VWVortex.com - remove stereo without radio removal keys
    Results 1 to 19 of 19
    Thread: remove stereo without radio removal keys
    1. 07-21-2008 03:34 PM #1
      is there anything i can use to remove the stock stereo without have those key things???
    2. 07-21-2008 03:35 PM #2
      Nope. Tool for every job.
    3. Member LOW36's Avatar
      Jan 17th, 2008
      SL,UT
      Bagged E36 Beast
      07-21-2008 03:37 PM #3
      just get the tool, to be safe [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ***Bagged E36 ***
      FACEBOOK
      flickr
    4. 07-21-2008 03:39 PM #4
      i had a friend pick up some from o reillys but they are for something different they were the pin things.
    5. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      07-21-2008 03:40 PM #5
      make some.
      "Turning right in fifth gear from the left hand lane into the wrong end of a one-way street while indicating left, if at all."
      All the custom, none of the cool.
      "Trying to be the cool kid is so cool." - MkIV Scene
    6. 07-21-2008 03:41 PM #6
      Its def a good idea to get the tool but if you cant and need to do whatever it is your doing now there is a way...there are 4 screws that you can find by removing the plastic pieces above and below the stereo, they are very small but after you remove them you can pull the entire thing out and get to the back of your stereo that way. This is how i did it when i put in an iPod adapter and worked fine [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member dremhmrk2's Avatar
      Sep 19th, 2003
      Fort Lauderdale FL
      2001 Mojave GTI GLX
      07-21-2008 03:43 PM #7
      make the tools out of credit cards or pendaflex hanging folder rods
    8. Member mikegilbert's Avatar
      Nov 29th, 2006
      Los Angeles
      328D / TDI / LWB
      07-21-2008 04:18 PM #8
      Make some- I used the metal collar stays from Bananna Republic shirts and fashioned the other two from an altoid tin [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      It really works
      PM Travy℠ |flickr | mikegilbertphotography.com | Everything you need to know | » | Scratch-It™ | Vimeo
      Great, a Chevy Lumina thread. Now I'm going to have an erection lasting more than four hours.
      #FREEPATRICKMAN
    9. Member veedubcos's Avatar
      Jul 12th, 2006
      Atlanta
      2011 CW GTI MT
      07-21-2008 04:47 PM #9
      hammer... jk theres a write up in the FAQS/DIY section on it using the metal strips from hanging folders.
      1985 Golf | 1996 Golf | 1997 Jetta Trek | 2005 GTI | 2012 3.6 SEL B7 Passat | '11 CW Autobahn GTI
    10. 07-21-2008 06:34 PM #10
      Quote, originally posted by jwad10 »
      Those are the ford removal tools. Oreillys doesn't carry them from what I have seen. Ebay has them cheap though.
    11. 07-21-2008 07:08 PM #11
      i just ordered some off ebay thanks everybody
    12. 07-23-2008 07:49 PM #12
      i decided i couldnt wait for them to get in so i have the dash apart and the center part that holds everything is stuck i have all the visible screws out but it is still stuck and i need help fast please
      i followed all the steps necessary using these diys
      http://forums.vwvortex.com/zerothread?id=967146
      http://forums.vwvortex.com/zerothread?id=958556
      Modified by jwad10 at 5:03 PM 7-23-2008
    13. 07-23-2008 08:05 PM #13
      get an old credit card and cut it into strips. put the strips in the slots on the radio. it will unlock the stereo from the cage and you can pull out the radio.
      very simple.
    14. Member silver_slayer's Avatar
      Jul 1st, 2008
      Lake Mary FL
      08' Jetta
      07-23-2008 09:38 PM #14
      you sure you got every screw? i just know there is a couple that are hiding pretty good. i think there is 3 on each side of the cage.
    15. Semi-n00b
      Apr 17th, 2011
      Tunkhannock, PA
      2002 VW Jetta 1.8T
      01-19-2012 12:27 PM #15
      I hate to bring this thread back from the dead but I am recently trying to get my radio out after I picked up my car this past summer and I ordered the keys off ebay but when I stick them in the slots they don't click in all the time and when I try and pull back once they are in they immediately release and won't pull the radio out any. I have a Monsoon double din radio, so I am not sure if the plastic pieces above and below can be removed like it was discussed in the above post or not. I am assuming the previous owner tried to used home-made keys and damaged the release tabs so now they won't work properly. If anyone has any other suggestions it'd be greatly appreciated.
      Snoman
    16. Member ebro's Avatar
      Apr 2nd, 2009
      Cranford, NJ
      JB20thAE
      01-19-2012 12:52 PM #16
      cut up a cd
    17. Member 01wolfsburgj's Avatar
      May 3rd, 2011
      Honeoye Falls, NY
      2004 DBP .:R32, 1996 Audi A6 Avant Quattro
      01-19-2012 01:52 PM #17
      well, the way i went about doing it was there is four very small screws on the top and bottom. take them out and the whole front face comes off. use something like a tooth pick or something to pull in all four tabs. headunit slides out.
      -Connor
      @connoromara
      DBP .:R32
      #SEND_IT
    18. 06-25-2015 08:11 PM #18
      Sorry about continuing an inactive thread.
      If anyone is looking for DIY radio removal key information, I found the following TDIClub post includes a very nice template.
      http://forums.tdiclub.com/showthread.php?t=364014
    19. 02-15-2016 12:59 AM #19
      they are very small but after you remove them you can pull the entire thing out and get to the back of your stereo that way.????
      == Solitaire ==
