VWVortex.com - Triangle shape dash light???
    Results 1 to 21 of 21
    Thread: Triangle shape dash light???
    1. Member Angina's Avatar
      Oct 21st, 2002
      2012 Golf R, 2007 BMW X3, 2002 Jetta 1.8T
      06-13-2008 01:21 PM #1
      I have a 2002 Jetta 1.8T, and a light on the dash that looks like a triangle with a circle around it, with an exclamation mark in the middle, is showing up every now and then (i think this symbol normally blinks if the car is sliding)... Its the triangle symbol in the below pic:
      Anyways, after driving, this light will come on (steady, not blinking). Does anyone know what could be causing this?
      I did recently have some CELS being thrown for a bad front 02 sensor and bad temp sender. I had those fixed, and the shop also fixed an exhaust issue (hangars that hold it up broke). I still have a CEL for a checksum error from my ECU/APR mod, but not sure why this other light is coming on.
    2. Member Boosted96GSX's Avatar
      May 29th, 2007
      West Palm Beach
      2000 GTI 1.8BT, 2005 Jetta GLI, 2004 Touareg V6, 2001 Jetta 1.8T RIP, 1998 BMW Shorty7Forty
      06-13-2008 01:24 PM #2
      Traction Control light
      If tires start to break traction from the road, it will blink, letting you know, and also pull some power to regain the lost traction.
      If the light stays on, then either you turned it off, by pushing the ASP light i believe its called near your ac vent, or you have an issue with the car and it is automatically dissengauging it.
      My Jetta had problems and the traction control never worked.
      So, if you are trying to launch the car hard peeling out, or doing burn outs, or anything where the tires might breaks loose(if thats what you want), turn it off...
      It's just a safety feature...
      Modified by Boosted96GSX at 1:28 PM 6-13-2008
      2000 GTI 1.8T - 20th Swap #3131 - NGP Original APR Stage 3 - NOW Unitronic 630cc Mafless, GT3071R, APR Exhaust Manifold, AEB head, IE Rods, IE Titanium Valvetrain, IE Adj. Camgear, Schrick Camshafts, SEM Intake Manifold w/ 70mm TB, Phenolic Spacer, FluidAmpr Crankshaft Pully, ACT 6 Puck Clutch w/ Lightweight Eurospec G60 Flywheel, IE Crankshaft Dowel Pin, ARP Everything and DW v65 High Flow Fuel Pump to name a few....
    3. Member veedub1991's Avatar
      Mar 16th, 2006
      pnw
      06-13-2008 01:26 PM #3
      Well that light is your traction control light. Check your MAF, cause i forgot to hook my MAF back up one day and the light would stay on.
    4. Member stevemannn's Avatar
      Apr 17th, 2008
      the dirty burg pa
      1994 huffy 10speed
      06-13-2008 01:28 PM #4
      its probably form your maf sensor .
      if its unplugged the light will go off or if the maf is completely shot it will go off..
      not sure why it turns traction controll off....but hey its a Volkswagen lol
      nahh but i put money on it... its your maf
    5. Member Angina's Avatar
      Oct 21st, 2002
      06-13-2008 02:09 PM #5
      the shop replaced my front 02 sensor, and did some exhaust work...would they have had to disconnect the MAF to do any of that work?
      How do I/where do I check to make sure MAF is plugged iN?
    6. Member veedub1991's Avatar
      Mar 16th, 2006
      pnw
      06-13-2008 02:29 PM #6
      Your MAF is connected to your airbox. So when your looking at your engine on the right side should be your airbox. Connected to that is a round device (MAF) And that has an electrical plug that should hooked to it. The MAF then connects to your intake pipe (rubber hose about 3in around) that runs down to your turbo by the firewall.
    7. Member veedub1991's Avatar
      Mar 16th, 2006
      pnw
      06-13-2008 02:34 PM #7
      I did a quick search and found this pic. The MAF is between the 2 red hoses. And the connector on the back of it is what needs to be there. Your set up will look a little different but its not hard to find.
    8. Member Angina's Avatar
      Oct 21st, 2002
      06-13-2008 02:50 PM #8
      could it be that I have a bad MAF? I'm guessing I would be throwing a engine light for a bad MAF if I did, right?
      Not sure what the MAF does, but don't some people run their cars without the MAF?
    9. Senior Member im no hero x's Avatar
      Feb 26th, 2007
      Westchester County, NY
      '03 Jetta TDI Wagon 5-spd, '97 Supra N/A
      06-13-2008 02:53 PM #9
      My mom's tdi wagon does the same thing...
      Would wheel alignment have anything to do with it? Cuz that was my guess... maybe it is the maf though?
      Looking for VW parts? Follow @irrelevanttuningco on Instagram for some great deals!
    10. Member veedub1991's Avatar
      Mar 16th, 2006
      pnw
      06-13-2008 02:57 PM #10
      I havent heard of people running without a MAF. Running without a MAF would make for some bad gas mileage and not running very well. The MAF tells your computer how much air your getting.
      But i've heard of that light coming on if the MAF is bad. But get stuff check out before you spend any money.
    11. Member VW1.8Tsunami's Avatar
      Mar 7th, 2007
      2011 Ram 1500, 2003 Stratus SXT
      06-13-2008 03:17 PM #11
      You can try to unplug your maf and see if it runs better. I believe the ECU can compensate for it being unplugged. FYI, it will make the light stay on as long as its unplugged.
      Previously Owned: 2010 Kia Forte, 2010 JK Wrangler, 2007 Passat, 2003 Jetta, 2002 Jetta, 1992 Sentra, 1998 Dakota, 1990 Ford Ranger
    12. 06-13-2008 03:21 PM #12
      I have had issues with the ASR light before when my APR Tuning was fighting it out with a bad MAF.....have you had any problems with your car going in and out of "limp" mode?
    13. Member Emron's Avatar
      Mar 27th, 2007
      Miami, FL
      2004 GTI Swapped to R32
      06-13-2008 03:25 PM #13
      Quote, originally posted by VW1.8Tsunami »
      I'm not an engineer, however, I think the mean by which the ECU compensates is the MAF sensor.
      Anyway, in the past, I also had the traction control light stay illuminated. A few hundred miles later, my ABS light stayed illuminated. If I remember correctly, I had my neighbor clear the codes for me and the lights haven't come back on.
      -Emron
    14. Member Deceitful's Avatar
      Sep 30th, 2005
      Sunshine State of Mind
      05 GTI (R.I.P), Imola 20th (Sold), 02 TT 225 (Sold), 06 Rabbit (Sold), 12 Beetle Turbo
      06-13-2008 04:05 PM #14
      Check your tire pressure.... IM SERIOUS.
      I'm not a nice person
    15. Member Emron's Avatar
      Mar 27th, 2007
      Miami, FL
      06-14-2008 06:12 PM #15
      I remember now. I think I simply pulled the fuses from atop the battery, cleaned them a bit, and then replaced them. Try doing that.
    16. 06-14-2008 06:21 PM #16
      How have you been around for so long and not know what your traction control light is??? I've never seen anything like this before....wow
      Chris
    17. Member Angina's Avatar
      Oct 21st, 2002
      06-14-2008 08:04 PM #17
      Quote, originally posted by gt02jettaz »
      Chris
      you ass. i already said that it was the traction light... but it usually blinks when you lose traction. In my case, its a steady light when I am driving in normal condition at a normal speed.
    18. 07-21-2015 01:11 AM #18
      decietful what does the tire pressure have to do w/ the ASR light or the MAF sensor other than the two share the same dummy light on the cluster.... the TPMS is built in the ABS sensor cable and TPMS can be turned off b/c its more annoying than helpful anyways you need an abs scanner to get that blasted traction control light off b/c a abs wire could cause your brake pedal go absolutly haywire making a rumbling noise but whats ironic is the abs light shuts off while your brake pedal feels like it's fighting your foot but ofcorse is no match for your manual brake pressure even if your brake booster is loosing pressure.... first i would check the break booster connections ... notorious break booster nylon hoses cracking at the seams.... oh and do use a nylon hose and shrink wrap w/ a heat gun don't cob it up w/ rubber hoses and twisty clamps but is totally garanteed to stop the leak b/c those 45 degree angles are only possible w/ 45 degree plastic couplers. Now if that doesn't fix your problem.... it's time to replace the abs sensor wires... hopefully you know someone who has a abs scanner .... or if you have a vag-com CAN 8$ off ebay and download vag-com program off pirates bay torrent .. you may be able to scan it yourself
    19. Member A-Bugg's Avatar
      Oct 24th, 2000
      Ohio
      20AE GTI, 04Golf Wagon, MK2 golf
      07-21-2015 08:56 AM #19
      If the light is on there is a code triggering it. I see that the ABS light is also on. I have both of these lit up on my car and the code is for one of the traction control sensors.
      You should try to have someone scan the car to tell you exactly what the light is for.
    20. 04-13-2016 02:52 PM #20
      I never had a code on my car for four years. then I get towed and my car has 8 codes, I think the tow man towed my car by dragging it with the e-brake up.
      why I beleave that beacaz I had tire wear. I ha dto change my tires e-brake, e-brake lines, brakes rotors, rear subframe bushings and I have 8 codes on my car sayin I now have electicall problems. can this becaz y wrongful towing?
    21. n00b
      Jan 3rd, 2016
      Charlotte
      2000 Gti Vr6, 1964 C10 (Inline 6)
      04-14-2016 09:06 AM #21
      its your ABS triggering it. Traction control uses the ABS sensors to sense slipping and if you have a bad sensor it will shut off the traction control system. One of the connectors for the abs sensor broke on mine triggering the ABS light which in turn shuts off traction control.
