VWVortex.com - Mkv r32 manual swap
    Results 1 to 5 of 5
    Thread: Mkv r32 manual swap
    1. Member 2 liter weedeater T's Avatar
      Jul 30th, 2006
      Bradenton, Fl
      96 JETTA, 06 GLI, 06 JETTA 2.5, 07 4DR GTI, 07 TOUAREG. 07 RABBIT 4DR, 08 R32, 08 audi A3
      06-13-2008 07:39 PM #1
      I'm trying to put an 04 R 6 speed manual w/ the help of 1552 design, into an 08 R. Need to know if the axles need to be replaced w/ the 04 R axles or if mine will bolt up to the 6sp tranny. will the 04 tranny even work? supposedly both cars run the exact same drivetrain. Would I need to get MKII audi tt 3.2 quattro 6speed manual axles? I've been told that the new 3.2 tt quattros run the same tranny as the 04 Rs. I have the part numbers for the tt and mkv R axles
      audi
      L 8j0 407 271 aa
      R 8j0 407 272 s
      MKV R
      L 1k0 407 271 bj
      R 1k0 407 272 cr
      From what I understand the 1st three numbers are the Vw and Audi identification. Then the rest all match except for the last two letters. Anyone have any ideas? Anyone know the mkiv R axle part #s?
      Modified by 2 liter weedeater T at 5:01 PM 6-13-2008
      Modified by 2 liter weedeater T at 5:02 PM 6-13-2008
      Modified by 2 liter weedeater T at 5:03 PM 6-13-2008
    2. Member 2 liter weedeater T's Avatar
      Jul 30th, 2006
      Bradenton, Fl
      06-15-2008 07:31 PM #2
    3. 06-15-2008 08:33 PM #3
      drivelines are different from front to back between 04 and 08, with that said will you be able to mix and match parts....thats up to you to tell us as for how the part number works the first 3 digits let you know what kind of cars it fits, second set of 3 shows what grouping they are with and 271 and 272 stand for left and right complete axle and the leters are the identification codes showing what version they are
    4. Member 2 liter weedeater T's Avatar
      Jul 30th, 2006
      Bradenton, Fl
      07-01-2008 09:43 AM #4
    5. Member 2 liter weedeater T's Avatar
      Jul 30th, 2006
      Bradenton, Fl
      08-23-2008 06:44 PM #5
