Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 113
Thread: *** 2.8 / 3.2 Valve Springs & Head stud Kits ***
  1. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    06-13-2008 01:43 AM #1
    Quote, originally posted by 24V ARP Head stud kit »
    High rate dual valve spring set for the 24v VR6, includes spring seats and Ti retainers which allow for higher lift than stock retainers, at half the weight.
    Specs:
    * 13.90mm max lift
    * Coil bind at 17mm
    * Rate 12.6lbs/mm
    PRICE FOR SPRING SET = $745US Shipped
    Quote, originally posted by High-Flow Valve Set, 24V VR6 & R32 »
    PRICE FOR VALVE SET = $775US Shipped
    Finally, an affordable head stud set for the 24v VR6, we build this set using ARP hardware, this is not an "off the shelf" ARP kit.
    Recommended for boosted applications or high revving NA to achieve superior head gasket sealing.
    PRICE FOR ARP STUDS = $265US Shipped
    Please send me a PM when you are ready to order.
    Thanks
    Modified by INA at 9:34 PM 12-11-2008
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  2. Member One Gray GLI's Avatar
    Apr 2nd, 2007
    Long Island, NY
    05' PSM STI, 03' 24VT GLI
    06-13-2008 06:01 AM #2
    cool, won't have to use raceware studs.
    I'll be PMing you very shortly I hope.
    The internet is serious business.
    Apr 23rd, 2006
    '11 STi
    06-14-2008 12:54 PM #3
    the ARP bolts aren't long enough to accommodate a s/s spacer...correct...???
  4. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    06-14-2008 01:02 PM #4
    Quote, originally posted by dubdoor »
    They are?I cant imagine your spacer being more than 3mm thick
    Email | Facebook
  5. 06-14-2008 03:39 PM #5
    some of the spacers are 8.5mm thick, specifically the hgp one that lowers compression to 7.5:1
  6. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    06-14-2008 03:41 PM #6
    Quote, originally posted by kurty85 »
    Thats pretty crazy
    Email | Facebook
  7. Member BakBer's Avatar
    Apr 19th, 2007
    Shreveport, LA
    2003 VW Jetta GLI, 1984 Ford F150, 2002 Suzuki DRZ400E
    06-14-2008 05:21 PM #7
    What are you basing this off of. If you screw the studs down as far as you can they aren't even long enough to bolt it down w/o a spacer. When I helping SLEEPYDUB put his hg spacer in we called Raceware b/c the we didn't think the studs were long enough. They then told us we were doing it wrong. You are only suppose to screw the studs into the head to give yourself enough thread to tighten the nuts on. Do not crank then all the way down into the head.
    The Elite 24v VR6 Club: Member #173
    INAEngineering.com
    Apr 23rd, 2006
    '11 STi
    06-15-2008 11:38 PM #8
    Quote, originally posted by BakBer »
    email correspondence with B. Schimmel...he claims they are too short...i posted here for confirmation...now it seems there is conficting info...
  9. Member BakBer's Avatar
    Apr 19th, 2007
    Shreveport, LA
    06-15-2008 11:50 PM #9
    I talked with Arnold at Pagparts and and rep for Raceware. They both said to not screw them down into the head all the way. Meik used the Raceware studs on his first build and so did Jacob.
    INAEngineering.com
  10. Member One Gray GLI's Avatar
    Apr 2nd, 2007
    Long Island, NY
    06-16-2008 12:10 AM #10
    watching.
  11. 07-01-2008 10:18 AM #11
    has anyone tried this arp bolt set..are the bolts the right length..?can i screw the bolts the hole way down,and it still works in the top..?arp works perfekt in my 12v.i don´t understand why it is a problem on the 24v..
    Modified by VR6-GT42RS at 7:29 AM 7-1-2008
    R36T AWD 1100HP
    www.ktech.dk
  12. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    07-01-2008 02:07 PM #12
    Quote, originally posted by VR6-GT42RS »
    We have sold a couple of sets and they work fine.The 12V's are too short to work in the 24V block.
    Email | Facebook
  13. 07-01-2008 03:35 PM #13
    i did not say that 12v bolts fit in 24v i know that it is not the same..i have both engines...i said that the arp bolts fit perfekt in my vr6 12v...and that is why i did not understand why arp has probs with the length to the 24v..i want arp bolts in my 24v too..but i want be sure that i fits perfekt before i order..anyone here in th 2,8 24v forum who has these bolts..?
    Modified by VR6-GT42RS at 12:40 PM 7-1-2008
    R36T AWD 1100HP
    www.ktech.dk
  14. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    07-01-2008 03:54 PM #14
    Well ARP does not list a set for the 24V.These were custom ordered by us for you.
    Email | Facebook
  15. 07-15-2008 11:36 PM #15
    I hate to be the bearer of bad news, but when I purchased my ARP studs from schimmel, they were too short. He also pieced these together as ARP does not make a kit. However, he replaced the short studs with ones from the 12v and they worked perfect. I have this set up, used it, and can get a measure of the stud I am using for anyone's reassurances if need be.
  16. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    08-03-2008 01:34 AM #16
    Email | Facebook
  17. Member Rodrigo18's Avatar
    May 20th, 2007
    NOVA AREA
    MK4 24 GLI/ ON BAGS
    08-17-2008 10:24 PM #17
    IM me with more info...
  18. 09-05-2008 01:44 PM #18
    Just wanted to give everyone an actual opinion on these studs. The Racewares are too short with a standard head spacer, meaning you have to back them out in order to get the nut on fully. After a Raceware stripped on the initial 20 ft-lbs torquing procedure, I called Issam to get a set of ARP's.
    The ARP's are longer than the Racewares, and have more than enough length to accomodate a spacer with the stud bottomed out in the block. Also, the ARP's have a hex key in the top, so that if you had to adjust the length, you could do so without having to remove the head. ARP's also include their moly lube, unlike the Racewares which suggest using motor oil. Personally, I would never think about using the Racewares again now that there is an ARP option availible.
    Thanks Issam!
  19. Member One Gray GLI's Avatar
    Apr 2nd, 2007
    Long Island, NY
    09-05-2008 07:06 PM #19
    Quote, originally posted by dmonitto »
    Thanks Issam!
    to that.
  20. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    09-05-2008 07:15 PM #20
    Thanks Issam!
    Thanks for the Review Joe!
    Email | Facebook
  21. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    09-05-2008 08:42 PM #21
    FWIW My car has raceware studs and a C2 headspacer and it's been that way for ~2 years now -- no leaks.
    -James
    04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
    >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
  22. 09-12-2008 10:46 AM #22
    Quote, originally posted by PhReE »
    Many people have luck with Racewares, but personally the ARPs are just a much nicer option.
  23. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    09-26-2008 06:21 PM #23
    Valve springs are now ready to go. 500+whp @ 17psi
    Email | Facebook
  24. 09-26-2008 08:31 PM #24
    monday I may pick these up! bump.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  25. Member One Gray GLI's Avatar
    Apr 2nd, 2007
    Long Island, NY
    09-26-2008 08:43 PM #25
    Quote, originally posted by fourthchirpin »
    id use em over the racewares..they're alot easier to adjust into the block, they have the allen key ontop.
    ask joey and vinny, they'll tell you fourth.
  26. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    09-26-2008 08:57 PM #26
    Want to pick up the Grenadines while you are @ it?
    Email | Facebook
  27. 09-27-2008 04:00 AM #27
    I wanted to chime and verify that you do have to back the raceware studs out, that is an accurate statement
    bump for Isaam, one of the biggest contributors to vortex, hands down
    Isaam - lmk if you gonna take me up on my offer that I left on your vm today
  28. Member .SLEEPYDUB.'s Avatar
    Jul 28th, 2005
    Shreveport, Louisiana
    2003 GLI, 2005 GLI, 2JZ Swapped E30, FC RX7
    09-27-2008 05:09 AM #28
    this stuff looks legit
    good **** Issam, i cant wait to see what this stuff will do for a 24v head
    What else do you suggest with this? Cams?
    Im sure you can provide cams with this setup and have the ultimate 24v head huh?
    The Elite 24v VR6 Club: Founder
    Want to be a horsepower baller? Buy my car
    http://forums.vwvortex.com/showthrea...whp-street-car
  29. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    09-27-2008 06:01 PM #29
    Quote, originally posted by .SLEEPYDUB. »
    I am using TT cams so let me know if you wants those.
    Tom my phone died again!
    Email | Facebook
  30. 09-30-2008 09:23 AM #30
  31. 09-30-2008 05:02 PM #31
    I used ARP both times.
    100% true. I screwed mine in all the way - then back 3 times or so. Basically just enough to make the bolts flush w/the top of the nuts.
    ~ 2.9L24VAWICVR6TGTI ~ "NuckinFutz" ~ SOLD 8/19/10
    New England Herpetoculture - Exotic Animals & Supplies
  32. Member boostAbear's Avatar
    Aug 19th, 2003
    CT
    Hoop-D
    10-07-2008 01:16 PM #32
    why the hell would you EVER want your CR that low???
  33. Member 29er's Avatar
    Feb 25th, 2007
    Not Fancy
    '12 JKU Rubicon
    10-07-2008 02:19 PM #33
    Watching
  34. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    10-08-2008 05:21 PM #34
    Quote, originally posted by vrDUCKin »
    Watching
    Email | Facebook
  35. 10-10-2008 11:20 PM #35
    Quote, originally posted by INA »
    Thanks
    Modified by INA at 7:15 PM 9-26-2008
    Can any1 chime on using this valve springs set. In the past Ive used full schrick 12v valve train, been a little spoiled. Pricing is not that bad considering I paid around 1K for a full schrick valve train.
