Page 1 of 2 1 2 LastLast
Results 1 to 35 of 46
Thread: VWOA Class Action Suit For Premature Timing Belt Failure Recall Information
  1. 07-15-2008 08:13 AM #1
    My 2002 1.8t Gti/337 just sheared 12 teeth off the belt while doing 70mph on the highway with only 82,000 miles on the clock where vw only recomends inspection at 80k no replacement schedule until 105k. I am sure I bent valves if not damaged pistons as well. Seeing as the tensioner/idler and belt are the same exact part #s as the A4, Passat and tt why is it only these vehicles being covered in recall ?????
    Tensioner part # 06B 109 477
    Idler/Roller # 06B 109 119A
    Belt 06B 109 243D
    SAME EXACT PART #S SO WHY ARE OUR CARS NOT COVERED IN THIS SUIT!! Yes I am shouting
    I am contacting this attorney that filed the suit tomorrow to see whats being done.
    On June 22, 2007 Pearson, Simon, Soter, Warshaw & Penny, LLP filed a class action lawsuit against Volkswagen alleging that the timing belts for model year 1999 - 2003 Audi and Volkswagen vehicles equipped with a 1.8 liter turbo-charged engine fail prematurely. The vehicles included are the Audi TT, Audi A4 and Volkswagen Passat. The complaint alleges that the timing belts fail prior to the service interval, as stated in the owner's manual. Plaintiff, on behalf of herself and the Class, is seeking reimbursement for the damages incurred relating to timing belt failures. Additionally, the complaint seeks an order requiring Volkswagen and Audi to update their owner's manuals to require periodic inspections.
    UPDATE: The parties have reached a class-wide settlement. Preliminary approval of the settlement was granted by the court on May 19, 2008. Claim forms, class notice and other documentation will be mailed on or about August 1, 2008. Details regarding the terms of the settlement will be in the notice sent to owner's of the class vehicles.
    Link to Attorney Office which filed the suit and reached an agreement
    http://www.psswplaw.com/CM/Cla...n.asp
    I am calling them today, if you paid big money I would suggest trying to recoupe some of it by giving them a call.
  2. Member mhjett's Avatar
    Oct 16th, 2000
    Northern Virginia
    2008 VW Jetta SE
    07-15-2008 08:17 AM #2
    simple answer: going only from what you posted, the golf/jetta aren't included in the settlement because they weren't included in the lawsuit.
    1995 VW Jetta GLX VR6 [07.2003 - 03.2012]
  3. Member Isgro's Avatar
    Mar 10th, 2004
    Mass
    '07 Rabbit, '05 T-100, '63 Type 2 SC
    07-15-2008 08:20 AM #3
    Did you get the recommended 80,000 mile check done? If the belt was on it's way out, wouldn't this inspection have noticed these faults and prompted you to replace it before it blew at 82,000 miles? Just playing devils advocate here.
    Matt
    B.D.I. | c.b.s. | Busdejos | MID
  4. 07-15-2008 08:24 AM #4
    Looks that way, but that can change if enough people with failures get together and file for ours as well.
    If you have had a failure, please add your name to the post I would say the Passat, A4 TT cases sets plenty of precedent.
  5. 07-15-2008 08:29 AM #5
    I checked it personally walked the crank all the around no stress cracks, grooves and tension was good.
    its not really the belt they are blaming, but the tensioner. Its hydraulic and if it loses pressure it lets the belt slack and belt skips at 3000 rpm highway speed in my case = fubar
    so the belt is merely symptomatic of the underlying problem
  6. Member Tucci's Avatar
    Feb 2nd, 2005
    Oakwood GA
    3.2 TT
    07-15-2008 08:37 AM #6
    Quote, originally posted by 4LUGVDUB »
    so you checked it? haha Instead of brining it to a dealer or qualified shop that may have been able to foresee this as they work on the cars daily, you checked it and now want to sue VW. Amazing.
    Modified by Tucci at 8:39 AM 7-15-2008
  7. 07-15-2008 09:39 AM #7
    good luck toolio. Shoulda got it checked by a VW tech. I'd say you are boned.
  8. Member nm+'s Avatar
    Jan 6th, 2006
    Land of Bro-Dozer Ya Yas
    07-15-2008 09:42 AM #8
    Quote, originally posted by Isgro »
    This is what VW will say and may win on this.
    Hwoever, given the same PN as the passat, the issue on the passat was a failing tensioner that gave no warning before failure.
    This was actually said
    Apr 14th, 1999
    Northeast GA
    2012 manual TDI JSW; 1997 VW Passat sedan VR6 5-speed;
    07-15-2008 10:03 AM #9
    I have to say that the law firm that filed the suit seems to make a living off of class-action suits. It'll be interesting to see exactly how much of the settlement accrues to the law firm and how much to the plaintiffs. IMO, such suits are almost always settled for the benefit of the lawyers, with very little useful consideration for the actual members of the class.
    2012 base manual TDI JSW
    Retired: 1997 VR6 Passat 5-speed -- 331k+ miles
  10. Member velocipedio's Avatar
    Apr 26th, 2006
    Cologne, Germany
    Audi S3 Sportback. Audi A4 Avant quattro (gone)
    07-15-2008 10:05 AM #10
    You will lose. You didn't get the belt inspected by VW.
  11. Member 20thAna3282's Avatar
    Oct 8th, 2005
    Methuen, MA
    2003 VW Gti 20th AE
    07-15-2008 10:09 AM #11
    Quote, originally posted by velocipedio »
    x2
    If you even get a cent i would be shocked.
    -Matt
    Jun 22nd, 2006
    Edgewood, MD
    Euro Ford junk collection
    07-15-2008 10:32 AM #12
    So a maintainence item failed on your now 7 year old/80,000 mile car... and you want to sue VW? WOW. If you were that worried about it, why didn't you replace it early? You seem to indicate you knew it was a common problem that if went unchecked, could cause extreme engine damage. The maintence schedule is just a "recommended" replacement schedule. Not every vehicle is going to have the same needs. Some will need replaced early, some will last forever. Could've saved yourself a lot of money! Do you think I could sue Ford because my 98 Contour needs converters?
  13. Member kerridwen's Avatar
    Aug 3rd, 2001
    Mexico City, Mexico
    Yamaha XT660R & XT660X
    07-15-2008 10:34 AM #13
    LOL!!!
    The real problem is that something got lost during the translation.
    Just go check what the replacement interval is in KMs in EU cars, and you'll see that it is the same # of kilometers as miles, like if they hadn't done the kms to miles conversion...
    There is no way in hell I would expect a timing belt to last 168,000kms. All VWs I've had or that my family had, called for a new belt every 90,000kms.
    Also, a bit of research shows that to be safe, you have to replace the belt at about 60,000 miles...
  14. 07-15-2008 10:42 AM #14
    Quote, originally posted by Tucci »
    Not advocating going to the "stealership" but had you taken it and paid .5hr inspection time at 80K, when the belt failed at 82K, you'd have a very STRONG leg to stand on with VW.
  15. 07-15-2008 10:43 AM #15
    When I had my GTI, I replaced the belt and waterpump at 65K regardless of what VW recommended. I researched the weak points on the car and gathered this was an important piece of preventative maintenance to do. I understand you want to blame VW, and even if it's legally sound, there is more than enough info out there to tell you to change the stock belt / waterpump earlier than the recommended interval.
  16. Moderator TREGinginCO's Avatar
    Jan 4th, 2004
    Parker, CO
    '06 Campy White Touareg V6 & 2013 Ibis White Audi allroad
    07-15-2008 11:02 AM #16
    There is only one set of winners in a class action lawsuit.... the lawyers!!
    My advice to anyone is to never get involved in those things... because the only people who see any benefit is the attorneys who collect their payments.
    I'm not even going to wade in on the issue of suing VW for an issue at 82,000 miles.
  17. Member GTI 20v's Avatar
    Oct 12th, 2000
    Right over there
    2005 S2000; 2011 Mini Countryman S All4; 2010 Jetta Sportwagen TDI; 1966 Pontiac GTO
    07-15-2008 11:44 AM #17
    The timing belt failed in my 2001 GTI in the same manner- shearing teeth off. FWIW, the "80k inspection" is meaningless. I visually inspected my timing belt a few hours before it failed and there were no apparent flaws. It even passed the inspection criteria layed out in the Bentley manual.
    Forunately for me, the ensuing engine damage (bent every exhaust valve) was covered under the 10/100k powertrain warranty.
    Quote Originally Posted by DUBLUV401 View Post
    I am not here for grammer lesson's
  18. Member 2004turbo's Avatar
    Dec 1st, 2004
    Northern NJ
    2010 S4
    07-15-2008 12:28 PM #18
    Mine went out at 40k . I want a Audi so bad but won't let myself because of that
  19. 07-15-2008 12:29 PM #19
    You bought a Volkswagen, that's why you're being treated like a second-class citizen.
  20. Member atomicalex's Avatar
    Feb 2nd, 2001
    Detroit and Düsseldorf
    dark blue stick shift station wagons and one shiny yellow motorbike
    07-15-2008 01:20 PM #20
    If you'd hauled in for the maintenance check, I'd say you have some leeway and would be able to find a dealer to cover it for you. However, without a stamp in your book, you're kind of screwed.
    I remember taking my wagon in for that check: I took pizza, homemade cookies, and a bunch of other goodies in along with the request to just check the belt and stamp my manual. I paid the $100 labor, too, without any gripes. Why? Because if the belt had gone, I wanted coverage, and I wanted the techs to think of me well so they would beg VW for me.
    Last time I had a belt go, it was on our old 2.0, and it was covered in full because we were on good terms with the dealer.
    A(u). Klasse A, unbeschrankt, ungedrosselt
    Compared to a British roadster, all Volkswagens are reliable!
    nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
  21. Member SinisterMind's Avatar
    Feb 27th, 2004
    Quakertown, Pa
    '04 GTI, '12 Camry SE
    07-15-2008 01:25 PM #21
    I had my belts changed at 70k. The belt itself was fine, but the tensioner was worn out. It could've failed before the 80k mark.
  22. Member
    Jan 27th, 2003
    Toyota Sienna Crossover SUV,Nissan GT-R
    07-15-2008 01:35 PM #22
    Most proceeds from a class action lawsuit will go to the lawyers.
    Don't buy and car with an interference engine.
  23. Member GTI 20v's Avatar
    Oct 12th, 2000
    Right over there
    07-15-2008 01:37 PM #23
    Quote, originally posted by driveareliablecar »
    Please tell us, what new passenger cars are available in the US with non-interference engines that the auto enthusiast might enjoy?
  24. Member
    Jan 27th, 2003
    07-15-2008 02:28 PM #24
    http://www.gates.com/brochure....=3487
    Not sure what cars an auto enthusiast might get enthused about. Gates belts can help people decide if they want to look up individual cars.
  25. 07-15-2008 02:31 PM #25
    Live and learn....
    BTW--Didn't VW recall the pre-03 models for defective tensioners?
  26. 07-15-2008 03:03 PM #26
    Link didn't work for me......
    Randy
    2012 Audi Q5 | 2002 Passat 1.8T manual
  27. Member TisforTurbo's Avatar
    Nov 7th, 2004
    SLC, UT
    E46 M3, K8 GSX-R
    07-15-2008 03:22 PM #27
    I thought you are supposed to do the timing belt thing at 60k
  28. Member fixmy59bug's Avatar
    Apr 9th, 2002
    2013 Passat TDI, 1959 Vw Bug
    07-15-2008 03:28 PM #28
    Belt 06B 109 243D
    I hate to tell you, but the passat and any other Vw models do NOT share part numbers for any of the timing belt components.
    For the Passat:
    Belt: 06B-109-119-F (No Supercession here)
    Roller: 06B-109-243-B (Superceded to 06B-109-243-E)
    Hydraulic Tensioner: 06B-109-244-A (No Supercession here)
    For all other 1.8T engines:
    Belt: 06B-109-119-A (No supercession)
    Roller: 06B-109-243-D (Superceded to 06B-109-243-F)
    Hydraulic Tensioner: 06B-109-244 (No Supercession)
    Notice they are slightly different part numbers but they are NOT interchangeable.
    Besides, If I am not mistaken, Vw lowered the service intervals to 60K inspection and 80K replacement.
    I hate to tell you, but I think you got to take this one in the shorts.
  29. 07-15-2008 03:30 PM #29
    Quote, originally posted by TisforTurbo »
    That's what I've been told on my 1999 A4 AND my 2003 GTI 20th AE.
  30. 07-15-2008 03:30 PM #30
    I have a 2002 Passat and I did not get a notice from VW for 80K replacement. Original owner too.
    Randy
  31. Member SinisterMind's Avatar
    Feb 27th, 2004
    Quakertown, Pa
    07-15-2008 03:44 PM #31
    Quote, originally posted by PDing »
    The manual in my car states to replace the belts at 100k.
  32. Member fixmy59bug's Avatar
    Apr 9th, 2002
    07-15-2008 04:17 PM #32
    But with all due respect, if they change their mind after something is made, the change doesn't magically appear in the manual.
    I have just confirmed it with Vw's Servicenet on the 2004 maintenance schedules that Vw recommends an inspection at 60K, belt replacement at 80k and a roller replacement no later than 100K.
    Of course it is wise to just replace it all at once while you are in there at 80K. So I see this lawsuit going nowhere....
  33. Geriatric Member VDub2625's Avatar
    Jan 3rd, 2003
    Fall River, MA
    90 Jetta GLI 16v, 99.5 Cabrio Highline
    07-15-2008 04:24 PM #33
    Quote, originally posted by fixmy59bug »
    What about the Audis? THe TT and A4. Same as the Passat?
    A2Resource
  34. 07-15-2008 05:13 PM #34
    Not for the 03 and later models. The design problem you refer to was on the models made before that. Like I said before I think it was a recall....
  35. Senior Member feels_road's Avatar
    Jan 27th, 2005
    East Bay Area
    2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
    07-15-2008 10:37 PM #35
    It's not just 80,000 miles. As any tech will tell you, it's a gamble to drive one past 6 years, or so. A good tech would have replaced it approaching six years, regardless of mileage or (sometimes unreliable) visual inspection.
    Aung San Suu Kyi
