Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 71 to 105 of 303
Thread: Tiguan Aftermarket Wheel / Rim Thread
  1. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-19-2010 08:22 PM #71
    Quote, originally posted by Transfer »
    I want to hear if anyone has fitted 9.5" wide wheels either front or rear. If a 255mm tire fits fine, shouldn't a 9.5" wheel? 255 is nearly square to a 9.5 wide wheel.
    Yeah, I quoted myself. I really want to see if anyone has a good answer to this. It's the tires that rub, not the wheel, so 9.5" wide should work, right?
    '09 Tiguan 4Motion - Tuned by APR
    '11 E90 ///M3
    My flickr
    Oct 1st, 2008
    The Poopy Glove
    01-20-2010 07:35 AM #72
    a 9 inch wide wheel fits fine
    i don't see why i 9.5 wouldn't fit
    but, in the end, it all depends on the offset
    a 20 x 9.5 ET 30 is going to fit
    a 20 x 9.5 ET 45 may not
  3. 01-24-2010 04:08 AM #73
    20 x 10 offset 38 with 255 / 35 works !!!!!
    look at my tiguan
  4. 01-24-2010 06:30 PM #74
    I ordered myself 19x9'' wheels with an offset of 41....
    Anybody knows if that setup will look nice? will I need spacers to make it look fine??? and wide my tires should be if I want to play safe and keep my mags in good conditions as our roads are like a war field here....
    Oct 1st, 2008
    The Poopy Glove
    01-24-2010 06:35 PM #75
    Quote, originally posted by Millo »
    look at my tiguan
    on all 4 corners? or just in the rear?
  6. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-25-2010 12:18 AM #76
    Quote, originally posted by volksmaniac »
    From what I've found the ideal is 19x9 ET33 with 255/40 tires as this is the stock VW size. With your setup and 255 tires you'll be 0.4" closer to suspension and 0.4" farther out under wheel well. It'll probably work but I don't think we've seen that exact size yet.
    '11 E90 ///M3
    My flickr
  7. 01-25-2010 03:04 PM #77
    So if I understand well (excuse my ignorance) It might be better with spacers???
    Oct 1st, 2008
    The Poopy Glove
    01-25-2010 03:07 PM #78
    an 8mm spacer will put those wheels at the same offset as the OEM 19s that VW offers
    i would do it like that
  9. 01-25-2010 03:38 PM #79
    @E. Gein
    yes, on all 4 corners !!!!
  10. Member
    Oct 1st, 2008
    The Poopy Glove
    01-25-2010 04:03 PM #80
    @E. Gein
    how close is the inner part of the front wheel to the strut?
  11. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-25-2010 06:42 PM #81
    Sweet, so if they work on all four corners I could easily run these all the way around with 255/40/19 tires:
    19x9.5 ET33
    I think I would rather have these:
    But I don't like the measurements as much and don't want to use spacers... 19x8.5 ET 38.
    '11 E90 ///M3
    My flickr
  12. 01-25-2010 11:13 PM #82
    Thanks....
  13. 01-26-2010 02:33 AM #83
    Transfer, I'm also looking at getting some VMR wheels. 19x8.5 ET35 for the rear and 19x8.5 ET45 for the fronts. At the rear this equates to running 16mm spacers on my current wheels which I tried out for a few days to test for rubbing and scrubbing etc and it worked out fine. Maybe not the most aggressive poke but looked plenty good to me
  14. 01-26-2010 11:09 AM #84
    just ordered 19'' tires 255/40 BF GOODRICH G-FORCE TA KDW for 54$ a piece CAN...
    thanks guys for the infos!
  15. 01-27-2010 12:50 AM #85
    Why would you go with et45 in the front? That's higher than stock 17s. If you get some V710s I want to see them! I probably won't get wheels until like May.
    Umm.......... not higher than stock when you have 8.5" wheels vs 6.5" wheels it isn't, thats 14mm more poke than stock.
    Modified by Tigamajig at 1:49 AM 1-28-2010
  16. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-29-2010 12:18 AM #86
    Alright, opinions needed!
    I'm going with a budget summer wheelset due to the likelihood of the Golf R coming our way next year.
    So, Omanyt in 18x8 or RS6 18x8? Both in et35 and 245/45/18 rubber. Total cost $1k.
    I know these aren't Tigs, they're for example.
    Modified by Transfer at 9:20 PM 1-28-2010
    Modified by Transfer at 6:58 AM 1-29-2010
    '11 E90 ///M3
    My flickr
  17. 01-29-2010 01:13 AM #87
    RS6 hands down
  18. Senior Member kidshorty's Avatar
    Jun 20th, 2002
    Pittsburgh
    2009 Tiguan S
    01-29-2010 10:32 AM #88
    RS6, don't think I've seen those on a Tig yet
  19. Member
    Oct 1st, 2008
    The Poopy Glove
    01-29-2010 10:35 AM #89
    19 x 8 ET35 RS6's would look dope
  20. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-29-2010 11:16 AM #90
    Quote, originally posted by E. Gein »
    Yeah I completely agree. The problem there is that offset is 45 and max tire width I would use is 245 so you're left with only 0.1" of poke over my stock 17s. Stock 19s have 0.8" poke over the 17s and the RS6 18x8 et35s have 0.5" poke.
    I want a little better stance and I don't want to use spacers. Also, 19s would add about $300 to the total package. Gotta go easy on the Tig upgrades if I want to trade our Rabbit for an R next year.
    '11 E90 ///M3
    My flickr
  21. Member hmsa's Avatar
    Jan 20th, 2003
    2011 Audi A5, 2008 VW Tiguan
    01-29-2010 02:39 PM #91
    Where do you get Omanyts in 18 x 8 ET35?
  22. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-29-2010 02:47 PM #92
    Quote, originally posted by hmsa »
    Powerwheelspro.com
    '11 E90 ///M3
    My flickr
  23. 01-29-2010 04:24 PM #93
    Bummer on the offset of the RS6s Can't get 8.5" or 9"?
  24. Member
    Oct 1st, 2008
    The Poopy Glove
    01-29-2010 04:28 PM #94
    Quote, originally posted by Tigamajig »
    lakeshore wheel and tire has a few different options
    19x8 5x112 ET30
    19x8 5x112 ET45
    staggered set
    19x8 5x112 ET30
    19x9 5x112 ET35
  25. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-29-2010 08:43 PM #95
    19x8 5x112 ET30
    19x8 5x112 ET45
    staggered set
    19x8 5x112 ET30
    19x9 5x112 ET35
    Yeah looks like they are out there! That setup would be almost $400 more for wheels and $100 for tires which is no longer "budget" for me. The 18x8 set at powerwheelspro looks like better quality and is only $489, which is an awesome price. This is gonna end up my wife's car in a year and she doesn't care about wheels.
    '11 E90 ///M3
    My flickr
  26. Member hmsa's Avatar
    Jan 20th, 2003
    01-29-2010 09:36 PM #96
    You mean these?
    http://www.powerwheelspro.com/...d=127
    Specifications: R32 style 35mm
    Wheel Size 18X8
    Bolt Pattern (PCD) 5x112
    Wheel Offset +35mm
    CB 57.1
    Finish: Hyper Silver
    Shipping $85
    PRICE/SET: $489
    ...because I can't find the Omanyts with the same specs.
    Modified by hmsa at 9:44 PM 1-29-2010
  27. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    01-29-2010 09:48 PM #97
    oh sh*t I didn't see those 18x8 Omanyt are 5x100 bolt. Well that settles that then. As soon as winter decides it's officially done, I'll get the RS6 reps put on with Hankook V12 evo tires.
    EDIT: Changed my mind on the Hankooks. Going with Yokohama. I don't think I want a max performance tire.
    Modified by Transfer at 2:59 PM 2-12-2010
    '11 E90 ///M3
    My flickr
  28. Member hmsa's Avatar
    Jan 20th, 2003
    01-29-2010 11:43 PM #98
    LOL.
    I was excited about the idea of 18 x 8 ET35 Omanyts for my Tig.
  29. 02-05-2010 12:12 PM #99
    Quote, originally posted by chrishart1 »
    Awesome. It looks just like it was meant for the Tig.
    My wish would be to find them in gunmetal, to go with my sapphire blue.
    Where did you buy your reps?
    hey kidshorty,
    how's the ride with the 45 tires? is it rough enough to ruin the ride comfort? i'm torn between 18 vs 19. i was thinking 18 was the official max from VW. i know the appearance is really awesome but i don't want to sacrifice ride comfort because this one's my daily driver.
  30. Member
    Oct 1st, 2008
    The Poopy Glove
    02-05-2010 12:15 PM #100
    where do you see 5x100?
  31. Senior Member kidshorty's Avatar
    Jun 20th, 2002
    Pittsburgh
    2009 Tiguan S
    02-05-2010 12:21 PM #101
    Quote, originally posted by kalso6699 »
    hey kidshorty,
    nope, my 245/45 rides like a dream, I actually threw the OEM 16s on one day this fall and the wife didn't even notice and she is a huge critic of ride quality. I already got one car dumped on big wheels and skinny tires that it tough on my ass, I didn't want two. I went with the 245/45 for a little extra cushion, it looks a bit rugged, and also fills the wheel gap a little since I'm not planning on doing anything other than springs for suspension. Plsu, they were like $88 each so I thought I would try that size.
  32. Member hmsa's Avatar
    Jan 20th, 2003
    02-05-2010 12:21 PM #102
    Here: http://www.powerwheelspro.com/...id=69
    So no 18s in 5 x 112.
    Modified by hmsa at 12:24 PM 2-5-2010
  33. Member
    Oct 1st, 2008
    The Poopy Glove
    02-05-2010 12:22 PM #103
    ahhh, i was looking at this link
  34. Member Transfer's Avatar
    Jun 16th, 2009
    Seattle, WA
    09 Tiguan, E90 M3
    02-07-2010 04:26 PM #104
    Anyone with any thoughts on using a 245/45/18 tire? It's something like 1.2% smaller diameter than stock. Actual 60mph = 60.7mph on speedo with that diameter. Is this significant for gear ratios and rpms?
    I ask because the wheels I'm planning on getting are 18x8 and the tires I want don't come in 235/50. 255/45 is too fat for 18x8.
    '11 E90 ///M3
    My flickr
  35. 02-07-2010 09:14 PM #105
