Page 2 of 44 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 1515
Thread: The all carb diet.
  1. Member speedtek40's Avatar
    Jul 8th, 2005
    Saskatchewan
    2013 Passat TDI Highline, 1996 Audi UrS6, 1991 Mk2 Jetta (mint)
    07-16-2008 04:28 AM #36
    I use the Misab gaskets and the rubber washers with the cups, I found they work far better than the crappy plastic spacers and thackery washers (which are absolute garbage). I just tighten the nuts until I have a fingernail width between the two cup washers....seems to be the easiest to tell for gap (you can feel it). It worked for me, no more massive leakage problem, although if you're using the nylock nuts, you'll probably have to use blue loctite (the removable stuff) to keep the nuts from backing off. I found that my studs weren't long enough to engage the nylon locking compound before the cups and washers were fully compressed.
    Oh yeah....and pics.
    Change is inevitable......progress is optional
  2. Member B4S's Avatar
    Apr 16th, 2003
    Marionville, Ontario, Canada
    1997 Ford Aspire, 1989 Dodge Colt GT Turbo
    07-16-2008 06:47 AM #37
    That's what I ended up doing last night. The gap (according to the Des Hammill book) is supposed to be 2mm or so IIRC, but that sucks. It tidied up most of my leaks, but since I've got emissions carbs, they've got idle bypass screws on each barrell, and two of them are leaky. I'll be fixing that today, and checking again.
    Apr 27th, 2003
    oregon city, oregon
    79 dual carb rabbit ( the dark green one )
    07-16-2008 08:19 PM #38
    turn those bypass screws in until they seat, then tighten the locknut. you dont really need fiddle with them. get the carbs setup and balanced first, using the inner bores of each carb to balance with a flow meter. once those are dialed in, if you feel like it, then adjust your bypass screws to get all bores the same for a little bit smoother idle
  4. Member B4S's Avatar
    Apr 16th, 2003
    07-16-2008 09:10 PM #39
    Idle air bypass screws completely seated, and the towers they're recessed into are now filled with silicone. Never using them again, and they could be a leak source IMO. I managed to get rid of the leak by going a bit extra tight on the two middle barrels, so I think the manifold isn't flat in that area. I've also got one idle screw that requires a full turn further out than the other three, confirmed by the colortune. I'm expecting another one in the mail soon, so I'll be able to run two at once to compare color of burn. Right now I've got the max rpm out of each cylinder, and turning any screw in more than a half turn results in an RPM drop, so I'm not worried. Once the butterflies open, then it's a non-issue. I have zero intake leaks now, so I'm not worried about a lean cylinder.
  5. 07-16-2008 09:43 PM #40
    success?
  6. Member B4S's Avatar
    Apr 16th, 2003
    07-16-2008 09:59 PM #41
    Pretty much, I'm a bit concerned with the one idle screw that is radically different, but at least the leak is gone. I'll pop the idle jet out and see if it's the same as the others. If it is, I'll just stop fussing and get to finishing the car .
    Apr 27th, 2003
    oregon city, oregon
    07-17-2008 08:48 AM #42
    sometimes you will have the mixture screw of 1 bore in or out more than the others. if you are more than 31/2 turns or less than 11/2 turns then you should get a richer or leaner idle jet for that cylinder
  8. Member B4S's Avatar
    Apr 16th, 2003
    07-17-2008 10:04 AM #43
    On three of the screws I believe I'm at 2.75 turns, and the fourth one I am around 3.5-3.75. As much as I try to convince myself there is no leak, and even though the empirical data (ie: liberal spray of brake cleaner) points to the same thing...I'm not convinced. I'm going to give it one last check tonight, I'll empty a can of brake cleaner if I have to.
  9. Member B4S's Avatar
    Apr 16th, 2003
    07-17-2008 08:43 PM #44
    @#*&)(@#*$)(@*!_!_+$(%)*(*@)*_!!!!!!!!!!!!!
    I'm dumping those silly Misab gaskets and going to the cast aluminum spacers with O-rings I have. I still have massive leaks. This time I sprayed the brake cleaner right down between the manifold and carbs, along the misab edge, and the rpms dropped hardcore .
    If the spacers don't work...then I'm going solid. I'm on stock engine mounts with a stock cam...I doubt aeration will be an issue.
  10. 07-17-2008 11:14 PM #45
    maybe take the manifold to a machine shop and have them cut new surfaces on both sides. it can't hurt and it gives you a nice flat to work with. the carbs can be surfaced too, if your willing to take them apart totaly. you can do this in an afternoon as i'm sure you know by now........it only cost me $40 to have the manifold done. when you get the carbs off, check it with a straight edge. good luck and let us know how you do.
  11. 07-18-2008 07:13 AM #46
    Quote, originally posted by VenaGTi »
  12. Member B4S's Avatar
    Apr 16th, 2003
    07-18-2008 08:45 AM #47
    This will be what happens if the spacers fail on me too .
    I was so wound up last night, that I ended up in the garage in my boxers last night, removing the carbs before I went to bed . 10 minutes and they were off the manifold...I love the simplicity of these things.
    I will not give up!
  13. Member vdub4life_89's Avatar
    Dec 2nd, 2003
    1961 Bug, 1966 bus, 1964 bug, 2007 Rabbit
    07-18-2008 02:09 PM #48
    here is mine
  14. Member B4S's Avatar
    Apr 16th, 2003
    07-18-2008 02:49 PM #49
    Nice! Solexs'? My Mikunis look similar.
  15. Member B4S's Avatar
    Apr 16th, 2003
    07-19-2008 11:40 AM #50
    Dumped the misab gaskets today, and went with the cast-aluminim O-ring holders. Going on a tip from an Alfa Romeo forum (alfabb.com), I put a bit of high temp grease on the O-rings before installing them in the holders. Also dumped the rubber isolators and cups, straight nut and washer. The leaks, I've discovered now that the manifold is off, is due to the over-porting of the manifold (from previous-previous owner). The misab gaskets overlap into the port, offering very little sealing surface. The O-ring holders eliminate that issue .
    Now...I need a new intake gasket, the new one I had on there was gas-soaked and crumbled away .
  16. 07-20-2008 10:18 AM #51
    you don't need a gasket between the intake mani and the head. if your mani is cut flat, just a little bit of high temp copper snot and you will never have a problem. i learned that from Dana of Dana's autosport in N.H. He raced a bunch of 8v rabbits in the 90's and had a shop in Heniker, iirc. i used his advice on my 32/36 carbed motor and never had a problem. again, i had that mani cut too.
  17. Member B4S's Avatar
    Apr 16th, 2003
    07-20-2008 08:26 PM #52
    There was some gasket residue on the manifold when I got it, maybe I should check it with a straight edge and see what it's like.
  18. Member B4S's Avatar
    Apr 16th, 2003
    07-21-2008 09:50 AM #53
    Heh...got a goodie coming in the mail, hopefully before the end of the summer. Can't wait .
    Might mean I have a dual sidedraft setup for sale, now that it's finally perfect, .
    It's still carb-related though...no worries .
  19. 07-21-2008 04:21 PM #54
    Quote, originally posted by B4S »
    glad to hear it
    hope to get mine running soon too. still resolving some a/c issues. yes, that's right....a/c on a dual carb set up. ought to be a freakin' nightmare
  20. Member hans j's Avatar
    Nov 29th, 2002
    City 'O Salt
    2001.5 S4 - 1986 Syncro Westfalia TDI - 1981 caddy ABA - 1980 caddy EV - 1978 bunny - 1973 T-181
    07-22-2008 01:16 AM #55
    carbs... soon to be just throttle bodies.
    Utah Imports - 858 South State SLC UT - 801-533-9600
  21. Member CozySpeed's Avatar
    Sep 24th, 2006
    the NW
    '75
    07-22-2008 05:26 PM #56
    counterflows on carbs my dream engine, some day
  22. Member B4S's Avatar
    Apr 16th, 2003
    07-23-2008 09:39 AM #57
    Heh...got my tracking number today .
    My dual carb setup might be for sale sooner than expected...
  23. 07-23-2008 06:13 PM #58
    and what exactly are we tracking now?
    didn't ya just get your shizzz to purr?
  24. Member B4S's Avatar
    Apr 16th, 2003
    07-23-2008 07:06 PM #59
    Yep, but I've always had a nagging doubt in the back of my head that my dual carb setup goes against the plan I have for the car. I'm more concerned with low end driveability, grunt, and getting the best fuel efficiency I can get out of a carbed car. I'm wasting dual carbs on grandpa-driving IMO.
    I'm not dead-set on swapping them out just yet though...it's just nice to have options .
  25. Member speedtek40's Avatar
    Jul 8th, 2005
    Saskatchewan
    07-23-2008 09:51 PM #60
    You can't grandpa drive dual carbs. Your right foot will take over and won't let you................
  26. Member
    Apr 27th, 2003
    oregon city, oregon
    07-23-2008 11:59 PM #61
    learn dual carbs and the force will be with you
  27. 07-24-2008 08:52 AM #62
    wait...these are NOT the carbs i was tuning....
  28. Member B4S's Avatar
    Apr 16th, 2003
    07-24-2008 10:27 AM #63
    I can't keep it in any longer, this is what I'm waiting for:
    My plan was to use one of the Mikunis on it, but I can't find any Mikuni PHH pump jets . They currently have 40s, but I would need some that are a tad larger, like 48s or 50s. My Dells are emissions units with 5 LARGE progression holes, and until I see how the tuning goes on the dual setup, I'm not going to commit one of them to the new manifold setup. My other option would be to buy more carbs...twist my arm .
  29. 07-24-2008 12:00 PM #64
    twist twist *cough *dcoe 45 *cough*coughand one more twist
  30. Member B4S's Avatar
    Apr 16th, 2003
    07-24-2008 12:49 PM #65
    Trust me...I'm already eBaying .
  31. 07-24-2008 04:48 PM #66
    Single 48 or 50 is way overkill. When you have a 1 barrel per cylinder setup, each draws through a 40, 45, 48, etc barrel. With 2 cylinders per barrel, each one is still only drawing through one barrel, one cylinder at a time. Put a single 40, maybe a 45 on that manifold and be extremely happy with it.
  32. Member B4S's Avatar
    Apr 16th, 2003
    07-24-2008 07:34 PM #67
    Oh yeah, if I do end up running it, which is entirely possible seeing as how I just got finished with the struggle to re-balance by duals and am fed up to *makes chopping motion at forehead* here, I'll be using a 40 with 34mm chokes.
    I just got finished reassembling everything, and FINALLY have no leaks.
  33. 07-25-2008 08:33 AM #68
    $6 each
    http://www.wolfcreekracing.com/
  34. 07-25-2008 08:38 AM #69
    Quote, originally posted by MkIIRoc »
    Baja recipe of success for years !!
  35. Member B4S's Avatar
    Apr 16th, 2003
    07-25-2008 09:22 AM #70
    Quote, originally posted by the12for12 »
    $6 each
    Hot DAMN! I completely forgot about those guys! Thanks for the memory jog, I'll be ordering some larger pump jets, 1.8 needle valve, and maybe some 34mm chokes (if they still have any) .
    I love this forum, and GREATLY appreciate the sharing of info that isn't common knowledge anymore. for all!
