VWVortex.com - Fair price to replace thermostat on a 1.8t?
    Results 1 to 10 of 10
    Thread: Fair price to replace thermostat on a 1.8t?
    1. 08-04-2008 06:03 PM #1
      Dealer is quoting me $285 to replace the thermostat on my 2003 Passat wagon with 1.8t motor. Looks like the thermostat lists for $28 and can be bought for $15 on line. Any reason I should pay another $250 for labor?
      Thanks,
      Jim
    2. Member vdubb3dan's Avatar
      Apr 7th, 2004
      Scranton PA
      Bagged B5.5 1.8T/81 rabbit diesel/tons of B3's
      08-04-2008 07:04 PM #2
      Are you even somewhat mechanicly inclined? If so this is a fairly simple job, and can be done in less than an hour. Just remember you'll need some coolant too, because you will lose some once you remove the old housing.
    3. 08-05-2008 12:21 AM #3
      This is the RIGHT way to go about dealing with these people!
      http://en.allexperts.com/q/Vol...g.htm
      This is with a 1.8T jetta though it should be the same for a passat 1.8T the location and procedure seems like something even I wouldn't want to tackle as a seasoned DIYer although it is the thing you'd need to replace to get the stealer the most money!
      http://www.volkswagentalk.com/....html
    4. Senior Member vdubspeed's Avatar
      Jul 18th, 2002
      Valdosta, GA
      I quit counting.
      08-05-2008 03:08 AM #4
      Quote, originally posted by JimMartin »
      Thanks,
      Jim
      because people in the past have payed that much and they figure they can get more people too?
      I don't know but it's actually laughable they would charge that much.
      Built > Bought
      58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
    5. Member Donuts's Avatar
      Feb 23rd, 2000
      Norwalk, CT
      '06 225 TTQ - Papaya/Grey
      08-05-2008 08:06 AM #5
      It is a fairly labor intensive effort. I'd bet book time of two hours minimum.
      http://www.passatworld.com/for...66611
    6. 08-05-2008 09:07 AM #6
      Agree...it's funny how most folks think the labor is the same for a Passat as it is for Jetta. The motor is longitudinal vs. lateral, makes so much difference on most engine parts. Especially timing belt jobs - a real treat on a Passat vs. Jetta.
    7. 08-05-2008 04:45 PM #7
      Quote, originally posted by Donuts »
      Book rate on a TSTAT for a 1.8T AUG engine is 2.6 hours. I got them to do it for half that in conjunction with the full timing belt experience, but according to the mech there is no real overlap in labor. Apparently varies significantly based on engine code, as some earlier 1.8T owners have said they replaced theirs in 20 minutes. On mine, they had to remove the alternator.
    8. 08-08-2008 10:50 AM #8
      Here is a writeup I did for replacing my thermostat on my 2002 1.8t. it was pretty easy and yes you do need to buy coolant. It took me about 30 minutes and I did not have to remove the alternator.
      http://www.passatworld.com/for...50868
    9. 08-09-2008 09:11 PM #9
      Quote, originally posted by King Gordon »
      Cool - makes me wonder why the book rate on tstat replacement on the AUG engine is 2.6 hours. I saw it with my own eyes. But like I said, he did it for half that (1.3 hours) which isn't too terrible I guess. The mech did remark it was a real PITA on my engine.
    10. 10-07-2008 01:31 PM #10
      Ugh
      I am about to leave for the stealership. They replaced the T sensor under warranty, but the CEL is back on for the same reason.
      I am going to see if they effed up the T sensor installation, but fear they will say Tstat!
      Trying to decide to just Not go and replace Tstat and see if all is well after that.
