VWVortex.com - AutoX project: Input is appreciated :)
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 53
    Thread: AutoX project: Input is appreciated :)
    1. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      97GTIVR6 08JETTA2.0T 99F250P/S
      08-04-2008 01:30 PM #1
      Started seriously looking into getting my Rabbit GTI into a great autoX car.
      The mods started last week when I found out my interior carpet was shot. I was excited when I thought I lost "some weight" After looking at it more in depth, I've decied to go all out with it.
      I purchased some dupli-color truck bedliner and covered my floor boards with it to protect against rust. removed almost every interior panel except door cards ( for now) , sound insulation and removed bumpers,
      It started out weighing 1980lbs. I weighed at the DOT station. After removing everything I could inside and the bumpers, the Rabbit has lost at least 200lbs.
      I weighed it on the same scale. Plans include New tires for autoXing only, lightweight batt. remove brake booster, small roll-cage, removing some more sound insulation from the spare tire well.
      With a special thanks to Scott (sandman126) for getting me the new recaros out of a MKII GTI
      P4C (sorry, car is dirty from all the rain)
      Out with the old blue seats...in with the new (used)
    2. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-04-2008 01:31 PM #2
      Back from the dead.
      Today:
      Replaced the trans with a Scirocco trans
      16V (made for a 16 valve vw GTI) pressure plate
      16V clutch disc
      All new mounting hardways
      new gear lube
      New axles
      fabricating some unibody braces
      Pix from what I pulled out today:
      Blew apart the clutch, Ruined the pressure plate and retaining clip. All has been replaced.
    3. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-04-2008 01:32 PM #3
      Back up top.
      I added a few extra goodies to the car. Installed a unibody support brace under the front of the car that ties the control arms together.( I dont have pix of that) I also fabricated myself a rear upper strut tower brace from 1X1 square tubing (12G) I designed it myself and built it in about an hour. Best advantage about this latest mod is I can remove it. 8 "grade 8" bolts hold it in place!!! Thanks for looking.
    4. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-04-2008 01:33 PM #4
      This thread will never stop...
      Received my Hoosiers on Saturday. Installing new wheelbearings. Got some 14" wheels for next season at the junk yard. I have pixd my front lower uni-body stress bar that was fab'd by my friend Dan and scott.. The ABA bottom end swap that I have planned for winter. That swap will put Tork around 150 ft/lbs (up from 105 ft/lbs now)
      A local parts store sold me the wrong axle when I was replacing mine b4 williston event. This was the result of the improper cv end...
      Oh and a pix of my dog, Lola
    5. Banned
      Mar 30th, 2002
      08-04-2008 01:47 PM #5
      ground controls an bilstein sports.
      do some reading an research on the different setup options you have for that car there are a ton of threads discussing this on this site
    6. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-04-2008 01:53 PM #6
      I have blisteins struts and springs on all 4 corners.
    7. Banned
      Mar 30th, 2002
      08-04-2008 01:55 PM #7
      sell the springs asap. you want to get some real spring rate under that thing
      ground controls come with whatever spring rate you want. like i said, read up on setting up these cars, there are two ways an both work very well, but neither use generic lowering springs (which is what you have now) [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Member Martinus's Avatar
      Oct 24th, 2002
      '84 GTi, '97 Jetta, '05 WRX wagon, '11 Frontier.
      08-04-2008 08:32 PM #8
      Gutted, lightened, triangulated ... no bumpers, AND a block thats a decade newer then the car.
      Hmmm... Your gonna need, way "more tire" for D Mod ! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Might as well, loose the doors, fenders, hood, hatch, all lights, glass etc. completely.
      Modified by Martinus at 8:36 PM 8-4-2008
    9. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-04-2008 09:29 PM #9
      Quote, originally posted by Martinus »
      I was hoping that 225/45/15 hoosiers were enough
    10. Member Martinus's Avatar
      Oct 24th, 2002
      08-04-2008 11:00 PM #10
      Quote, originally posted by gtiguy1994 »
      I thought, you said 14's ???
      ... but no.
      *edit*
      ... well, maybe for the rear.
      Modified by Martinus at 11:01 PM 8-4-2008
    11. Member Martinus's Avatar
      Oct 24th, 2002
      08-06-2008 03:05 AM #11
      I do belive, THE reason ( to stay the eff out of DM ) is on page 56 in the October 2008 GRM. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ... its EP without the 2.0L.
    12. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-06-2008 07:21 AM #12
      I will have to read up on this then. Thank you. Im there for raw times anyways...Its fun posting better times than STI
    13. 08-06-2008 08:38 AM #13
      I haven't received my issue yet, who is on page 56? Mark's Lotus?
    14. Member Martinus's Avatar
      Oct 24th, 2002
      08-06-2008 12:30 PM #14
      Its worth the wait ... the OP "safe" , looks like he got bumped to BM, tho.
    15. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-06-2008 01:59 PM #15
      The region I race in is very small...they rarely take the time to figure out the class we are running in. if they cant figure it out. they put us in "unknown class"
    16. Member EvanBoyle's Avatar
      Nov 23rd, 2003
      San Jose, CA
      '92 Jetta GLI, '03 Passat Wagon, '10 A3
      08-07-2008 03:54 PM #16
      id give Shine Racing a call for spring / shock advice. their website is http://www.srsvw.com . the phone number for the shop is 508-660-7974
    17. Member magicninja's Avatar
      Sep 30th, 2007
      Rodeo, CA
      94 325is, 94 4wd Toyota Pickup
      08-10-2008 05:17 PM #17
      That rear brace bolts in where the rear bumper support bolted right ? Nice ingenuity on that one ! [IMG]http://*****************.com/smile/emthup.gif[/IMG] :
    18. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-10-2008 06:43 PM #18
      Yes, I wanted to make the rear brace removable. Which it is. The top of the brace bolts in where the the rear lateches in. easy in and easy out.
      Thanks.
    19. Semi-n00b
      Aug 18th, 2008
      1995 e36 M3 coupe (STU), 2004 Mini Cooper S (F Prepared), 1987 16vGTI (ST), 1992 16v Passat (FSP)
      08-20-2008 07:20 PM #19
      looks like a great project. definantley will be in EP.
      the stiffening you've done is first class.
      to be competitive in EP you should exploit every section of the rules. i.e lexan windows, delete all unneeded parts.
      other cars will be as light and likely built for racing too.
      considerthe following upgrades:
      aggrsive cam, pretty crucial for Prepared
      alternative trottle body,
      lighten and balance crank, if you've got the tools.
      light flywheel,
      peloquin atb lsd, or clutch plate lsd: essential 2 put the power down.
      polyurethane or aluminum engine mounts (black forest industries)
      larger slotted/ cross drilled rotors
      the 15" sub zeros should fit over larger rotors. and you will have plenty of torque running 225/50/15's.
      p.s. keep those hoosiers warm and wrapped up until your ready to use them.
      best of luck
    20. Semi-n00b
      Aug 18th, 2008
      08-20-2008 07:22 PM #20
      oh and definantly coilovers. spax are reasonable abbout $800 for the complete setup.
      and after your corner weights are balance across the diagonals, adjust your brake proportioning valve.
    21. Member BoiseMK1GTI's Avatar
      Jan 27th, 2004
      Boise, ID
      '58 OG Paint PG/SG Microbus, '60 Fjord Blue Bug
      08-20-2008 08:33 PM #21
      If you are serious about running EP, you will want to run the car completely gutted with lexan everything, and you will need to run 13's with some Hoosier or Goodyear full slicks, instead of r-comps. Hoosiers are stickier quicker, but the goodyears last longer.
      Looks like a good start though.
      '60 Fjord Blue Bug slammed daily driver
      '58 OG paint PG/SG VW Standard Microbus
      David Kvapil Photography
    22. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-20-2008 09:45 PM #22
      Thank you both for your input. I will update this thread as work progresses
    23. Member xxxfattonyxxx's Avatar
      Oct 25th, 2003
      Idaho Falls, ID
      94 Passat Wagon, 81 Caddy
      08-21-2008 06:27 PM #23
      Holy ****, I was scrolling down and thought "why the **** is my dog on here?" no joke thought it was my dog
      http://oldskoolvw.com/ Custom MK1 parts
    24. Member Martinus's Avatar
      Oct 24th, 2002
      08-21-2008 10:32 PM #24
      LOL. Who recomended the, "off-the-shelf" Spax, for THIS project ? ( ) ... not the same guy, recommending all the illegal ( for EP ) engine mods. Is it ?
      Yeah, you obviously done this before ...
      Modified by Martinus at 10:38 PM 8-21-2008
    25. Member gtiguy1994's Avatar
      Jan 2nd, 2003
      Minot, ND
      08-22-2008 07:53 AM #25
      LOL. 20mm spacers will be in today.
