Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 141 to 175 of 327
Thread: the 096/01m internal harness DIY...enjoy!
  1. Member MRosier's Avatar
    Sep 17th, 2006
    '96 Cabrio VRT, '97 Jetta VRT (rip)
    07-28-2009 01:50 PM #141
    cool, im gonna swap the new solenoid i bought from the n89 position and stick it in n91 and put the original n89 solenoid back in.
  2. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    07-28-2009 02:03 PM #142
    Quote, originally posted by MRosier »
    N91 = 3 ohms
    n89 = 60 ohms
    Wont work
    Modified by CoolAirVw at 11:07 AM 7-28-2009
    Modified by CoolAirVw at 11:25 AM 7-28-2009
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
  3. 07-28-2009 02:08 PM #143
    i have some problems with a my transmission, is slipping when engage second and forth, what do you think it could be? no codes with a obd11 i don't have the vag
    Modified by rinux1 at 11:42 AM 7-28-2009
  4. Member MRosier's Avatar
    Sep 17th, 2006
    07-28-2009 02:18 PM #144
    Quote, originally posted by CoolAirVw »
    N91 = 3 ohms
    n89 = 60 ohms
    Wont work
    I thought all the shift solenoids were the same?
    this is where i ordered the solenoid from before: http://www.makcotransmissionparts.com/75421A.html
    it says order 6 for a set.. so there must not be a difference.. i know what youre saying about the resistance though n89 is 55-65 ohm and n91 is 4.5-5.1
    Modified by MRosier at 2:20 PM 7-28-2009
  5. 07-28-2009 02:32 PM #145
    they are not the same. i can see the confusion. the n91=n93 (EPC). the others are the shift solenoids.
    Modified by rychas1 at 11:35 AM 7-28-2009
    '11 Routan SE (black), '01 Wolffy (white)
    FE ///Motorsports VCDS Hex-Can, if you need help.
    http://mefi.us/images/fuelly/sig-us/128853.png
  6. Member MRosier's Avatar
    Sep 17th, 2006
    07-28-2009 02:39 PM #146
    so where can i order a n91 solenoid?
  7. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-28-2009 02:42 PM #147
    Quote, originally posted by rinux1 »
    So now you have slips in 2nd and 4th?? With as many transmission related problems as you have posted about you better get the VAG. Or since you dont have the VAG and since there isn't a fix posted for any of the others I'll suggest you should probably just take the car to a good trans mechanic.
    Auto trans posts created by rinux1
    code P0740 after a long drive blown pan gasket help!
    Forum » Automatic Transmission Forum
    Creator » rinux1 9:21 PM 7-17-2009
    torque converter or shifting cable adjust?
    Creator » rinux1 8:21 PM 6-9-2009
    help with a new project !!!
    Creator » rinux1 11:12 AM 6-2-2009
    arrrrrggg!!!! no 4 gear please help to the gurus
    Creator » rinux1 10:29 PM 5-27-2009
    transmission pressure check DIY ( testing pressure selenoid )
    Creator » rinux1 1:30 PM 5-4-2009
    transmission slips at any gear code p0730
    Creator » rinux1 8:39 PM 4-14-2009
  8. 07-28-2009 02:44 PM #148
    the same site! next one down...
    http://www.bulkpart.com/Mercha...unt=1
  9. 07-28-2009 02:48 PM #149
    well if i wanted to take the car to a mechanic, i wouldn't be asking in this forum, the goal is to do it yourself, that is the forum for, am i wrong?, thanks anyway i thank you for the time you take to answer
  10. 07-28-2009 03:03 PM #150
    he is saying that the obd2 reader may not give all codes that vagcom may show. check the regional forums are try to find someone local with one. it really does pay for itself.
  11. 07-28-2009 03:12 PM #151
    thanks richas1, i think that best to do, really good post by the way, very useful post
  12. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-28-2009 04:36 PM #152
    Somehow I feel blighted. But I'm ok, cuz I'm smart enough, I'm good enough, and dammit people like me.
  13. 07-28-2009 07:12 PM #153
    you are awesome!
  14. Member CoolAirVw's Avatar
    Mar 8th, 2007
    07-28-2009 09:21 PM #154
    No your awesome! You've got MAD trans skills! You help people!
    Where'd ya learn all your trans stuff at?
  15. 07-28-2009 09:46 PM #155
    crying, bleeding over my many auto trannies. plus i just read diagrams over and over. i am a novice, honestly.
  16. Member MRosier's Avatar
    Sep 17th, 2006
    08-05-2009 08:29 PM #156
    ok so I still havent had any luck fixing this damn trans.
    are these trannys finicky about the trans fluid level? like if its too low will it not shift?
    a quick run down:
    purchased car with a CEL (in limp mode) so i cleared it and it shifted perfectly for days before the CEL came back. generic scanner said shift solenoid D
    was told by rychas to replace N89, so I did and cleared codes, would not shift at all. basically the symptoms got worse after I did that. I put in new oem fluid..
    however no CEL ever came back after that...so I got it hooked up to VAG and it told me solenoid N91 open or short to ground...
    replaced that solenoid with a low ohm one that coolairvw sold to me and there was absolutely no improvement from before I changed the solenoid. only thing I got was an immediate CEL for shift solenoid D again (generic OBD2 scanner)
    however I reused the fluid that I drained out, and it wasnt quite enough because nothing ever drained out during the refill.
    please help me get this thing fixed! I dont have direct access to VAG, I have to take it up to eip tuning for them to do it
  17. 08-07-2009 07:55 PM #157
    i am sorry that still no luck, but hey, u got rid of the CEL nonetheless, if u have 0 codes, fluid is the right type/level, filter new, and all that jazz, then it HAS to be the lack of a vagcom not pulling up a certain code that is your issue. having that vagcom makes a difference! did u post in the south forum for vagcom help?? did u go by the dealer? they can scan and make a recommendation, but u dont have to get the work done there.
  18. Member MRosier's Avatar
    Sep 17th, 2006
    08-07-2009 10:14 PM #158
    well no, now i have a code for shift solenoid D which is back where I started. at one point I wasnt getting a code with the obd2 scanner. as soon as i changed the N91 solenoid which is the one that vag com came up with when i took it up to EIP tuning, the code came back with my obd2 scanner. the fluid level is low, when i refilled it for the 2nd time i didnt have anymore to top it off, no fluid drained out of the hole when i was filling it which is why i asked if itll not shift if it has low fluid
  19. 08-08-2009 08:11 PM #159
    correct. incorrect fluid (too high or low) will not shift. get that right!! it should drip out of the hole. make sure its warm.
  20. 08-23-2009 10:37 PM #160
    subscribed for info
  21. 08-27-2009 08:12 PM #161
    alrighty-- I read up and did my hmwk and so hopefully I won't be wasting anyones time with noobery...
    I have a 1997 Jetta with the auto tranny. Not sure if thats an 096 or a 01m but its been shifting like piss for months and I just got a CEL with code P0740 - torque converter clutch solenoid circuit.
    I don't have/know anyone with VAGCOM, but before I continue some background:
    car was in an accident, and some tranny fluid was lost. I've since checked it and it appears to still be leaking a bit. I'm going to dig into it and fix whatever it is thats bent or broken. I also just did a head gasket job and replaced the head, as it was warped and leaking water into the oil. (at the same time, the water pump, thermostat, and various other items were replaced).
    I read that vacuum signature affects these trannies with their adaptive whatever junk, so I did a "reset" of the tranny using the Bentley instructions of holding down the accel. pedal. CEL stayed on and nothing appeared to change.
    SO i searched the net and found nothing relevant to my OBD2 code, and so I came here to this thread because frankly I didn't know what else do to.
    Tranny was supposedly replaced just before we bought it, but **** all if i know if thats true or not.
    In any case -- these are the resistance readings I got from the round plug to the solenoids:
    EV-1: 100ohms
    EV-2: 120ohms
    EV-3: 70ohms
    EV-4: 5 ohms
    EV-5: 160 ohms
    EV-6: 5ohms
    Ev-7: 120ohms
    TFT: infinity on x10 scale, between 500 and 100 on x1k scale
    it appears to me that either the harness or the solenoid (or both!) are bad -- except ev3, ev4, ev6, and the tft appear to check ok. the ambient air temperature today when I measured was between 90 and 100 degrees all day though, and the ohm readings earlier in this thread were spec at 70-something degrees -- so not sure if my readings are within spec or wayyy out of whack. that's my first question.
    my second question is, am I barking up the wrong tree?
    my theory is thus:
    my brother had his accident
    tranny lost fluid
    began running like piss
    tranny continued losing fluid
    overheated
    harness fried
    result: CEL and terrible shifting.
    am I on the right track here folks? help would be appreciated. My next step, assuming you guys think I'm on the right path -- is to replace the filter, fluid, and harness/solenoids. I'm also going to determine if the pan or something else is responsible for the leak.
    THANKS!!!
    Modified by xvdubtunerx at 5:13 PM 8-27-2009
    Modified by xvdubtunerx at 6:26 PM 8-27-2009
  22. 08-28-2009 03:31 AM #162
    Quote, originally posted by xvdubtunerx »
    t.
    EV-1: 100ohms
    EV-2: 120ohms
    EV-3: 70ohms
    EV-4: 5 ohms
    EV-5: 160 ohms
    EV-6: 5ohms
    Ev-7: 120ohms
    my theory is thus:
    tranny lost fluid
    overheated
    harness fried
    THANKS!!!
    ok well solenoid's 4 and 6 are supposed to be around 4.5-6.5 ohms, the other 5 are supposed to be 55-65 ohms.
    so i agree they are out of spec and it seems it could be the cable.
    spec's:
    sol. 1 -N88-
    sol. 2 -N89-
    sol. 3 -N90-
    sol. 5 -N92-
    sol. 7 -N94-
    all 55-65 ohms
    sol 4. -N91-
    sol 6 -N93-
    all 4.5-6.5 ohms
  23. 08-29-2009 06:01 PM #163
    ok-- so you don't think the extremely warm ambient air temps had anything to do with it?
    I'm going to open her up today and see what I find. pictures to come. Do you guys think this is the problem resulting in my OBD2 p0740 code?
  24. 08-29-2009 10:56 PM #164
    as stated before, your 4 and 6 are with norms, the others are not. that means harness. the harness could also mean the TCC code will show up. TCC is controlled by ev4, which is in spec, but still...signals are not getting around, thus the code.
    solution...change harness, recheck specs, but be prepared to also change the out of spec solenoids once the codes are cleared and the test drive. the harness may solve it all. get to work
  25. 09-05-2009 12:28 AM #165
    I've read thru this topic at least 3 times now and think I have a grasp on things.
    N88, N89, N90, N92, N94 shift solenoids
    N91, N93 pressure solenoids
    I have no codes but am getting a hard shift from 2nd-3rd. See this post: http://forums.vwvortex.com/zerothread?id=4537361
    Replacing N93 has been recommended, but since it only occurs during 2nd-3rd I think N93 is functioning properly. I'm leaning towards shift solenoids at this point.
    What steps would you recommend at this point? Checking resistance, etc? I appreciate any advice/help you can give. Thanks!
  26. 09-06-2009 01:08 PM #166
    even without codes, do the tcu relearn/tb adaptation (stated throughout the thread and the beginning) just to be sure. then, i would check resistance at the round plug(the harness plug into the ribbon). determine that, and then replaced solenoids accordingly. i will tell you corresponding solenoids when you get back to me on that.
  27. Member CoolAirVw's Avatar
    Mar 8th, 2007
    09-06-2009 01:48 PM #167
    P0740 really doesn't mean TCC solenoid circuit. This is why folks need vag-com.
    P0740 corresponds to VAg-code 01192 which means tcc slip.
    BIG DIFFERENCE!
    I fixed 01192 in the following thread.
    http://forums.tdiclub.com/show...t=01m
  28. Member CoolAirVw's Avatar
    Mar 8th, 2007
    09-06-2009 01:51 PM #168
    Quote, originally posted by joshsjetta »
    I posted in your thread.....
  29. 09-07-2009 09:59 AM #169
    Thanks. I will test the solenoids and get back to you with my findings.
  30. Junior Member al bundy's Avatar
    May 17th, 2006
    Bucharest/Romania
    2009/Skoda Octavia 2FL 2.0 TDI
    09-18-2009 06:39 AM #170
    Hi guys.
    I have a problem with a 4-speed automatic gearbox on a Golf MK3 motor AAA.
    The car goes over the place with step 1, change in step 2 and after 2 sec is to 1, increasing engine speed, passing and in 2 and is 1 and so on.
    ATF level is good, I have no error code on the machine.
    VCDS 11.11.2
  31. 09-22-2009 03:59 PM #171
    Finally got a Fluke. Here are my resistance readings:
    EV-1 N88 82ohms
    EV-2 N89 154ohms
    EV-3 N90 69ohms
    EV-4 N91 5.3ohms
    EV-5 N92 84ohms
    EV-6 N93 5.1ohms
    EV-7 N94 67ohms
    TFT 75 on K scale
    Although N88 and N92 are a little off, N89 is way out of whack. If I am correct, N89 is the 2nd gear solenoid. That would make sense why 2nd-3rd shifts are harsh at times. Your thoughts/suggestions?
    Modified by joshsjetta at 3:05 PM 9-22-2009
  32. 09-22-2009 11:10 PM #172
    everything is off, but n93 (barely). cable for sure! n89 is a 2nd gear solenoid, not the 2nd gear solenoid. do work...
  33. 09-22-2009 11:11 PM #173
    Quote, originally posted by al bundy »
    Hi guys.
    not sure i fully understand this... please restate.
  34. 09-22-2009 11:40 PM #174
    Well, I had already ordered the solenoid so I will try that first. If it doesn't help, I know what to replace next.
    Also, would measuring resistance at a temp higher than 72degrees affect results? I just realized I had checked resistance when the car was still hot.
    Thanks for your help
    Modified by joshsjetta at 10:49 PM 9-22-2009
  35. 09-22-2009 11:56 PM #175
    its supposed to be up to that temp before anything is done, so its accurate.
