Results 1 to 22 of 22
Thread: DIY- Cleaning Engine Bay
  1. 07-19-2008 10:00 AM #1
    Hey guys. Searched for DIY and never found one, so I decided
    to do my own. I hope it helps you guys.
    Please note, this is the procedure I used. It works for me. In no way am I responsible
    for any damage that you may cause( not that you will, and Im hidden in the smallest
    country in Africa!!)
    Please READ ALL instructions on cleaners before you use them, and check that they
    are engine friendly.
    This is also a perfect time to check for loose hoses, any leaks, tighten all clamps,
    luve the DV, clean flat panel and put everything neatly back in place. If you are doing the
    DIY-Engine bay cleanup SAI etc., an engine wash is the perfect thing to do right after.
    Please correct me if Im wrong in any way. Im doing this from the goodness of my heart
    for the newbs especially.
    PS( I dont care what cleaners are better. Im in Swaziland, this is the best I could purchase
    over here))
    1. One or two able bodies for the job!
    2. You will need
    - Rag/cloth, sponge and steel wool
    - Paint brush (new)
    - Star screwdriver and spanner
    - Some form of plastic cleaner
    - Enigine wash (I used castrol)
    - Electrical Contact cleaner( for PC use etc)
    - Something to smoke or chew on
    - Aluminium foil
    3. Start by covering all electricals. Normally your engine will be waterproof, but hey,
    who wants to take a chance. I found aluminium foil the best to use.
    4. Start the engine, and let the car warm up a bit. The photo shows ideal temperature.
    General rule of thumb, if you touch engine and its not hot enough to say "ouch" then
    the temperature is okay.
    5. Once engine is warm, switch off. Remove negative battery terminal.
    6. Remove engine covers. Spray your engine cleaner on places needing to be cleaned, and let it
    soak in for a while( read instructions on cleaner).
    7. Now that cleaner has soaked in on grime its time to remove grime. For general blaces use
    the paint brush and rag to clean. For in betweens and hard to reach places, I put a thin wire
    with a rag covering and cleaned these places.
    8. Once all the grime is removed, its time to wash off your engine cleaner/grime remains.
    Lot of people will rush to use pressure hose, but i reccomend a nice, easy flow from
    a normal hose. (you might notice your plumbing has white spots from cleaner. Dont worry
    about that)
    9. My blower broke out on me so I used sun power!! Its 34 degrees celsius today, so
    it was quite a fast process. I used a rag to remove water that sat/remained in grooves.
    10. While waiting, i decided to get some steel wool and metal polish to clean intake manifold
    etc..
    11. When engine is dry(or relatively dry) use a dry cloth to wipe foil around the engine
    electronics to remove any water, and then remove the foil. Leave to drive out nicely.
    12. Once you sure the engine is completely dry, clean the sensors out with contact
    cleaner. It cleans the sensors, and displaces moisture. Please make sure its user
    friendly with electronics. Generally computer stores sell the best ones(here anyway!!)
    13. Last but not least, use a plastic polisher/cleaner of your choice to clean and add
    shine to all hoses, covers etc. Do the rain cover as well. Try to use a silicone free
    spray beacuse a) it collects dust super fast and b) it gets a bit hard on the
    hoses and may cause them to crack( easy boost leak!!!)
    Dont forget to check engine for any tools/foil you could have left over. Replace engine covers
    and the negative battery terminal. Switch car on, and let idle for ten minutes. You
    should be able to know by hearing, for any misfires etc for water that could have seeped in(a
    bit impossible if covered correctly but possible non the less). Easy option would be to
    run a quick Vag.Com
    Admire your beautifil work. Please excuse my engine cover, I stupidly scratched it
    in the process.
  2. Member stevemannn's Avatar
    Apr 17th, 2008
    the dirty burg pa
    1994 huffy 10speed
    07-19-2008 12:48 PM #2
    nice car
    Quote Originally Posted by speeding-g6O View Post
    so yeah, i wanna get me some of those hid lights, so i can see the girls in the dark better so i can pick them up and go skating. i like skating. i never did speed skate, as i am sort of odd shaped. people have called me an "egg on stilts" which means i am kind of top-heavy. with skinny long little legs. i prefer smooth and sleek like a stork, but then people say it rhymes with "dork" so that doesnt work.
  3. 07-19-2008 01:04 PM #3
    Nicely done, added thread to FAQ
  4. Member Jetta4Life's Avatar
    Sep 5th, 2001
    2003 1.8T GTI, 2001 BMW M3
    07-19-2008 01:44 PM #4
    looks good! like the bumper, who makes it?
  5. 07-19-2008 01:48 PM #5
    Thanks so much you guys
  6. Member SoFloGLI's Avatar
    Dec 15th, 2004
    South Florida
    2005 vw jetta gli
    03-25-2009 03:04 AM #6
    CaMALE toe!
  7. Member stevemannn's Avatar
    Apr 17th, 2008
    the dirty burg pa
    1994 huffy 10speed
    03-25-2009 03:22 AM #7
    AHAHAHAHA
    that is so worth being ressurected lol
  8. 08-10-2009 01:21 PM #8
    looks nice
  9. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    08-10-2009 02:18 PM #9
    What front bumper is that? It looks badass
  10. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    windsor 2.0, ginster 1.8t
    08-29-2011 10:12 PM #10
    wow we came a long way from 08 cause im pretty sure this car would be getting a lot of hate in these days
  11. Member ldaledub's Avatar
    Oct 14th, 2007
    2005 vw gli, 84 gti
    08-29-2011 10:31 PM #11
    haha
    CTS turbo,UNI,USP, Integrated eng.,Labonte motorsports,ESEtuning.
  12. Member fosterfobag's Avatar
    Aug 14th, 2011
    The 'HAM (WA)
    20V & 8V
    08-30-2011 12:40 AM #12
    Wow
  13. Member fosterfobag's Avatar
    Aug 14th, 2011
    The 'HAM (WA)
    20V & 8V
    08-30-2011 12:46 AM #13
    Actually I'm pretty grossed out.
    A) Lower
    B) What the f^$# front bumper is that?
    C) Door Handles
    D) Chrome wheels ain't working.
    but hey, it's not my car.
  14. Member PoLock33's Avatar
    Aug 14th, 2011
    B'Ham WA
    1982 Jetta coupe 1.6D, 1989 GTI 1.8 16v, 82 rocco
    08-30-2011 02:50 AM #14
    Quote Originally Posted by fosterfobag View Post
    Amen....
    No Bad Days.
  15. Member GTIRACER2.0t's Avatar
    Apr 2nd, 2001
    '01 Indigo 4dr 1.8t , '94 4dr vr6 Obd2 gti swap
    08-30-2011 03:03 AM #15
    Quote Originally Posted by PoLock33 View Post
    Amen....
    Clean engine..Those wheels and bumper offended me.
  16. Member PoLock33's Avatar
    Aug 14th, 2011
    B'Ham WA
    08-30-2011 03:56 AM #16
    Quote Originally Posted by builtvw View Post
    No Bad Days.
  17. Member desertdubs_C's Avatar
    Sep 20th, 2009
    Phoenix
    2005 VW Jetta GLI Blue Lagoon --all stock--
    08-30-2011 06:00 AM #17
    ^This.
    No joke...a little stomach acid came up when I saw this car. I appreciate how the owner took the time to detail the engine bay. However, this does not take away from the fact I nearly spit up what food I had in my belly. An overall rating of 2 and a
    My never ending project RootsNeverDie
  18. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    08-31-2011 01:24 PM #18
    exactly my point lmao
  19. Member lorge1989's Avatar
    Sep 3rd, 2008
    Buffalo, NY
    2000 Audi A4, 1988 Audi 90, 1985 VW GTI
    08-31-2011 01:51 PM #19
    A) Lower
    C) Door Handles
    Quote Originally Posted by desertdubs_C View Post
    ^This.
    Go back to the emkayfour forums.
    When I clean my bay I find it easier just to take the coilpacks out with wiring just to make sure I don't get any water in there. Just makes the job a lot easier and gives me piece of mind.
    Good write up non the less.
    Dubs in the Buff
    in other news, lindsay lohan prefers "philosophical dabbler" to "crack whore."
  20. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    09-01-2011 01:04 AM #20
    im thinking they made a hot wheels car of it
  21. Member fosterfobag's Avatar
    Aug 14th, 2011
    The 'HAM (WA)
    20V & 8V
    09-02-2011 01:49 AM #21
    I saw a pretty sweet honda today.....
  22. Member wagner17's Avatar
    Oct 19th, 2009
    baltimore
    jazz blue 20th # 427
    09-02-2011 02:38 AM #22
    thread is mad old lol.. but yea you two are right
    SoIAteAPancakeToday
    i have a really small penis so i lowered my car so people will look at me
