    Page 1 of 2 12 LastLast
    Results 1 to 35 of 37
    Thread: Rear Brake Pads Change DIY
      Sep 17th, 2007
      Texas, USA
      07-25-2008 02:55 PM #1
      Following up on my Front Pad Change posted last week...
      1) The rear brakes on the R32 (like many other VWs today) have the emergency handbrake integrated into the brake caliper, and there is a need for the special tool to retract the rear piston without damage.
      Here are pictures of the rear brake on the R32
      2) You will need a 15mm slim fit open end combination wrench to loosen the caliper guide bolts. You can typically find these at a bicycle shop...or try one of your local hardware stores.
      The slim fit wrench is the one that goes inbetween the caliper and the caliper bracket (next to the dust boot)...see pictures
      3) Slide caliper off brake disc and pads after you have removed both upper and lower guide bolts.
      4) This is the special tool you will need to retract the rear piston. You can buy it online from a variety of retailers or you can rent it from Autozone which I did...The correct size attachment plate is the one on the top, 1st right plate from the middle (H014).
      5) Your favorite rear brake pads should be the 1108 shape/pattern. There are no sensors on the rear and this pad shape/pattern is available in a variety of compounds from a few aftermarket manufacturers.
      6) Here is what the stock pads look next to the ones I bought.
      7) Apply a layer of grease (high temp, brake caliper suitable grease only) to the back of the pad where it would contact the piston and on the pad edges where it would contact the caliper bracket.
      8) Using the specical tool, slowly retract the piston back into the caliper.
      9) Place the new pads on the caliper bracket before you slide the caliper back over and onto the brake disc and caliper bracket.
      10) Re-assembly of caliper with new pads onto the caliper bracket is simply the reverse of when you took it off.
      11) A thin coating of anti-seize compound on the hub is a good idea so that you won't have the wheel 'fusing' to the hub after some time.
      12) This would not be a bad time to clean up the wheel (inside and outside).
      13) Finally, torque lug bolts to the required setting (I use 80 ft lbs since I did not know what the factory spec is...I have since been told that the facotry spec is 88 ft lbs).
      Note: Usual disclaimers applies to this DIY, I have attempted to be as detailed as I can, but if you have specific questions, I will be glad to answer based on my experience. Make sure your car is properly supported and secured before you work on it.
      Modified by AsianDude at 1:57 PM 7-25-2008
      Modified by AsianDude at 1:58 PM 7-25-2008
      Modified by AsianDude at 7:16 AM 7-26-2008
    2. Member ZPrime's Avatar
      Mar 7th, 2006
      [216 / 440] Mayfield Heights, OH
      2008 R32 #3603/5000
      07-25-2008 03:28 PM #2
      Rather than "thinly spreading" the anti-seize on the hub, it's a lot easier to use the kind that is a pot with a brush... and just do two or three little blobs between the bolt holes on the hub. The wheel will squish it out and cover where you need. A little bit of rust isn't going to hold it on there anyway, it's only when the whole face is rusted over that they will stick...
      Also, make sure the grease you are using on the pad backs and contact points is HIGH TEMP / brake grease and not just standard anti-seize. You don't want to burn up your grease on a track day.
      Oh, and why use the special caliper tool? Every time I've had to retract a caliper, we just use the old pad pressed up against the face of the caliper, and then a C-clamp around the back. Tighten C-clamp and the caliper retracts. Is this one special somehow, does it twist on the way in or something weird?
      [Forge CAI, BlueFlame catback, DLI mounts, UM software, RNS510+MDI+9W7BT, RacingBrake 4pot, OEM (projector) fogs, other Euro stuff]
      I'm a tech nerd and radar/lidar countermeasure enthusiast. I like track days, autocross, and US Highway 129. I love aural pleasure.
      WitW 2014 || I UM
    3. Member jaydub's Avatar
      Sep 19th, 2000
      Las Vegas, NV
      2011 GTI
      07-25-2008 04:22 PM #3
      I have the same tool, and it does twist as it as it compresses the piston. I know in my Mk4 Jetta, it was required to turn the piston otherwise you could seize it.
      I don't know if it's necessary on the Mk5, I don't even own one.
    4. Member
      Sep 17th, 2007
      Texas, USA
      07-26-2008 08:17 AM #4
      Quote, originally posted by ZPrime »
      It does have to turn to retract...the old push method won't work for the rear...the fronts are ok.
    5. Member Clegg's Avatar
      Mar 1st, 2008
      Denver.
      2012 Touareg TDI, had an 2008 R32
      07-27-2008 11:06 AM #5
      Running Semi-Metalic pads?
      arent you worried about screwing up the finish on your wheels? The dust that comes off Semi-Metalic pads is at like a million f'n degress and when it lands on the wheel it melts into the wheel's paint clear coat.
      I had this happen on another car back in the day... I tried to clean the rim but it never got clean or not as clean as it should.
    6. Member
      Sep 17th, 2007
      Texas, USA
      08-13-2008 07:13 PM #6
      Could not find Ceramic pads for this car...otherwise I would run those
      If you clean your wheels frequently enough...Semi Metallic is ok imo
    7. 08-13-2008 07:17 PM #7
      what comes on the car ceramic or semi metallic?
      EUROMEDIAN your source for all things euro Blog.Video.Stills.News
    8. Member BMP 132's Avatar
      Sep 2nd, 2007
      Vegas Yo!
      Current: '07 RS4 Gone: '08 .:R32, BMP 20th
      08-13-2008 11:42 PM #8
      Quote, originally posted by AsianDude »
      I'm running Hawk ceramics front and rear on my car. Pads are awesome. No dust and excellent bite.
    9. 08-13-2008 11:49 PM #9
      Awesome writeup
      Did you have to open the cap to the brake fluid reservoir before you pushed the caliper in?
      Quote, originally posted by Clegg »
      I think a claybar+light polishing can take care of that no problem.
    10. Member BMP 132's Avatar
      Sep 2nd, 2007
      Vegas Yo!
      08-14-2008 10:23 AM #10
      I can't speak for AD, but when I did my pads I didn't remove the cap. It would probably make it easier though as it was kind of a PITA to retract the pistons. Even with the proper tool. FYI, if you plan on renting the tool from say, Autozone, the price is $35 but you can buy a new one from them for the same amount.
    11. Member
      Sep 17th, 2007
      Texas, USA
      08-14-2008 01:41 PM #11
      Quote, originally posted by justinperkins »
      Yes I did loosen/remove the brake fluid resevoir cap to release pressure (if any) but more importantly so to make sure that the fluid would not overflow when the pistons were retracted from each caliper.
      Sep 17th, 2007
      Texas, USA
      08-14-2008 01:43 PM #12
      Quote, originally posted by BMP 132 »
      Renting the tool from Autozone is free. The $35 plus tax is credited back to your credit card when you return the tool. (at least that is how it worked at the local Autozone for me).
    13. Member BMP 132's Avatar
      Sep 2nd, 2007
      Vegas Yo!
      08-14-2008 01:48 PM #13
      Yeah its probably the same at my local autozone too but they didn't tell me that. I'm glad I did buy it though since I got the wrong rear pads at first. One less trip I had to make.
    14. Member aeproberts21's Avatar
      Apr 10th, 2007
      Rockville, MD
      1998 A4 Quattro
      08-19-2008 09:46 AM #14
      Does the tool work for other cars as well? Just curious if I could re-use it on my wifes honda?
      "Never Drive Faster Than Your Guardian Angel Can Fly"
    15. Member boki-san's Avatar
      Jun 14th, 2003
      '04 R32T . . . . . . . . . . . . . . . . . . . '95 90 Quattro Sport . . . . . . . . '00 Miata LS
      08-19-2008 12:33 PM #15
      Quote, originally posted by aeproberts21 »
      yes.
      90% of that kit is for other cars
      ぼき 母気 boki-san
      the original summit to plummet to summit tripper
      world R32 record holder for high altitude, low altitude, maximum trip altitude delta
      member of usfra bonneville 130mph mile club
    16. Member vr6fanatic's Avatar
      Apr 4th, 2003
      Mass
      2004 VW R32
      08-19-2008 12:56 PM #16
      I have the same brake tool kit, and I have used it on my R and my brother's 91 Toyota Supra and my other brother's 94 Toyota Celica.
      Laz
      Many people enjoy eating apples and oranges, but in the end they are still… just apples and oranges. The R32 is passion fruit. . Live Long and Prosper.
    17. Member aeproberts21's Avatar
      Apr 10th, 2007
      Rockville, MD
      1998 A4 Quattro
      08-25-2008 09:53 AM #17
      I am doing this install this week. I noticed that there are no torque specs on the instructions.
      Anyone know how tight I need to make the guide bolts?
    18. Member aeproberts21's Avatar
      Apr 10th, 2007
      Rockville, MD
      1998 A4 Quattro
      08-28-2008 12:26 PM #18
      So I just got back from Advanced Auto Parts. They didn't have the specialty tool that was mentioned in the DIY. They instead told me this part would work with a normal 3/8 ratchet. The package says it works with most european cars. Will it actually work for the rear brakes?
    19. Member
      Sep 17th, 2007
      Texas, USA
      08-28-2008 02:33 PM #19
      This tool does not work (I've got one sitting in my toolbox)
      You need the set (or similar) shown above in my pics
    20. Member
      Sep 17th, 2007
      Texas, USA
      08-28-2008 02:34 PM #20
      I never found out what the torque specs are for any of the bolts.
      But I would venture to say that the caliper guide bolts are no more than 10-12ft lbs
    21. Junior Member
      Dec 13th, 2008
      Chicago, Burbs
      '12 jetta se
      12-13-2008 10:25 PM #21
      I have found a rear brake caliper kit that looks just like the one in the picture at harbor freight.......I paid around $20 for it.....
    22. 02-07-2009 12:18 PM #22
      You MUST replace the caliper bolts. They are TTY bolts & the torque spec is 35 Nm (26 ft-lb). USE A TORQUE WRENCH.
      The factory wheel torque is 120 Nm (90 ft-lb).
    23. Member
      Dec 12th, 2001
      Monmouth County NJ
      2006.5 / VW / MKV GTI
      05-02-2009 08:39 AM #23
      Or would all 15mm box wrenches be considered slim ?
      2006.5 MKV Pkg1 / Provide VAG-COM support
      Monmouth County NJ
      http://www.philipsautolighting.com/popup_bulbfinder.asp
    24. Former Advertiser
      Aug 21st, 2008
      San Antonio TX
      91 Porsche 964 C4 Cabriolet / 92 Porsche 964 C2
      05-03-2009 01:11 AM #24
      the second best thing comes in tube after hair gel
    25. Member f.rizzo's Avatar
      Jun 29th, 2008
      Los Angeles
      CLK 550
      05-07-2009 12:57 AM #25
      Another option for the brake reset tool:
      http://www.metalnerd.com/cat08.htm
      Works on the front and the rear and comes with the thin 15mm wrench.
      FYI...
      Modified by f.rizzo at 10:01 PM 5-6-2009
      Previous: 2011 CC VR6/4mo, 2008 R32. Hers: 2006 Beetle 'vert, Pkg 2. MK4 GLX VR6 Jetta
    26. 08-07-2009 03:21 PM #26
      Thanks for an awesome DIY. Do you have to bleed the brake lines after doing the installation? Also, is there a risk of overflow even if the reservoir is open?
      Modified by deepclue at 12:41 PM 8-8-2009
    27. Member
      Sep 17th, 2007
      Texas, USA
      08-08-2009 11:04 AM #27
      You should always bleed out some fluid after the install just to make sure that no air got trapped towards the end of the brake line when you retracted the pistons.
      If no fluid was topped up during the life of the car, then you should not have an overflow situation when the caliper pistons are retracted.
      Good Luck!!!
      Modified by AsianDude at 10:05 AM 8-8-2009
    28. Junior Member
      Jan 9th, 2011
      Central PA
      2007 Fahrenheit GLI
      05-03-2011 02:47 PM #28
      what direction do you need to spin the rear piston to retract it?
    29. Member Ikey3125's Avatar
      Jan 27th, 2008
      Fairchild AFB/Spokane WA
      08 .:R 2763/5000
      05-03-2011 03:21 PM #29
      Quote Originally Posted by bulldawg79 View Post
      Clockwise
    30. Member urshur's Avatar
      Jan 24th, 2009
      So Cal
      '08 R
      05-04-2011 06:39 PM #30
      i literally JUST did this at my friends house, rented the kit from Autozone for $60 and returned it and got my money back.
      BTW......DAMN your brakes are CLEAN lol i cleaned mine a little since it was the perfect oppurtunity
      but nowhere near that clean
    31. Member Voyles's Avatar
      Jun 1st, 2008
      Detroit
      MKV .:R32
      05-04-2011 08:06 PM #31
      Don't have to have a slim 15mm wrench. I used a set of needle nose pliers to hold the nut until i could get a regular 15mm wrench in there.
      BTW ... super clean rotors man.
    32. 05-04-2011 08:36 PM #32
      This is good stuff Mod please sticky it.
    33. Junior Member
      Jan 9th, 2011
      Central PA
      2007 Fahrenheit GLI
      05-07-2011 05:01 PM #33
      this was super easy to do. i was able to make due using the front brake tool and a pair of channel pliers so i didnt have to rent the brake kit from a local auto store.
      http://www.ecstuning.com/Search/Brake_Tool/ES8211/
    34. 05-08-2011 10:34 AM #34
      WOuld you happen to know the size of the tool, H014?
    35. Banned BetaOp9's Avatar
      May 4th, 2006
      2008 VW R32 [TR #2392]
      05-08-2011 12:42 PM #35
      I don't see why not to rent it, it's free.
      ¤ Posted via Tapatalk on my G2 ¤
