    Results 1 to 9 of 9
    Thread: VAG 1598
    1. Member KT54g60's Avatar
      Jul 31st, 2003
      Philadelphia area
      02 GTI VR6, 92 corrado 2.0L lysholm
      07-24-2008 01:40 AM #1
      So does this tool and/or kit still exist? (VW techs look around at work under the senior techs toolbox haha...) if anyone has one, let me know! i'd like to know where to buy one i suppose.
      my power steering is fine thx bye
    2. 07-24-2008 07:49 AM #2
      what is it?
    3. Member MK2TDI's Avatar
      Feb 11th, 2007
      87 Pirelli Coupe 3.0VRT, 96 A6Q, 2000 Jetta VR
      07-24-2008 09:16 AM #3
      Quote, originally posted by KT54g60 »
      first three on the list...
      http://www.florida-tools.com/V...6.asp
      Quoted from slcturbo:
      "I look in the mirror everyday at my face. What other people see is their problem."
    4. Member KT54g60's Avatar
      Jul 31st, 2003
      Philadelphia area
      07-24-2008 03:08 PM #4
      Quote, originally posted by MK2TDI »
      nope, it's not one of those... i don't know if it's 1598A or 1598/14 or 1598/3... so on and so on
      supposedly, it's a tool that was used to set the timing on corrados... properly.
    5. 07-24-2008 04:20 PM #5
      eyeballs and a timing light? its just a matter of lining things up and then following the procedures in the bentley
    6. Member MK2TDI's Avatar
      Feb 11th, 2007
      07-24-2008 07:56 PM #6
      Try here then... every variant of the 1598 test box and various plugs. Basically plugs in in place of the ecu and used to test various functions of the efi system, abs, etc.
      https://erwin.volkswagen.de/wo...5.htm
    7. 07-24-2008 08:02 PM #7
      the ecu can do that itself though. it plugs into the various parts and runs the software you want.
      I thought about building a set of diagnostic chips. each one would force a sensor to behave nominal to determine the failure.
      I have an ecu here that has bad ram or blown dac portion where the ecu thinks the blue cts is always cold. I just coded the ecu to say its always 195F which makes cold starts suck ballz but runs fine otherwise for its purpose.
      Theory was that if you put the chip in and the car acted no different you could rule out that sensor.
      i wanted to make an ecu that held all of the modules but i think that if one person had jacked up wiring they would torch that ecu and then $$ would be lost as ecu's are no longer $50 on ebay/classifieds any more. those were the days.
    8. Member KT54g60's Avatar
      Jul 31st, 2003
      Philadelphia area
      07-24-2008 08:10 PM #8
      yeah, i found that site as well. have to read through it.
    9. Member atoson's Avatar
      Dec 29th, 2002
      San Jose, Ca. South Bay Area
      12 Golf TDI, 00 GTI, 00 NB, 84 Scirocco, 80 Dasher
      12-29-2014 12:23 AM #9
      I know it's an old post but to update on the price $3370.64 and it's out of stock from my source.
      Ignition and injection systems like multi-point injection and Bosch Motronic with miniature contacts (diameter approx. 1.3 mm) can no longer be checked with conventional testers. The following has to be considered:
      - The contacts in the connectors can become damaged.
      - It is difficult to get at connectors and the numbering on the inside is difficult to read.
      - The time spent fault finding on increasingly complex systems must not get out of proportion.
      - For positive fault identification, components such as the Hall sender and knock sensors must be checked dynamically.
      The test box V.A.G 1598A fulfills the demands for a modern and workshop orientated appliance. It can be used with current fault finding systems. The plug sockets on the test box are designed to accommodate the multi-pin connectors of the ignition and injection systems
      All future fault finding programs will be developed and current systems will be gradually converted for use with the test box.
      Design and features
      Test box with impact resistant plastic casing, resistant to fuel and oil.
      Precision CuZn stamped contacts, 0.8 µm range. The rest are gold plated.
      Mounting bracket for storage system V.A.G 1347
      Items supplied
      Test box with 2 m cable, including 9 adapters and plastic case.
      Replacement parts
      Adapter
      V.A.G 1598/1, ASE 401 330 00 000
      Adapter
      V.A.G 1598/2, ASE 401 331 00 000
      Adapter
      V.A.G 1598/3, ASE 401 332 00 000
      Adapter
      V.A.G 1598/4, ASE 401 333 00 000
      Adapter
      V.A.G 1598/5, ASE 401 334 00 000
      Adapter
      V.A.G 1598/6, ASE 401 335 00 000
      Adapter
      V.A.G 1598/7, ASE 401 336 00 000
      Adapter
      V.A.G 1598/9, ASE 401 354 00 000
      Test box (basic version)
      V.A.G 1598/14, ASE 401 337 00 000
      Mounting bracket
      V.A.G 1598/17, ASE 401 267 00 000
      Recommended accessories
      Adapter
      V.A.G 1598/10, ASE 401 355 00 000
      Adapter
      V.A.G 1598/11, ASE 401 356 00 000
      Test Box Kit - 16 Terminal Adapter
      V.A.G 1598/12, ASE 401 357 00 000
      Adapter
      V.A.G 1598/13, ASE 401 339 00 000
      Adapter cable, 68-pin
      V.A.G 1598/18A ASE 441 009 00 000
      Test leads set
      V.A.G 1598/18-1, ASE 401 445 00 000
      Adapter
      V.A.G 1598/19, ASE 401 465 00 000
      Adapter
      V.A.G 1598/20, ASE 401 466 00 000
      Adapter
      V.A.G 1598/21, ASE 401 467 00 000
      Adapter
      V.A.G 1598/22, ASE 401 468 00 000
      Adapter
      V.A.G 1598/23, ASE 401 469 00 000
      Adapter
      V.A.G 1598/24, ASE 401 473 00 000
      Adapter
      V.A.G 1598/25, ASE 401 472 00 000
      Adapter
      V.A.G 1598/26, ASE 401 537 00 000
      Adapter
      V.A.G 1598/27, ASE 401 538 00 000
      Adapter
      V.A.G 1598/29, ASE 401 539 00 0000
      Adapter
      V.A.G 1598/30, ASE 401 540 00 000
      Adapter cable, 121-pin
      V.A.G 1598/31, ASE 441 003 00 000
      Test leads, 1 m
      V.A.G 1598/31-1, ASE 441 004 00 000
      Test leads, 2,5 m
      V.A.G 1598/31-2, ASE 441 005 00 000
      Adapter
      V.A.G 1598/32, ASE 441 002 00 000
      Adapter cable, 47-pin
      V.A.G 1598/33, ASE 441 006 00 000
      Adapter cable, 34-pin
      V.A.G 1598/34L, ASE 441 007 00 000
      V.A.G 1598/34R, ASE 441 008 00 000
      Adapter cable with cover plate
      V.A.G 1598/35; ASE 441 010 00 000
      Cover plate
      V.A.G 1598/35-1; ASE 441 011 00 000
      Adapter cable
      V.A.G 1598/36; ASE 441 012 00 000
      Adapter lead
      V.A.G 1598/37; ASE 441 013 00 000
      Cover plate
      V.A.G 1598/37-1; ASE 441 014 00 000
      Adapter lead
      V.A.G 1598/38; ASE 441 015 00 000
      Adapter lead for Can bus
      V.A.G 1598/39; ASE 441 016 00 000
      Adapter lead
      V.A.G 1598/40; ASE 441 017 00 000
      Adapter lead
      V.A.G 1598/41; ASE 441 018 00 000
      Test box
      V.A.G 1598/42; ASE 441 019 00 000
      Test box, 105-pin
      V.A.G 1598/42-1; ASE 441 076 00 000
      Test lead set 2mm
      V.A.G 1598/42-2, ASE 441 077 00 000
      Test lead set 2/4mm
      V.A.G 1598/42-3, ASE 441 078 00 000
      Earth lead
      V.A.G 1598/42-4, ASE 441 079 00 000
      Adapter lead
      V.A.G 1598/43; ASE 441 020 00 000
      Adapter lead
      V.A.G 1598/44; ASE 441 021 00 000
      Adapter lead
      V.A.G 1598/45; ASE 441 022 00 000
      Adapter lead
      V.A.G 1598/46; ASE 441 023 00 000
      Test adapter
      V.A.G 1598/47; ASE 441 024 00 000
      Test adapter for automatic gearbox 09G
      V.A.G 1598/48; ASE 441 025 00 000
      Test adapter for ABS mark 70
      V.A.G 1598/49; ASE 441 026 00 000
      Test adapter
      V.A.G 1598/50; ASE 441 027 00 000
      Test lead for ESP 8.0
      V.A.G 1598/51; ASE 441 083 00 000
      Test lead for decoupling anti-roll bar
      V.A.G 1598/52; ASE 441 087 00 000
      Test lead for air suspension management
      V.A.G 1598/53, ASE 441 088 00 000
      Test cable for selector lever
      V.A.G 1598/54, ASE 441 091 00 000
      Test cable, electromechanical parking brake
      V.A.G 1598/55, ASE 441 092 00 000
      Test lead for HSD connection
      V.A.G 1598/56, ASE 441 093 00 000
      CAN bus test cable
      V.A.G 1598/57, ASE 441 094 00 000
      Warranty
      24 months
      ASE 401 345 00 000
      Product Specification
      Repair Group 97
      VW Auto Ship Number 000
      AUDI Requirement Minimum
      Availability Available
      AUDI Auto Ship Number 000
      VW Requirement Minimum
      Tool Number VAG1598A
      Substitute By
      Tool Class Test Equip
