VWVortex.com - check out this compressor map and tell me what you think
    Page 1 of 15 1234511 ... LastLast
    Results 1 to 25 of 359
    Thread: check out this compressor map and tell me what you think
    1. 08-13-2008 08:07 PM #1
      its the red one of a Holset HE351CW it has .65AR and can be found off a 5.9l cummings diesel and can be bought for around 300$
      so for the money im thinking about trying one out, plus i think i can get one of these MYSELF for prolly 100 bux
      how do you guys think the spool and power would be?
      from my math this turbo flows roughly a max of 57 lb/min so its in between a 3076 and a 35r
      that has really peaked my interest since i figured that out
      Modified by 50trim S at 5:24 PM 8-13-2008
      Oct 4th, 2006
      Sellersville, PA
      2002 GTI 1.8T, 2004 Audi A4 Avant 1.8T quattro, 1984 GTI 8v, 1991 Wolfburg Jetta 8v (retired).
      08-14-2008 10:31 AM #2
      I plugged your map into spreadsheet I developed a while back. As you can see, the Holset won't develop any boost until 4100 RPMs. Efficiency drops off fairly quickly above 6000 RPMs with estimated peak efficiency between 5800 and 6200 RPMs (map does not have efficiency lines). It's a poor choice because it was developed for large diesel with limited top end (<5500 RPMs). See map below with RPMs overlaid.
      EDIT: Converted all maps to lbs./min. for easier comparison.
      Here is the Holset matched to the original 5.9L assuming twin-turbo setup (actually it's the 5.9L TDI V12 b/c I didn't have cummings diesel on file). Notice the nice powerband from 2500 RPMs to 5000+.
      EDIT: Heres the 2871 matched to the 1.8T for comparison (largest Garrett turbo I have on file). Notice peak efficiency at approx. 4600 RPMs. Also the TD05H-16G (from the Mitsu. Evo III) with peak eff. at approx. 5200 RPMs.
      Modified by mainstayinc at 12:10 PM 8-14-2008
      Turbo: GTX2867R 0.48 A/R T31; Engine: ALH 95.5mm crank, JE 83mm 9.5:1 pistons, IE rods, ARP bolts; Intake: R32 75mm TB, SEM IM; ECU: GTS Performance, 4bar MAP sensor; Fueling: Gen II 1200's, Aeromotive 340 (x2), -6AN lines, Fuelab FPR; 5bar BFP; Drivetrain: 02J trans, APTuning race gearset, 3.389 RP, Peloquin LSD, Bully Kevlar Clutch; Exhaust: 2.5in QTP cutout; Suspension: Bilstein PSS, SRS Anti-torsion; Major Apocalyptic Sign
      Oct 4th, 2006
      Sellersville, PA
      08-14-2008 02:12 PM #3
      The 3071R. Peak efficiency from 3000 RPMs at P2/P1=1.4 to 5200 RPMs at P2/P1 = 2.2. Interestingly, peak efficiency improves above this point to 4200 RPMs at P2/P1 = 4.0 (follow the dotted line up and to the right). Nice turbo capable of 450 to 500 hp with decent powerband for the 1.8T.
      EDIT: Added GT3076R for comparison.
      Modified by mainstayinc at 11:36 AM 8-14-2008
    4. 08-15-2008 03:54 PM #4
      other opinions please
    5. 08-15-2008 04:14 PM #5
      thanks for the graph analysis, I haven't seen a map modded with 1.8T spec RPM ranges before.
      50trim, that pretty much answered your question didn't it? You can see exactly what it's doing, and how it compares to other turbos...
      Personally, if I could get one for cheap I'd rock it, it should make good HP on a stock rod engine (considering higher HP to TQ ratio). Plus non-BB is a plus in that case.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
    6. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 04:44 PM #6
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] Here's the map for the disco potato in case anyone is interested.
      I have other maps with RPMs for the K03 and K04 and others garretts if interested.
    7. 08-15-2008 04:50 PM #7
      id like to see how a gt35r compares to the holset he351 if thats possible [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 08-15-2008 04:51 PM #8
      I'd be interested in the K03 (Sport?) and K04 maps! Those are hard enough to find on their own as it is.
      These maps should actually go in the FAQ, me thinks.
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 04:58 PM #9
      Here's the maps you requested. I am not sure if this is the K03 or K03 Sport.
      Here is the K04-20. I will check to see if I have K04-01, since I know there are quite a few people on this forum that use this turbo.
      Note: All maps are converted to lbs./min for easy comparison.
    10. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 04:59 PM #10
      I'll have to grab that map (GT35R) and see what I can do. I will try to post before end of the day.
      EDIT: I can also show analysis for stroked or bored out motor. Just give me the numbers (i.e.: 92.8mm stroke, 83mm bore etc.).
      Modified by mainstayinc at 5:32 PM 8-15-2008
    11. 08-15-2008 05:02 PM #11
      "Quote, originally posted by Blackfin »
      I believe, but am not sure, that the K03-2075 would be the K03S with its 38mm inducer and the -1870 and -2072 are the "lesser" K03 models with 33mm and 36mm inducers. "
      that map does look pretty pathetic for the K03. lol
      Edit, here's a website, they have a few 3K-B maps...
      http://www.not2fast.com/turbo/maps/
      Modified by -Khaos- at 10:06 PM 8-15-2008
      ░░░░░░ .. R13 5
      ░░░░░░ .... 24
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 05:18 PM #12
      Yeah. Pretty pathetic compared to the other turbos. It's only capable of about 21 lbs/min or about 200 hp. But... great spool.
    13. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 05:20 PM #13
      Here's the GT35R. You'd really have to bore or stroke your 1.8T to get the most out of this turbo. Alternatively, you could raise your rev limiter. I will try to overlay both maps and post when I get a chance.
      EDIT: Isolated and cleaned up Holset map. Overlay of Holset and GT35R to come...
      Modified by mainstayinc at 3:03 PM 8-15-2008
    14. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 06:16 PM #14
      Comparison to come.
      Modified by mainstayinc at 3:30 PM 8-15-2008
    15. 08-15-2008 06:18 PM #15
      Quote, originally posted by mainstayinc &raquo;
      i'd really like to see those 2 overlayed
      they look very similar and for 300 bux that holset is a GREAT alternative
      don't you guys think? [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      i think that according to the maps the holset looks better
      Modified by 50trim S at 3:20 PM 8-15-2008
    16. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      08-15-2008 06:20 PM #16
      Mainstay, could you do this compressor map please? I've been interested in this turbo...it's only 850 bucks new:
      GT2860R not RS
    17. 08-15-2008 06:24 PM #17
      Quote, originally posted by 20aeman &raquo;
      GT2860R not RS
      look at an APR stg3 kit and you'll see how that turbo does on this motor [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. Member NOLA_VDubber's Avatar
      May 23rd, 2007
      New Orleans
      98 M3
      08-15-2008 06:28 PM #18
      the GT28R is not a GT2860R... EDIT: GT28R = GT2560R
      Modified by NOLA_VDubber at 5:29 PM 8-15-2008
    19. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      08-15-2008 06:30 PM #19
      Quote, originally posted by 50trim S &raquo;
      Haha, it's actually pretty confusing but the GT28r (apr stage 3) is actually a GT2560R. In comparison to this turbo, it can probably flow 10-15lbs per minute more...but it doesn't like the higher pressure ratios like the 2860R.
      The 2860R is a factory replacement/upgrade for Skyline GTRs.
    20. Banned 20aeman's Avatar
      Jun 7th, 2006
      ///M Roadster
      08-15-2008 06:31 PM #20
      nola beat me to it.
    21. 08-15-2008 06:34 PM #21
      my bad
      but the turbo you listed will still be pretty close to the stg3 kit minus about 20 whp from the math i figured [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Member NOLA_VDubber's Avatar
      May 23rd, 2007
      New Orleans
      98 M3
      08-15-2008 06:36 PM #22
      nola beat me to it.
      muhahahahahaha
      *twirls sinister moustache*
    23. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 06:38 PM #23
      Here is the GT28R (aka GT2560R). This is the same turbo which is currently being delivered to my house from California (Atp turbo). I got it with the T31 turbine housing and external wastegate. I just finished porting and polishing my ATP clone manifold two days ago. I ended up in the emergency room this morning before work because I had a chip of iron in my right eye.
      Here is the map for the GT2860R (not the RS Disco Potato) in case this is the one you mean.
      Modified by mainstayinc at 4:30 PM 12-12-2008
    24. Member
      Oct 4th, 2006
      Sellersville, PA
      08-15-2008 06:39 PM #24
      I'm still working on this overlay. It's a bit tricky b/c you have to match axes.
    25. Member NOLA_VDubber's Avatar
      May 23rd, 2007
      New Orleans
      98 M3
      08-15-2008 06:41 PM #25
      I ended up in the emergency room this morning before work because I had a freakin chip of iron in my right eye.
      Happened to my brother doin the same thing...damn you die grinders! The piece in his eye actually started to rust
