex.com/zerothread?id=3879344
      I posted a few weeks ago on the following and was hoping you could help me out…
      V177 is movable by hand.
      I checked both fuses per your post and both SA3 and SB24 are ok per meter and obviously so because when the output test is performed from VAG the FAN V7 does come on at some pretty high RPM’s…However, V177 (smaller one) DOES NOT get activated…I do not know what exactly is coded in the OUTPUT test for the fans with the VAG, are you telling the J293 Control Module to turn on V177 also?
      Sebastian any help would be greatly appreciated..The Bentley does not go into great detail on this…Also during normal driving conditions the larger fan V7 does come on…
      And this also happened to me when I first got the car in 06..on a trip to SC…dealer down there told me they replaced a defective fan…??
      Thank you
      Joe Orapello
      Coding: 0000003
      2 Faults Found:
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 13
      Mileage: 96176 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 20:04:33
      Freeze Frame:
      RPM: 686 /min
      Load: 31.8 %
      Speed: 0.0 km/h
      Temperature: 79.0°C
      Temperature: 37.0°C
      Voltage: 13.843 V
      Freeze Frame:
      Fault Priority: 0
      Fault Frequency: 6
      Mileage: 96304 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 06:16:38
      Freeze Frame:
      RPM: 1508 /min
      Load: 51.0 %
      Speed: 53.0 km/h
      Temperature: 93.0°C
      Temperature: 45.0°C
      Voltage: 13.970 V
    8. 07-05-2008 05:11 PM #8
      Being as the small fan does not activate via final control, disconnect the harness to the smaller fan and check the resistance you will probably find this to be "open circuit".
      The radiator control module J293 is built into the big fan control pack and activates both V7 and V177.
      Modified by Piconet at 1:14 PM 7-5-2008
    9. 07-05-2008 09:57 PM #9
      Thanks
      Wish I could find that connector with out taking the dual fan unit out...So what you are thinking is that the coil on the small fan motor is open or defective...I will give it a shot..If that is the case it will be(2) V177 fans that have gone bad...
      Joe
    10. 08-02-2008 01:37 PM #10
      Took out the (2) fan assembly and ohmed out V177 (smaller fan) and got a floating resistance above 2Kohms..Can't imagine it should be any more than 5 or 10 ohms when working correctly.
      Does anyone have this unit out and could you possibly give me a reading on it?
      Output test turns the bigger V7 on but thats about it.
      My concern is that the larger fan V7 has the controller in it that turns on V177. So I am not sure what resistance I should be seeing at the V177 connector.
      Is there a measuring block test I can go to?
      Thanks
      joe
      2 Faults Found:
      P1951 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
      Freeze Frame:
      Fault Status: 10100010
      Fault Priority: 0
      Fault Frequency: 56
      Mileage: 96176 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 20:04:33
      Freeze Frame:
      RPM: 686 /min
      Load: 31.8 %
      Speed: 0.0 km/h
      Temperature: 79.0°C
      Temperature: 37.0°C
      Voltage: 13.843 V
      P0480 - 004 - No Signal/Communication - Intermittent - MIL ON
      Freeze Frame:
      Fault Status: 10100100
      Fault Priority: 0
      Fault Frequency: 20
      Mileage: 96304 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 06:16:38
      Freeze Frame:
      RPM: 2639 /min
      Load: 90.6 %
      Speed: 56.0 km/h
      Temperature: 90.0°C
      Temperature: 50.0°C
      Voltage: 13.843 V
    11. Member
      Feb 11th, 2004
      Magdeburg, Germany
      08-03-2008 02:02 PM #11
      There's a repair kit available for the coolant fans, this is most likely what you need...
    12. 08-03-2008 04:57 PM #12
      Sebastian
      Can you give me more details?
      please help the old man out...
      lol
      joe
    13. 08-04-2008 03:27 PM #13
      I was told that you have to replace both fans by more that one dealer. (??) I went with both because if they did change manufacturers like they said, then the input impedance of V177 was more than likely to be different, being it is drawing current from V7.
      I just figured it was the best bet to change both with the info i had.
      These fans have been superceded many times over. So, the versions that I bought today are the 3rd version available.
      As you can imagine these fans are a common failure item so beware.
      thanks
      joe
    14. Member Bman005's Avatar
      Jun 7th, 2007
      717 PA
      2010 Tiguan, 2006 GTI
      08-05-2008 09:41 PM #14
      Quote, originally posted by orp »
      thanks
      joe
      Oh yes they are, I've seen a couple a week come through the shop
