VWVortex.com - Official Displacement Increasing Thread
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 64
    Thread: Official Displacement Increasing Thread
    1. Member crazyass713's Avatar
      Dec 27th, 2006
      01 Golf mid-enine 2.7T Twincharged, 04 B6 USP 2.0T built
      08-03-2008 08:13 PM #1
      This is the official thread for increasing the displacements in both the 058 and 06A blocks. After reading numerous posts about overbores and/or increasing stroke, I decided vortex could use a thread on the matter for new members and current members wishing to learn about the subject. This is my attempt to help out the forum on this matter
      To answer the question, “should I go stroker or not?” it’s different for everybody. In my motor, I was going to drop in rods and call it a day. After disassembling my motor, I checked wall to piston clearance and I measured .004” which is too much. So I had to overbore. Since I was buying pistons and rods, I decided to just buy a crank at the same time. If you buy overbore pistons and later decide to stroke your motor, you will have to buy pistons again, which I was wanting to do so I did it all in one shot. Another thing that made me think about doing pistons from the beginning was that I wanted to lower the compression ratio so I could run higher boost on pump gas. Basically, if you are replacing your pistons and rods, you should go stroker.
      First, you need to know which block you have in order to determine what course of action you need to take.
      Here is how you can tell if you have an 058: you have an engine coded AEB or ATW, you have an external water pump, you have an intermediate shaft (IM shaft) for the oil pump, and you are drive by cable, ect…
      Here is how you can tell if you have an 06A: you have an engine coded AWM, AWD, AWW, AWP, AMB, ATC, AJQ, APX, AUG, APP, ARY, AUQ, AMU, BAM, BEA, APH or AWV you have an internal water pump, you have no IM shaft, and you are drive by wire, ect…
      Displacements are as follows:
      81mm bore x 86.4mm stroke = 1781cc (stock)
      81.5mm bore x 86.4mm stroke = 1803cc
      82mm bore x 86.4mm stroke = 1825cc
      82.5mm bore x 86.4mm stroke = 1848cc
      83mm bore x 86.4mm stroke = 1870cc
      83.5mm bore x 86.4mm stroke = 1893cc
      Now when you add a 92.8mm stroke crank to you engine you have the following displacements:
      81mm bore x 92.8 mm stroke = 1913cc
      81.5mm bore x 92.8mm stroke = 1937cc
      82mm bore x 92.8mm stroke = 1961cc
      82.5mm bore x 92.8mm stroke = 1985cc
      83mm bore x 92.8mm stroke = 2009cc
      83.5mm bore x 92.8mm stroke = 2033cc
      I will not go into the 95.5mm crank from the TDI as I do not know enough to accurately inform people about making it work in either the 06A or 059 blocks.
      I will start with the 058 block. Stock bore is 81mm, pistons are generally offered in .5mm increments over stock, there are some exceptions. JE, Mahle, Wiseco, CP, and Supertech are the popular choices, not to say the only ones that are good. For rods, you use stock length (144mm). Scat, Pauter, IE and Carillo are the popular choices, again, not the only ones that are good.
      For using a stock crank, the process is pretty straight forward. You tear down the motor and bore the cylinders. Install is the reversal but with the exceptions of putting the new slugs in.
      For stroking the motor, the process is much more involved. You need pistons with a lower deck height due to the increase of stroke. The same rod dimensions are used and if the stock height pistons were used, the pistons would travel 3.2mm too high and impact the valves. Not good as you can imagine. So custom pistons will be needed and they are readily available for order because luckily for us, others have been doing this and the design has already been done. Which crank do you use? Well since you are 058 you must use an ABA crank from a MK3 Volkswagen. Pre OBD2 cranks are forged, post are cast. Chances are you won’t be coming anywhere NEAR breaking either unless you are going to max out a 35R or beyond. Now for the installation of the whole setup… A couple things will need to be done to make clearance for the rods due to the larger stroke of the crank. #1 The block will need to be grinded away by about 1.5-2mm on the side of the block away from the IM shaft. Cylinder 3 has a hump that the rest do not and that will need to be ground a bit more. The rods will actually clear without any grinding, but you should have at least .100” clearance in my opinion. #2 The cylinder 4 oil squirter will need to be moved away from the piston using a copper o-ring between the block and the squirter. You will also need to grind the corner closest to the back of the motor and closest to the cylinder. #3 The IM shaft will need to be modified. The gear will need to be machined down to a thinner size. The amount needed to be removed depends on the type of rods you use, mind you only a little bit, but it does matter.
      For the 058 you will NEED the following to reassemble your motor:
      Crank bearings
      Main Bearings
      Main Bolts
      Head bolts
      Flywheel bolts
      Rear main seal
      IM shaft seal
      Headgasket (if you are going past 82mm bore a head gasket from an ALT will be needed)
      Oil pan gasket
      Front seal
      Valve cover gasket set
      You SHOULD do the following things as well:
      Oil pump
      Timing Belt
      Rollers and tensioners
      Serpentine belt
      Water Pump
      Thermostat
      Now on to the 06A block things are a bit easier for a stroker. The same applies for the stock stroke builds, just bore and put in new pistons. The reason the stroker crank is easier to run is because nothing has to be clearenced. Just install your new rods, pistons and crank and you are good to go. You have several options for crankshafts. For drop in solutions you have the AZG and AEG cranks. The AEG and AZG are from MK4 2.0’s and are cast in construction. The other options are ALT and BPV which are from a B6 2.0 FSI found in Europe. They have the wrong oil pump gear and need to be modified to be used in this application. The ALT is cast and the BPV forged. If you have the correct oil pump gear pressed on, the ALT and BPV can be used just like the AZG and AEG, just drop in and go.
      For the 06A you will NEED the following to reassemble your motor:
      Crank bearings
      Main Bearings
      Main Bolts
      Head bolts
      Flywheel bolts
      Rear main seal
      Oil pan silicone sealant
      Front seal
      Oil pump
      Timing Belt
      Serpentine belt
      Water Pump
      Thermostat
      Now for the credits:
      Issam Abed (wizard-of-od) for providing me with every possible crank option there is lol [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Paul Calado (killa) for convincing me to go stroker with his write up [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      The original guys in this scene who pioneered the stroker stuff for us [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      And all the others I’ve probably missed [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Also here are some pictures from when I went to 2008cc on my 058 blocked A4 (and one from killa), this will give you 058 block guys some idea of what it’ll take to fit that ABA crank in there:
      2001 Golf mid-engine RWD Allroad 01E 2.7T TVS1320 BW S374 twincharged (long title, I know)
      2004 A4 Ultrasport 2.0T 3076R built to the hilt all the way around (daily sleeper status)
    2. 08-03-2008 08:19 PM #2
      Or you could buy my 2.0fsi crank lol... sorry i just had to and btw nice thread!
    3. Member crazyass713's Avatar
      Dec 27th, 2006
      08-03-2008 08:31 PM #3
      Quote, originally posted by slow85golf »
      with the correct oil gear pressed on of course
    4. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      2003 TTq coupe, 2005 Outback XT, 2014 Soul!, 2004 A6 3.0
      08-03-2008 09:35 PM #4
      Is the FSI crank cast or forged? Also, do you have the part numbers for the cranks you mentioned, specfically the ALT and BPV? How easy is it to get these Euro cranks?
      Audi TT FAQ --- Maintenance, Misfires, and a XT Spec-B swap --- Great Lakes TCL Registry
      Quote Originally Posted by LG6R View Post
      The Lincoln was like floating down a river made of flowing chocolate; the Buick was like riding a drunk horse up a cobblestone hill.
    5. Member crazyass713's Avatar
      Dec 27th, 2006
      08-03-2008 09:53 PM #5
      Quote, originally posted by l88m22vette »
      FSI is forged... I dont have any parts numbers or access to the european cranks but shoot a pm to user INA on here, Im sure he can help you [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    6. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2008 12:32 AM #6
      Excellent write up Jacob [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      However forget the ALT.
      p.s. I have yet to see a failed oil pump on these engines.
      Modified by Wizard-of-OD at 12:33 AM 8-4-2008
    7. 08-04-2008 12:52 AM #7
      Agreed on the failed oil pump. And I had to clearance the oil squirters for my FSI crank and 83mm Wiseco's. Pics to come shortly.
    8. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      08-04-2008 12:53 AM #8
      So, does it really matter whether or not you use a forged crank? I've read about cast 1.8t cranks holding 500hp...Also, wanted to include a parts link - $608 for an FSI (2.0T A3) crank. That plus $350 for rods? $1100 seems like a good price for a 2.0. I wonder how my K04 would handle it...could I theoretically build my engine to 2.0 and use the stock ECU, or would I need to get it tuned?
      Modified by l88m22vette at 11:54 PM 8-3-2008
    9. Member crazyass713's Avatar
      Dec 27th, 2006
      08-04-2008 07:04 AM #9
      Quote, originally posted by Wizard-of-OD »
      thanks for your help
      Quote, originally posted by Adam@Unitronic.ca »
      Nice, that would be cool if you could contribute Adam [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member crazyass713's Avatar
      Dec 27th, 2006
      08-04-2008 07:05 AM #10
      Doesnt really matter unless you are going for the moon, and you mention K04 in your post
    11. 08-04-2008 08:44 AM #11
      That's $950, then you still need the custom pistons. You can't get it done for $1100, plus you still have to buy the new oil pump gear. I got lucky and got my crank over a year ago on ebay for $200. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member l88m22vette's Avatar
      Mar 1st, 2006
      Chicagoland, IL
      08-04-2008 09:05 AM #12
      Ok, thanks for the info guys...I saw QED has Supertechs for $600, and that would be on top of rods, so yea, $1100 isn't going to do it. I'm definetly interested to see the squirter clearancing Adam.
    13. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      08-04-2008 09:15 AM #13
      Who makes an 83.5 slug for the 86.4 stroke?
    14. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2008 09:18 AM #14
      You had to clearance your pistons for the squirters,not the crank...
      Its a direct fit in all 06A/06B blocks.
      Quote, originally posted by 20aeman »
      We do (INA).Send me a PM on that account
    15. 08-04-2008 09:23 AM #15
      No, I didn't touch my pistons or the crank. I clearanced the squirters, just like I said. JE, Wiseco, lots of people make overbore pistons for stock stroke.
    16. 08-04-2008 11:33 AM #16
      Ill be the first one to say PLEASE CLEARANCE THE SQUIRTERS!! Even the 06A blocks need clearanced since mine hit, among another member. As for the crank, Autoxtreme's drag car is running over 600whp and running a cast crank w/o issues
    17. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2008 10:01 PM #17
      You DO NOT NEED to clearance the squirters,leave them alone.Purchase pistons with the skirts clearanced allready.
    18. 08-04-2008 10:10 PM #18
      So is that a "do not buy wiseco" post? My wisecos hit, Garry's hit all 4 and Adam's would of hit if he ran it. Guess i should of stated Wiseco
      Also i didnt see if it was posted, but the NA 20v gasket is thinner and will increase the c/r some
      Modified by cincyTT at 9:11 PM 8-4-2008
    19. Member 20thAEGti1009's Avatar
      Jan 27th, 2005
      Martinsburg, WV
      2001 Audi A4 (Daily) 20th Anniverary GTi 1984 GTi (20vt) 2004 Chevy 3500 Crew Cab DRW (Tow Rig)
      08-04-2008 10:11 PM #19
      x2
      i have never had to clearance any of my oil squirters and i have run both JE's and now am running the Supertech's from bobq all with no clearance issues at all
      1984 GTi 50 Trim 20v swap on Maestro
    20. 08-04-2008 10:13 PM #20
      Nothing like telling people not to do something when others have had horror stories
    21. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2008 10:24 PM #21
      Quote, originally posted by cincyTT »
      Nathan,
      It really depends on your piston manufacturer.
      The crankshaft counter weights clearance the oil squirters fine...even up to 95.5mm stroke.
    22. 08-04-2008 10:33 PM #22
      I guess my #3 squirter got scared and just jumped in the oil pan then.
      Im just stating that telling people to not to bother with checking and spacing the squirters is going to bite someone in the ass (i already stated 3 that did get bit). With me being one of them, i know its not a fun experiece driving home with a squirter working its way down to the oil pan
    23. Member
      Nov 26th, 2000
      New Jersey
      A2 GTI,B5A4,B6A4, 2.7t
      08-04-2008 10:35 PM #23
      Quote, originally posted by crazyass713 »
      All I see is your using my pic without asking for it.
      Expect to hear from my lawyer
    24. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2008 10:37 PM #24
      Rotating your engine by hand before cranking it WILL bite you in the ass.No question about it BUT considering all your oil squirters sit on the same plane,I would say that you had an ugly duck for a #3 piston
    25. 08-04-2008 10:40 PM #25
      That one was replaced and all the others got spaced out, basically what Adam is doing now with his wiseco pistons
