VWVortex.com - Cabriolet Fender Flare Rehab
    Results 1 to 13 of 13
    Thread: Cabriolet Fender Flare Rehab
    1. Member montmil's Avatar
      Jul 8th, 2006
      Denton, TEXAS
      1986 Cabriolet WE
      08-10-2008 03:57 PM #1
      The factory paint on the plastic fender flares of my 1986 Cabriolet had deteriorated to the point that all four had flaking and cracking of the original paint. The damage was primarily on the upper portion of each wheel arch. That's the area that has been exposed to 23 years of often blazing hot Texas weather. Pretty sad looking. Time for a Cabriolet rehab to match the fresh, new top.
      Sheet metal screws and washers hold each flare in place and are easily removed. Bag them so you don’t misplace them. Expect to find some silty dirt packed inside the lower 6-8 inches of the flare’s interior. Some cars may have an adhesive seal between the car body and the flare. Mine did not.
      Clean out the agricultural samples with a strong water jet. Perhaps use a small, stiff brush and something like Simple Green. Remove any tar or road oils from the components using mineral spirits and a rag. Do not paint over dirt and grease. The paint does not stick well, nor very long, to these materials.
      I began the paint prep work by wet sanding the flares with 3M 220 grit Wet-or-Dry paper. This is the most time consuming part of the entire job. Initially, I was sanding clear coat. You will know when you have worked down to the paint when the swarf (sanding debris) is paint-colored rather than the milky look of the clear coat.
      The area on the top of each flare was where I had the most damage. It was necessary to sand down to the base substrate black plastic in the serious areas. Blend the sanding to create a smooth transition between plastic and any solidly anchored paint. If the paint is still smooth and well bonded to the plastic, sanding prep is all you need. Not necessary to remove all the color.
      When you feel like the flare looks good, sand some more. It’s really difficult and depressing to have to go back and begin again after you’ve shot primer and discovered the not-so-smooth sanding prep. Solid work in preparation will mean far less time required for color finish.
      Rinse the parts thoroughly. After drying, give the parts a quick wipe down using lacquer thinner. Do not spend too much time with the lacquer thinner on the primer as it may begin to soften. Avoid oily fingerprints and any toweling that may be contaminated with oils or a silicone product. You do not want to deal with fish eyes. Tack rags are good but watch for bits of thread.
      I chose to prime the flares using a rattle-can. The flares are small enough that setting up a paint sprayer just for primer may not be worth the trouble. Stop by an auto body supply and buy some quality primer. SEM is a brand that I have had good experiences with. For the plastic flares, I selected SEM’s #39133; a flexible primer-surfacer designed for automotive plastics. Perfect, but pricey.
      Apply several medium-wet coats rather than one heavy coat. Allow 5-10 minutes drying time between coats. After about an hour, depending on temperature and paint film build thickness, the product can be wet sanded.
      3m 320 grade Wet-or-Dry, used wet, smoothed the primer and did a good job of blending the surface areas. A little bit of sanding through the primer is not a bad thing. Simply finish the initial sanding and shoot a little more primer. Repeat with the 320 paper.
      Wet sanding is the preferred way to sand down primer and paint. Use lots of water to keep the surface flushed clean of sanding debris. By wet sanding, your paper will remain clog free and the job will go faster with better results. A five-gallon bucket of water and a squirt bottle are all you need. Rinse the part and paper often.
      Keep in mind that sandpaper will wear out. When it quits cutting well, replace it. Using worn out sandpaper will only add unnecessary time to the job plus you’re just polishing the high spots. This is false economy.
      Body shop suppliers offer many varieties of sanding blocks. A hand-sized hard rubber block works quite well on flat surfaces but the fender flares seem to be lacking many flat areas. There’s a flexible sanding pad, too. A dense gray foam pad backed by a harder black rubber. This pad is able to conform to subtle curves. It became my preferred weapon.
      Each of us has different levels of patience and only so much sanding capability within. Sanding burn-out occurs when you say to yourself, “That’s it! Good enough.” Perhaps it is, or maybe not. Good materials will help you do better work faster. The final paint will tell all.
      Examine your primer work closely. Low spots, usually very small and not easily seen, will show up under close scrutiny as slightly darker specks or scratches. This occurs because the defects are below the surface of the recently sanded primer which now has a lighter color.
      You have a couple options on taking care of the small flaws; keep sanding -not a bad idea- or apply a very thin skim coat of glazing putty (sometimes called spot putty) over any small rework areas. Resist the urge to slather on more primer.
      The flares on my Cabriolet had a “pebbly” texture but only in some areas. May just be the way the plastic was molded. Sanding off the old finish in the damaged areas knocked down the tops of the texture. The primer-surfaced filled most of the low areas and the glazing putty took care of the rest.
      After all four fender flares are primed, sanded and quality inspected, it’s time to get out the spray gun and prep for the color coat. Insure that your parts are completely clean. This is critical for solid color bonding to the primer.
      The original paint on my fender flares was a color/clear coat finish. I elected to use what I am most familiar with which is a single-stage PPG acrylic enamel with a gloss hardener additive. I have painted aircraft with this product and find it to be very satisfactory in performance and durability. Clear coat finishes are fine, too. Just added cost. Go with what you are most comfortable with.
      Here’s an easy way to save a substantial bit of money on a paint purchase. A quart of PPG Cabriolet Titian Red in acrylic enamel, a small tin of the hardener and a quart of reducer came to $133.00 with the 20% body shop discount. I don’t operate a body shop. Ask for the shop discount and odds are, you’ll get it if you are paying with cash.
      The price made my eyes water a bit and I told the salesman that I’d have to give it some thought. Thought, as in, “I’m gonna look elsewhere, pal.” He then responded with a suggestion that I use the PPG value line Omni AE paint product. Same stuff. Different label. Total cost was $55.00.
      After all the prep work of cleaning, sanding, priming, more sanding, spot putty, more sanding, more primer and even more sanding... I’m ready to get some color on the flares and quit for awhile. If you have been diligent with the paint preparation, the final color will look better than factory and you can take pride in the effort.
      Use a proper reducer with the paint. Ambient temperature will determine what reducer you will need. Ask the color house people. Do not be tempted to cut corners here and simply throw in some lacquer thinner. Not worth it.
      Should you be doing the spray gun work, then you’ve probably done it before and there’s really no need for another lesson. If lacking spray gun equipment, you might wish to enlist the aid of a friend and his spray equipment to assist with laying on the color. You will still have a substantial personal labor “investment” in the completed job. The actual painting took me less than five percent of the total time expended on this project.
      And while the paint is drying on those great looking, refinished fender flares, you should offer to clean out the spray gun. Then take your friend for a burger and a beer. Good job. Looks great!
      And this, folks, is the Cabrio's fender flare paint shop at Planet Parkside. Believe it. Nothing exotic or fancy, just functional. Setting up the sun and wind screens, gathering all the support materials and confirming the morning's temperature and humidity took almost two hours. Shooting color on all four fender flares was completed in less than twenty minutes! The Hummingbird feeder is actively used. While I was shooting color, a female cruised by and was high ticked that the canvas drop cloth was blocking her breakfast buffet.
      Monte Miller
      1986 WE Cabriolet
      1981 BMW R65
      1978 BMW R100S
      1995 Triumph Trophy 900
    2. Member BoraVR's Avatar
      Mar 13th, 2005
      Toronto
      '87 MK1 Cabby, '08 B6 Passat
      08-11-2008 01:33 AM #2
      Amazing write-up, thank you for putting this together [IMG]http://*****************.com/smile/emthup.gif[/IMG] Very detailed, yet simple enough, with a touch of humor thrown in that makes it so much more fun to read and use. I truly enjoyed reading this and will bookmark for future reference (even though my flares are textured ) [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Should be added to FAQ, IMO
      Mk1 Mayhem
      ______________
      VRSociety #142
      Apr 15th, 2006
      Clarksville, Tennessee
      '89 Cabriolet Best Seller '95 Ford Ranger XLT
      08-11-2008 07:12 AM #3
      Monte, yet another great write-up! [IMG]http://*****************.com/smile/emthup.gif[/IMG] You beat me to the punch for I'd thoughts of doing one right along the same lines when I recently replaced the cracked Clipper side "skirt" between fender flares on my '89 with one of the nice, intact-but-red pieces from my parts car. Those arches turned out great!
      I and many others here will back up what Monte mentions about the wet sanding and taking your time with the prep work, too... Take your time and when you're done sanding, look over the area or piece you're painting with a fine-tooth comb for every little imperfection. I always go take a break then go back and give it one final wet sanding just to be sure... All the prep work and as much patience as you can muster will pay off hugely in the long run...
      Good job, Monte! [IMG]http://*****************.com/smile/emthup.gif[/IMG] <brisket icon goes here>
      My flying/aerial/scenic/transportation-related photography: http://www.flickr.com/photos/vfr_photography/
      Cabriolet photography from years past: http://s82.photobucket.com/albums/j2...usa/?start=all
    4. Member DubPhreek's Avatar
      Apr 17th, 2003
      Bellevue
      89 Cabriolet, 90 Westfalia, 91 Gti
      08-11-2008 02:18 PM #4
      That looks really good..
      Curiously.. couldnt someone put the paint in a rattlecan?
      Also, what sort of compressor/gun setup did you use?
      Thanks
    5. Member montmil's Avatar
      Jul 8th, 2006
      Denton, TEXAS
      1986 Cabriolet WE
      08-11-2008 02:37 PM #5
      I have a 3.5 hp Craftsman single-stage compressor. It's L-O-U-D. Sometime in the future, I'd like to upgrade to a dual-stage with belt-drive electric motor and cast iron cylinder/s. So much quieter... and more expensive.
      I utilize two spray guns, depending on the project. Both are Taiwan copies of the expensive guns and sold under the Campbell-Hausfeld label. Parts interchangeable. One has a quart cup and the other is a detail gun with an 8-ounce cup. Have had the equipment for over twenty years now and, by being kept clean and maintained, should serve for at least another twenty.
      Monte Miller
      1986 WE Cabriolet
      1981 BMW R65
      1978 BMW R100S
    6. Member DubPhreek's Avatar
      Apr 17th, 2003
      Bellevue
      08-11-2008 02:52 PM #6
      Nice to see someone's doin it right! its good to take care of them, so they last!
    7. 08-11-2008 03:29 PM #7
      Great write up but you might not want to use lac. thinner on those ABS plastic arches as that will attack the plastic and make them really brittle.
      I'd would recommend the use of rubbing alcohol instead.
    8. Member kamzcab86's Avatar
      Feb 13th, 2002
      Arizona
      1986 Cabriolet Best Seller; 1990 Vanagon Westfalia; 2016 Golf GTI S
      08-11-2008 03:32 PM #8
      Nice job, Monte! [IMG]http://*****************.com/smile/emthup.gif[/IMG] (Now you need to do the wheels. )
      FWIW, all '80-'87 fender flares begin life as being textured.
      Quote, originally posted by BoraVR &raquo;
      It's been Cabby Info'd. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Cabby-Info.com -- Your online guide to VW Cabriolets/Rabbit Convertibles
      Old Blue's Blog -- The adventures of a 1990 Westfalia
      "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
    9. Member montmil's Avatar
      Jul 8th, 2006
      Denton, TEXAS
      1986 Cabriolet WE
      08-11-2008 04:17 PM #9
      Quote, originally posted by werksberg &raquo;
      Great write up but you might not want to use lac. thinner on those ABS plastic arches as that will attack the plastic and make them really brittle. I'd would recommend the use of rubbing alcohol instead.
      Please reread the post... "After drying, give the parts a quick wipe down using lacquer thinner." As stated, we're lightly wiping the primer, not the bare plastic.
      Monte Miller
      1986 WE Cabriolet
      1981 BMW R65
      1978 BMW R100S
    10. Member montmil's Avatar
      Jul 8th, 2006
      Denton, TEXAS
      1986 Cabriolet WE
      08-11-2008 04:20 PM #10
      Quote, originally posted by kamzcab86 &raquo;
      Nice job, Monte! [IMG]http://*****************.com/smile/emthup.gif[/IMG] (Now you need to do the wheels. ) FWIW, all '80-'87 fender flares begin life as being textured. It's been Cabby Info'd. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      You're echoing my wife's comments about the flaked Titan Red on the "snowflakes". May have to wait until it's time for new tires, then have the wheels blasted to bare aluminum and do the paint. Don't know if a brush touch up on the bare spots would look good...
      And I can not explain why only a portion of the fender plastics had the textured surface. My rear view mirror housings are next. They are a fully textured surface. The clear coat is gone from the upper surfaces and the Titan Red is sorta "chalked".
      Modified by montmil at 3:23 PM 8-11-2008
      Monte Miller
      1986 WE Cabriolet
      1981 BMW R65
      1978 BMW R100S
    11. 01-31-2010 01:15 AM #11
      Sorry for bringing back a VERY old thread but does anyone know if these can be purchased? Is there a company that makes these or anywhere that i would be able to buy OEM replacement ones? I cant seem to find them.
      Apr 15th, 2006
      01-31-2010 11:19 AM #12
      First place I'd check would be on eBay... The fender flares, entire "Clipper kits" (the later Cabriolet "body kit"), and tons of other parts show up there frequently. Do a search for VW Cabriolet and you should end up with pages of results... Just remember to research the seller's feedback and number of sales, plus all the fine print in any auction...
    13. Member
      Jun 28th, 2006
      Elizabethtown, PA
      '97 Golf (sold), '82 Rabbit 'vert, '92 Jetta VRT, '01 BMW 325i wagon
      02-02-2010 12:05 PM #13
      Quote, originally posted by YamahaR14 &raquo;
      You have IM.
