VWVortex.com - 2000 JETTA..horn stopped working
    Results 1 to 5 of 5
    Thread: 2000 JETTA..horn stopped working
    1. Member greyjetta's Avatar
      May 3rd, 2006
      Oshawa/Liverpool NY
      1981 caddy. 2008 audi a3
      06-16-2008 12:21 PM #1
      I'm pretty sure this is the ground wire for the horn, I still hear the relay click when I press the horn on the steering wheel.
      Just wondering where the wire commonly breaks apart?
      thanks
      Looking to buy working and non working digifiz
    2. 06-16-2008 12:26 PM #2
      check the fuse first i heard they blow out easliy.
    3. Member greyjetta's Avatar
      May 3rd, 2006
      Oshawa/Liverpool NY
      06-16-2008 12:50 PM #3
      thanks...the fuse is good though.. just checked it..
      the relay clicks when the horn is activated..just no actual honk
    4. Member JDriver1.8t's Avatar
      May 19th, 2005
      Charlotte, NC
      03 GTI 1.8t BT
      06-16-2008 01:01 PM #4
      the wire doesn't usually break apart.
      The horns are on the drivers side behind the bumper. Check them.
    5. 06-16-2008 01:04 PM #5
      What you can do is to disconnect the horns and test them on the battery to see if they are still functioning. If not you then would have to replace them, I did that with mine, my car is missing the water guard for the under carriage and horns went because of water damage. The PIAA 500/600MHz are pretty good replacements.
