Have you tried posting on the Vag com forum? Trying starting a thread in there I'll bet there is a bit more traffic in that area of this site.![]()
#1
does anyone have vag commander 1.4I bought one and none of the channels will communicate
when i start up the program it says DOG INIT failed
DOG INITIATION FAILEDthe com port works and the lights blink when I try to open a channel
But the channel will not connect? I wonder why
I have tryed all version 1.4 2.1 3.0 4.5 and 5.1I tryed 2 different pcs and still nothing. The lights are blinking on the vagcom but it does not open the channel ever!
#2
#3
Quote, originally posted by Amsterdam087 » Have you tried posting on the Vag com forum? Trying starting a thread in there I'll bet there is a bit more traffic in that area of this site. ![]()
No reason to send him there, Its not a Ross Tech product.
They make it pretty clear that the forum is strictly for VAG-COM products only.
Clearly this is a case of a failed third party cable.Contact the manufacture, most likely you'll need to send it back as its firmware is damaged.
Happens quite frequently when someone updates.
I make a copy of my firmware and keep it as a backup. I won't get into details about it. As my cable is not a Vag-commander.
Best of luck.
The original Dub and Dubber.
Manche VWs sind einfach schneller als andere.
#5
Having the same issue, wondering if you ever found out how to get it to work.
Thanks
