i think you'll be fine without air tools but it would make the process go a lot faster.
#281
I'm looking to install my B&Gs tomorrow -- Doug (friedguy) and myself think we've got most of it figured out, but it looks as though air tools might be needed. I know it's a long shot, but does anyone here have tools or access to them? Thanks.![]()
#282
Formally : 05slvrstonegray1.8t
PM me for services..
Bodywork (molding/shaving)
Coilover installs , Air installs
Vag Com Scans
#284
are you reusing the same bumpstops etc?i had to cut mine up a bit to modify them.
i would suggest to grab some zip ties so you can zip tie your abs lines/sensor onto the tabs on the body so that when you are low your tires dont rub the lines and break them like mine did
Vag Com Scans
#285
only reason i think we might need air tools is due to the design b&g has. there is no way to keep hold the piston if it spins while tightening the top nut on the front strut assembly.there is a chance that they are designed so it doesn't spin, but i won't know until we try it.
#286
Quote, originally posted by 05slvrstonegray1.8t » are you reusing the same bumpstops etc? i had to cut mine up a bit to modify them.
So if I decide to cut the bumpstops on my Konis, you would know enough to keep me from messing them up?
#287
when we put my coils on..(FKs)... air tools were not needed but it would save you lots of troubles... i dunno about B&Gs
#288
Quote, originally posted by vespoli » I'm looking to install my B&Gs tomorrow -- Doug (friedguy) and myself think we've got most of it figured out, but it looks as though air tools might be needed. I know it's a long shot, but does anyone here have tools or access to them? Thanks. Update?
#289
Quote, originally posted by friedguy » only reason i think we might need air tools is due to the design b&g has. there is no way to keep hold the piston if it spins while tightening the top nut on the front strut assembly. there is a chance that they are designed so it doesn't spin, but i won't know until we try it.
yeah i had to use a air gun to remove the top nut on the front struts. Thats my only concern about the B&G's.
Quote, originally posted by str8jakett » So if I decide to cut the bumpstops on my Konis, you would know enough to keep me from messing them up?
Well theres nothing to it really. I just cut a portion off from it to fit into the suspension setup. If you didn't have to then i would probably just leave it at that. Trying to go lower? take out the perch
Vag Com Scans
#290
Middle perch was never installed. I need to remove the spacer and cut the bumpstop to see if it gives a better ride like the VMaxx.
#291
just finished a little while ago... everything pretty much went as expected. we think we need to have someone impact the top nut just to make sure it's tight, but even that may be overkill..he needs spacers though... the front tires are rubbing on struts... pics later.
#292
Yeah -- we finally got them on. One of the struts was a bitch to get apart, but Doug really helped me out a ton today. I would have needed to take it to a shop without himI do rub in the front -- gonna probably pick up a pair of 8mm spacers for the front and 15mm for the back.
Car looks great, the front is low, low; the back is a little higher, but we're going to wait for it to settle a bit and reevaluate.
#293
Saw the pictures on CCVT. Looks good, I'm jealous of the height. Skid plate or any plans for one
#294
Dunno. Gotta fix the tire rub first. I really don't know that I'm interested in a skidplate. I plan on driving it pretty safely. Probably going to put one on after I sacrifice the first oilpan to the car gods![]()
#295
Hah. Sounds good to me. You shouldn't have too much to worry about. I've been low (though not your low) since March of last year and I haven't killed one yet.
#296
Quote, originally posted by vespoli » Dunno. Gotta fix the tire rub first. I really don't know that I'm interested in a skidplate. I plan on driving it pretty safely. Probably going to put one on after I sacrifice the first oilpan to the car gods raise the collar back up so its not hitting your tires until you get spacers to clear it. Forget the skidplate, its not worth it. It will hang lower and hit a lot more things. Ive been slammed for years and still haven't replaced my pan. Subframe has taken hits before but the oil pan is still good.
Vag Com Scans
#297
i guess he'd have to go wayyyy high to not hit. probably have the collar actually above the tire (which may be what you are suggesting). the tire was against the strut assembly before we even put the car on the ground.
#298
yeah exactly what i was suggesting.no point in killing your tires and possibly chipping the inside of the wheel for a couple days while you order the proper spacers to clear.
I just wrote on ccvt but i have a set of generic 5mm spacers you can use to test it out if you guys like. Can even have them for like $10. They are nothing special to look at, just generic 5mm spacers.
Vag Com Scans
#299
is anyone meeting tomorrow?
my car just got out of the shop for tires so im down to meet now that i ACTUALLY have something to show haha
#301
Sorry man, drank too much last night and I'm paying for it today.
#303
i think ive seen your audi around campus a lot last year but not so much this year... with the teckademics stickers right?
#304
That is correct BUT we dismantled the Teckademics name and use only Mischief nowcar looks hellA different from last year!
#305
thats sick... how did you get involved with that crew if you dont mind me asking? i own all the movies and just wondered how like dustin and dado got started
#306
UPS brought me a present.
Still need to glue if I'm going to do it myself. I still prefer to find a professional.
#307
Quote, originally posted by MkIV2.004 » thats sick... how did you get involved with that crew if you dont mind me asking? i own all the movies and just wondered how like dustin and dado got started Of course man. Dustin and Dado met at a car meet actually years ago while Dustin was at his beginnings out of college and Dado was just a newb who had boatloads of talent with his M3 showcar. They decided to start hanging out and film stunts and Dado drifting and it blew up from there when Dustin and Sean (the owner of Pornstar Clothing Co.) started Teckademics. Dado then became the "by default" stunt driver and the DVDs started tearing up Best Buys nationwide.
There was also supposed to be an MTV series modeled after our crew and sadly many people got fired at MTV in 2006-2007 so that project got cancelled without anyone knowing why.
I for one got involved with Teckademics way back in the day when it was just a baby lol Dustin and I hung out with the same people, shared the same passion and so I joined the crew since 2002 (roughly about a year and a half after Teckademics started).
Nowadays we go simply by the name MISCHIEF (the name of the movie series) and have since dropped the name Teckademics for reasons I can't really discuss on the forums...I can tell you in person though and answer any questions you all may have!![]()
#308
I still need someone to help a headliner newb like me install a suede/alcantara headliner!!
#309
I'll help you out, but I'm a newb as well. We need to have an install day sometime. Although I don't have anything to install really. Anybody do the short shifter that goes on the tranny? I installed a Fidanza short throw (B&M copy) when I first got the car, but I've been thinking of buying the B&M and the tranny part as well.
#310
awesome, i seriously need to find some black alcantara around here
that would look real sharp. Dont know what shop would carry something like that
#311
Call Schoolhouse fabrics:Telephone:
Phone: (540) 745-4561Email:
sfabrics@swva.netThey are a three story fabric place in Floyd (20 minutes away). I know last time I was in there I saw suede but don't remember alcantara. I know there are some other guys looking for fabric right now, it wouldn't be a bad cruise if everyone wanted to get together and take a drive up there.
#312
Quote, originally posted by TrboPowr » Of course man. Dustin and Dado met at a car meet actually years ago while Dustin was at his beginnings out of college and Dado was just a newb who had boatloads of talent with his M3 showcar. They decided to start hanging out and film stunts and Dado drifting and it blew up from there when Dustin and Sean (the owner of Pornstar Clothing Co.) started Teckademics. Dado then became the "by default" stunt driver and the DVDs started tearing up Best Buys nationwide.
wow thats crazy... never thought id actually ever talk to anyone from that crew... the original gumball movies and mischief 3000 were the movies that got me into the european car scene
#313
dado is nothing but a rich brat douche.
im a fan of his car and all, but dado himself is![]()
Vag Com Scans
#314
Quote, originally posted by 05slvrstonegray1.8t » dado is nothing but a rich brat douche.
yea i just really like rolling videos of the lambos and whatnot on the rallys... the videos do what they were made to do, entertain
#315
yeah i use to like watching the videos but after dado started coming to meets and acting like a retard it made me lose respect for him and the video.
Vag Com Scans
