VWVortex.com - CEL P0501 Vehicle Speed Sensor Fault?
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 36
    Thread: CEL P0501 Vehicle Speed Sensor Fault?
    1. 07-24-2008 11:01 PM #1
      1997 Passat OBD2 VR6 swap in a mk2.
      16885 P0501
      Vehicle Speed Sensor, Range/Performance
      Replaced the sensor, fault keeps coming back. It has to be wire related. Speedometer has always worked perfectly, along with the odometer. I am sick of seeing this CEL.
      Yes, I searched, but it seems nobody came up with a definite solution to the problem...and I do not have a Bentley for mk3 or Passat. Only have a mk2 and mk4.
      PVW 5/11 Held It Down
      mk2 1.8t ~ mk3 vr6t ~ mk3 vr6 ~ 7p5 3.6exec
    2. 07-24-2008 11:02 PM #2
      DAMNIT....move to the 12v forum please!!!
    3. 07-25-2008 10:01 PM #3
      help
    4. 07-26-2008 01:28 AM #4
      ttt
    5. 07-27-2008 01:00 AM #5
      ttt
    6. Member Benthefrench's Avatar
      Nov 17th, 2007
      San Jose
      Better than yours
      07-29-2008 05:06 PM #6
      up
    7. 07-29-2008 10:43 PM #7
      the speedo, odometer, trip, mpg, mfa all work perfectly. no issues ever.
    8. 07-30-2008 07:42 PM #8
      Swapped in a known working cluster today. Fault still returns. Gotta be a signal wire from the cluster to the ecu for sure.
      just need to locate the wire...without a bentley*
    9. Banned VRsuper6's Avatar
      Jul 8th, 2007
      07-30-2008 08:29 PM #9
      dont want to sound mean, but are you scanning with the motor running?
      you will always get a code for the vss when the engine is off
    10. 07-31-2008 12:12 AM #10
      Quote, originally posted by VRsuper6 »
      Both running and off. Like I said, I clear that only fault code P0501 1 of 1, drive, light comes back on, same fault code.
    11. Banned VRsuper6's Avatar
      Jul 8th, 2007
      07-31-2008 08:30 AM #11
      what harness/cluster combo are you running? i may be able to helo you, but have the mk3 bentley
    12. 07-31-2008 05:52 PM #12
      The whole front of the car is the '97 B4 Passat harness as well as the fuse box and gauge cluster w/ wiring.
      The dash and rear of the car is stock mk2.
    13. 08-01-2008 12:29 AM #13
      Ok, I have some more info from a good friend...just posting this for the record, history.
      Im going to check on this stat!
      8:24 PM 7-31-2008) jackyltardvaark:
      OK so there are two wires you need to check from the ecu to cluster. I am pretty sure one is speed signal, and one is tach. But i am going to tell you both
      (8:27 PM 7-31-2008) jackyltardvaark:
      1st Pin#51 on ecu, is a purple/white wire--It goes to pin#26 on the cluster
      2nd Pin#65 on the ecu is a blue/white wire--- goes to cluster thru fuse box and changes to all white wire---it is pin#7 on the cluster
      thanks troy
    14. Member c25porter's Avatar
      Sep 12th, 2006
      Lynnwood, WA
      1966 Riviera, B5 S4, B5 Passat
      08-02-2008 04:53 PM #14
      From what I read, the engine speed sensor is actually off of the crank just inside the block behind the freewheel. The speed sensor which runs the odometer/ speedometer is on the back of the O2A Transmission.
    15. Member GTIDUBThee's Avatar
      Aug 12th, 2006
      phoenixville pa
      1998 GTI VR6
      08-02-2008 05:30 PM #15
      Clean your throttle body. After that turn your car to the on position and clear the code. Then start her up.
      13.99 @ 101mph 2.24 60ft on street tires
    16. 08-03-2008 12:46 PM #16
      i replaced the throttle body. No change. I think I found the problem though...update this week
    17. 08-04-2008 06:04 PM #17
      Quote, originally posted by GTi2OV »
      This was my problem. I fixed it! Fault is long gone!!
      No more CELs for me
    18. Member
      Feb 21st, 2002
      Grayson, GA
      88 Golf VRT, 04 E500 Wagon, 04 E55, 95 E320 Cabriolet
      11-27-2008 03:11 PM #18
      back from the dead, im havin this same problem , a2 vr swap from mk3 , what if I splice the blue/white wire straight to pin #9 on the cluster??
      -I have continuity from ecu to fusebox (pin 65 to box) and fusebox to cluster (box to pin 9) but they will not talk to each other through the box??
      Can the connection be wrong, it looks like the ecu wire goes to a junction box (blue) that clips to the fusebox , I am lost
    19. Member
      Feb 21st, 2002
      Grayson, GA
      11-27-2008 05:15 PM #19
      fixed
    20. 12-08-2008 05:59 PM #20
      sweet [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. Member
      Oct 27th, 2002
      Fresno Ca
      Current VWs I own...'60 '60 '63 '76 '82 '83 '91 '92 '96 '96 '97 '03
      02-03-2009 01:23 AM #21
      No more CELs for me
      what did you do to fix it???
      @captainsaveadub
    22. 02-15-2009 02:17 PM #22
      Quote, originally posted by 2deepn2dubs »
      read above
    23. Member g6raddo's Avatar
      Sep 16th, 2004
      cypress, TX
      93 corrado slc supercharged
      02-15-2009 03:09 PM #23
      did you splice the bl/wht wire to the cluster?.. cuz if so i'm doing this right now!
    24. 02-21-2009 11:22 AM #24
      i have the same problem with my 1997 jetta GL i replaced one of the sensors. the one with the orange shaft at the end that goes in the transmission
    25. Member Lu VR6's Avatar
      Aug 29th, 2003
      07 V10TDI, 90 VRT, 07 Monster S4RS
      02-25-2009 11:20 PM #25
      was it a loose connection? at the pin?
