Page 99 of 102 FirstFirst ... 49 89 95 96 97 98 99 100 101 102 LastLast
Results 3,431 to 3,465 of 3556
Thread: ACHTUN!NG | Shop Life
  1. 08-10-2012 02:53 PM #3431
    We've got a LOT of work ahead of us! We just took delivery of the APR "Stage 4" engine that was once intended for our A3 but will now end up in the ACHTUNING Golf R! Then we'll be resurrecting the ACHTUNING A3 project shortly after... STAY TUNED!!
    ACHTUN!NG | Hartmann Wheels » follow us on facebook
    14515 NE 91st St. STE 7 Redmond, WA 98052 • 425.895.0000 • info@achtuning.com
    We are the LARGEST APR stocking distributor!
  2. Member oempls's Avatar
    Aug 8th, 2004
    Chula Vista, CA
    CW MK6 GTI
    08-10-2012 04:01 PM #3432
    Damn! That's gonna be a sick build!
  3. 08-13-2012 02:24 PM #3433
    A couple of hours in and we've already got the stock engine out of the Achtuning Golf R this morning!
  4. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-14-2012 03:44 PM #3434
    I like this! I need to come down for a real life look
    Sent from the bottomless pits of HELL!
    god i love my car. it may not be fast, but it's crazy fun!
    C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
  5. 08-14-2012 03:57 PM #3435
    The turbo for the APR "Stage 4" build on the Achtuning Golf R has just arrived. *drool
  6. 08-14-2012 07:38 PM #3436
    In-house tuning for your Audi TT RS and Audi R8 V10 is COMING SOON to ACHTUNING! Starting today, APR began shipping the highly anticipated APR 2.5 TFSI & 5.2L FSI V10 ECU Flashing Interface to APR Dealers around the globe. This will allow us to flash stock or upgraded ECUs, in house, without ever sending the ECU to APR. The APR CCD makes the upgrade process as simple as plug and play. The ECU is plugged into the device, connected to the APR Direct Port Programming servers and APR software is downloaded.
    Select ECUs from the following vehicles require the APR CCD for in house flashing:
    - Audi TT RS 2.5 TFSI
    - Audi R8 5.2L FSI V10
    Contact us to make arrangements for your APR ECU upgrade today!!
  7. 08-15-2012 03:36 PM #3437
    We're making good progress with the "Stage 4" build on the Golf R...
  8. Member DrinkBeerWSU's Avatar
    Mar 12th, 2002
    WA
    63 Beetle
    08-15-2012 06:24 PM #3438
    Jeezus Bill! That mofo is going to scream!
  9. Member crabpot's Avatar
    Dec 9th, 2006
    Mill Creek, WA
    2007 S4
    08-15-2012 06:44 PM #3439
    Are there specs on the Stage 4 motor, or is it super secret squirrel?
    BPCDubs» We use a bidet, that's how euro we are.
  10. 08-16-2012 02:09 PM #3440
    Definitely not a secret, it's just we haven't received the details ourselves.
    We know this is a similar set-up to what was thrown into the APR/BFGoodrich MaxR project. We hear we are also working with some new and improved parts which could potentially put us slightly beyond the MaxR project's figures, a claimed 500hp. We know we have APR's "latest and greatest" 2.0T head machined straight off their Centroid 5-axis machine. (check out the vid below) And of course the bottom-end has been strengthened and balanced as well.
    http://youtu.be/YpmaCZMRNzQ
    We know we have a Garret Honeywell GTX2867R turbo-charger. This is what APR had to say about it: "The GTX2867R is a new turbocharger unit from Garrett that offers a lightweight billet compressor wheel with next generation geometry for extremely fast turbocharger spool and high-end airflow numbers. It’s able to spool very quickly while still offering the headroom necessary for top end power as we cross 7000 RPM.
    Another key feature to the new turbocharger unit is the use of an anti-surge compressor housing. The anti-surge housing allows us to spool the turbocharger very quickly, running high boost levels at low airflow levels, such as in the lower RPM range, to produce tons of power off the line without worry of running into dangerous levels of compressor surge.
    We are using a T25 turbine to manifold connection with a smaller AR to help aid in turbocharger spool. After testing the differences between the larger and smaller AR, we chose to go with the smaller AR as the larger AR seemingly only added turbocharger lag with no measurable top end gains.
    We have also opted to use an internally gated wastegate setup. This allows us to use the factory N75 to control boost with the ECU just as if this turbo was intended to be on the engine from the factory. It adds a high level of precision and all the protection necessary to protect the engine should something go wrong."
    We'll have a comprehensive spec sheet made up once we confirm all the goodies. Meanwhile, the engine is just about ready to be thrown in:
  11. 08-16-2012 05:38 PM #3441
    Getting closer...!!
  12. 08-16-2012 10:55 PM #3442
    Got the stage 1 apr tune for the tdi today. What a difference! Thanks you guys
  13. 08-17-2012 02:15 PM #3443
    Thank you for the feedback and opportunity!
  14. 08-17-2012 04:57 PM #3444
    A few goodies arrived from BFI today for the Achtuning Golf R "Stage 4" project!
  15. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-17-2012 05:00 PM #3445
    Quote Originally Posted by Dion@ACHTUN!NG View Post
    Are you guys starting to Carry the bfi line? I want to order their motor mount
  16. 08-17-2012 05:17 PM #3446
    No sir, not carrying their line.
  17. 08-17-2012 06:00 PM #3447
    ... And that's not all the deliveries for today, either! Just in, we're really excited about the brand new StopTech Trophy caliper recently developed/completed for the VW Golf R and we will go much further into detail about the Trophy kit from StopTech next week. Stay tuned!
  18. 08-17-2012 07:22 PM #3448
    It's ALIVE!!!
  19. Member
    Oct 6th, 2004
    Mill Creek, Washington
    '99 Civic Hatch, '04 Audi A6
    08-19-2012 02:20 PM #3449
    It's ALIVE!!!
    Complete with the CEL on.
  20. Junior Member
    Dec 13th, 2011
    Kirkland, WA
    '09 BMP GTI
    08-20-2012 02:32 PM #3450
    ^ wouldn't be a VW if the CEL wasn't on
  21. 08-21-2012 12:35 PM #3451
    At first start-up, without the right software, you betcha.
  22. 08-28-2012 03:58 PM #3452
    I'll need to update you with what happened last week while I was gone...
    It's done!! The APR "Stage 4" engine is in, and Bill took the Golf R to The Ridge Motorsport Park for this last weekend's ACNW track event, "Strassenlage" to put it through its paces and get to know this new monster. There are still a few, minor "tweaks" to really complete the project but for the most part it's done and running well! We expect this APR set-up should put us just under the 500hp mark while StopTech's Trophy BBK will aid in bringing all that power to a halt. More info and details yet to come but first, I must now go out and drive it!
  23. Member BrownBag's Avatar
    May 18th, 2006
    Gig Harbor, Wa
    Audi A4 USP, 2012 4MO Tig
    08-28-2012 05:27 PM #3453
    I went over to The ridge motorsport park while I was in shelton visting my parents. The golf R sounded really good out on the track.
    Autodirnen
    SECK-C
  24. Member
    May 11th, 2010
    Seattle, WA
    08 A3 08 M3
    08-28-2012 09:06 PM #3454
    Dion,
    You guys still offering free install for the K04 setup? The time is nearing....
  25. 08-29-2012 11:34 AM #3455
    We sure are!
    In fact, we just got done doing a free K04 install on Shane's Tiggy earlier this week.
  26. Member
    May 11th, 2010
    Seattle, WA
    08 A3 08 M3
    08-30-2012 12:54 AM #3456
    We sure are!
    Thanks Dion...makes me wish I kept my Tiguan after seeing the dyno numbers. Anyhow, I called while you were at lunch, with Wa tax and all, the kit is still out of my reach.
  27. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    08-30-2012 02:38 AM #3457
    Wife would kill me for it...but k04 tiguan 4motion? That could be really fun!
  28. 08-30-2012 01:10 PM #3458
    A StopTech ST40 Big Brake Kit for Ian's Golf R is headed out the door! We offer FREE rear Sport Kit parts (rotors/pads/lines) with a StopTech BBK purchase - what more of a reason do you need to shop at ACHTUNING?
  29. Member
    Aug 5th, 2011
    Tacoma
    Supercharged Exige, turbo' d Range Rover Evoque, 2013 Audi A7 3.0T supercharged
    08-30-2012 01:15 PM #3459
    Planning to get a MK6 Gti later down the road. Probably lower it with H&R spring but just wondering what flash/remap can i use without effecting warranty?
    My force inducted family:
    Lotus Exige S (supercharged)
    Range Rover Evoque (turbocharged)
    Audi A7 3.0T Prestige (supercharged)
  30. 08-30-2012 02:01 PM #3460
    You're actually voiding your ECU's warranty with any "chip" brand. That said, dealers around here are very mod-friendly and recognize the APR software we install on our customer cars do not cause the typical issues their customers bring to them to have covered under warranty. That said, you have to go into this knowing you have to "pay to play."
  31. 08-30-2012 02:38 PM #3461
    Thomas knew right away after picking up his brand new Touareg that he needed a better looking wheel set-up to compliment his ride. His dealership had recommended a visit to Hartmann Wheels and after a quick visit to our Redmond showroom, Thomas immediately fell in love with the idea of running the 22" Hartmann HRS4-252-GS wheels. After recommending a set of 7mm H&R wheel spacers out back, Thomas was very pleased with the final results!
  32. Member
    Aug 5th, 2011
    Tacoma
    08-30-2012 03:53 PM #3462
    With my exprience with dealers anything modified in the cars are cause for denying any warranty work!
    Pay to play...lol i know this very well!
  33. 08-30-2012 03:55 PM #3463
    We're very fortunate to have the dealer network that exists in the PacNW. Looks like Auburn VW would be your nearest, mod-friendly dealer.
  34. 09-06-2012 04:49 PM #3464
    The Achtuning A3 Resurrection Project is under way! The stock engine we removed from our VW Golf R has found its new home in the engine bay of our A3...
  35. 09-06-2012 06:12 PM #3465
    I'm impressed.
    BPC>>Shoot when you're hot, shoot to get hot
