VWVortex.com - Rear door stuck closed
    Results 1 to 10 of 10
    Thread: Rear door stuck closed
    1. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      04 R32, 83 Gti, 85 Golf 2dr Diesel, 90 1Z Corrado, 91 G60, 92 SLC, 96 1Z B4, 99.5 Golf 2 dr, Eurovan
      07-01-2008 05:54 PM #1
      If anybody has battled with a rear door stuck in the closed position on a mk4 4 door please help. The door is in the closed position and the interior and exterior door handle does not open the door. I pulled the panel and window assembly and can not figure out how to get the latch to open. Any suggestions?
      Oct 16th, 2007
      avant aeb 2.0 stroker (elim 2871 atm), avant ATW bagged
      07-01-2008 06:27 PM #2
      try lifting up on the door and pulling the handle. this happened on my driver side door and it was just the locking mechanism. good luck
    3. Banned Tagless's Avatar
      Jun 11th, 2008
      07-01-2008 06:29 PM #3
      ur cars just dying to be a 2 door
    4. 07-01-2008 06:30 PM #4
      Coupe FTW!
    5. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      07-01-2008 09:18 PM #5
      I was looking originally for a two door but ended with a four door golf. Pulling on the door in any direction did not help. Worked on the latch for hrs and nothing closer to getting it open.
      It not to late I can weld the rear doors shut and have myself a 2 door golf without the long doors that like to catch the wind and bang into other cars. Not from my experience but seen it happen.
    6. Banned Tagless's Avatar
      Jun 11th, 2008
      07-01-2008 09:20 PM #6
      DO IT.. but dont tell insurance
    7. Member harryvw's Avatar
      Sep 26th, 2007
      atl
      07-01-2008 10:17 PM #7
      IIRC there is a recall/tech bulletin for this at the dealerships...
    8. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      07-02-2008 12:28 PM #8
      Do you happen to have more information on the update service procedure? I have not heard anything regarding the door stuck closed. Special policy by vw they will cover and if its an update than I need to pay for it. If I have the procedures to fixing it I can do it. Thank you for the heads up.
    9. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      07-02-2008 11:17 PM #9
      TTT
    10. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      07-14-2008 02:02 PM #10
      Anyone run into something like what I got
