Results 1 to 23 of 23
Thread: How To: VF Engineering engine passenger side mount install
  1. 08-13-2008 09:42 PM #1
    Since my final two engine mounts arrived I'll finish the write ups for them. The pendulum mount writeup can be found here http://forums.vwvortex.com/zerothread?id=3653871
    The passenger side engine mount is abit more involved than the lower mount, but still takes only around an hour to install.
    Tools Needed:
    You'll need;
    torque wrench that has a range of around 15-50 ft-lb
    10mm, 13mm, 15mm, 16mm, and 18mm sockets. A 13mm and 15mm swivel socket will be handy for this job
    T25 torx for the bellypan
    Extension
    Ratchets
    Breaker bar, and a cheater bar as well (cheater not pictured)
    Jack and jackstand (not pictured)
    Getting started:
    Jack up the car and place the jackstand on the driver's side.
    Remove the 8 T25 torx screws and 3 10mm bolts holding the bellypan on.
    SUPPORT THE ENGINE WITH THE JACK!!! this is VERY important. You'll want to put enough pressure on the engine to actually push the car up and then add another pump or two.
    I placed my jack pad at the rear corner of the pan like so. I'd recommend using a 2x4 if you have a steel jackpad.
    Now go to the top and remove the factory mount by unbolting the washer fluid reservoir (10mm bolt)
    Remove the 13mm bolt on the black bracket between the fender and factory mount (Not visible, under the coolant reservoir.) Here is where the 13mm swivel socket comes in handy. Set the bolt aside for later
    Pull the factory bolts (16mm and 18mm) They will not be used again.
    WHEN UNBOLTING THE 18MM BOLTS FROM THE MOTOR DO NOT ALLOW THE MOTOR TO DROP!!! if it starts to drop, you need more pressure on the jack!
    You can now remove the factory mount by pulling it towards you and out.
    ^^^ In this picture you can see the black bracket. Do not remove it since it'll just make more work for you.
    Mount comparison:
    The pics pretty much sum it up, the stock mount has massive amounts of flex and movement to it. Therefore, it is crap.
    Installing the VF mount:
    The hard part is already done if you've made it this far. The new mount is a perfect drop in fit. Install all the bolts BY HAND before tightening any of them. You may have to shift the mount around to get all bolt holes aligned. Reuse the 13mm bolt for the bracket, and tighten the VF supplied 15mm and 16mm bolts.
    Torques;
    Mount to engine: 60Nm (44 ft-lb)
    Mount to frame: 40Nm (30 ft-lb and center bolt gets the same torque as well)
    Mount bracket to black fender bracket: 25Nm (18 ft-lb)
    Torque everything twice and release the jack. Reinstall bellypan and remove jackstand. Stand back and admire your fancy new mount. Don't forget to reinstall the washer reservoir filler.
    Don't forget to retorque after driving 200 miles. You've got no excuses not to!
    All information contained herein is for educational purposes only. Don't blame me if you do something dumb and hurt yourself. As always Your Mileage May Vary.
    Modified by S4mig at 2:43 AM 8-14-2008
  2. Member _GoatPunishment_'s Avatar
    Mar 28th, 2002
    2011 Mustang GT
    08-13-2008 09:49 PM #2
    I hope everyone else has $900 bucks worth of tools to install this mount.
  3. 08-13-2008 10:11 PM #3
    Awesome writeup, how has this changed your driving experience?
    ^ $900 in tools?? If you don't have a torque wrench and a socket set, you are not eligible to work on your vehicle
  4. Member djdub's Avatar
    Dec 29th, 2001
    Norcal
    Golf TDI 4dr MKVI
    08-13-2008 10:18 PM #4
    Quote, originally posted by justinperkins »
    X2 and LOL.
    Awesome write up!!!
    Want: Audi MQB RS3 Sportback, S-Tronic (DSG) in the USA.
    Want: Mk7 Golf Sportwagon with DSG, HID/LED's, TDI and AWD (With potentially an R-Kit)
    Want: Mk7 Golf R 4 Door with DSG
    Want: More Hatchbacks/Sportbacks/Wagons in the US.
  5. 08-13-2008 10:21 PM #5
    Well I just drove it 6 miles to go get gas.
    On startup, there is no denying the added vibration. At idle you can feel it through the dead pedal and very noticeably the brake pedal. As soon as you give it some throttle or start moving the vibration is unnoticeable.
    Driving around town you get the feeling that engine has more urgency and response. There is no denying the shifts seem more responsive even when just driving slowly. Downshifts are now perfected, whereas the pedulum left something to be desired, this mount nails it. There is no rocking or snapping sensation on downshifts anymore.
    With the pendulum after a few weeks of driving the vibration and benefits were no longer noticed. I think there is a breakin period with these mounts. If the vibration of this mount goes away but the benefits remain it would be perfect. As of now I give it 8.0 out of 10, only due to the vibration at idle.
  6. Member ZPrime's Avatar
    Mar 7th, 2006
    [216 / 440] Mayfield Heights, OH
    2008 R32 #3603/5000
    08-13-2008 10:48 PM #6
    Have you done the Trans mount yet or are you planning to?
    Oh and it's only $900 of tools because he has a $700 Snap On digital tq wrench. Sockets aren't that bad, although the swivels are probably a little pricy.
    I have installed most of the popular bolt-on mods for a 2008 R32, minus suspension work. I know a lot about electronics and car audio, and have experience with VCDS ("vagcom"). I'm a radar/lidar countermeasure enthusiast. I like track days, autocross, and US Highway 129. I love aural pleasure.
    WitW 2013 || I UM
  7. 08-13-2008 11:07 PM #7
    Quote, originally posted by ZPrime »
    I'm waiting for my EVOMS intake to arrive to install the trans mount. Figure I'll do a two for one install and do both writeups.
  8. 08-13-2008 11:10 PM #8
    No need to do a writeup on the evoms, it doesn't get any easier than that, plus there's already a few. I'm selling mine if you want it
  9. 08-13-2008 11:33 PM #9
    I'll just slide a pic into the mount writeup then. I'm about ready to cancel my order but its supposedly should be shipping about now. Why'd you pull yours and what filter/color does it have?
  10. 08-13-2008 11:52 PM #10
    Do you still have your S4? Silver S4/DBP R32 is a winning combo.
    Nice write-up. Your car is the one that sealed the deal for me when Jared posted the teaser Alcon shots over on, uh, that other forum.
  11. 08-13-2008 11:57 PM #11
    Yep still have it sitting back home in Ohio. Whenever I get the time I'll be doing the Tial 650 kit along with all the other stuff i have massed for it. Great car and I miss be able to drive it.
  12. 08-14-2008 12:00 AM #12
    True enough. Still waiting to see some logs for a Tial car with some proper tuning (like Tony).
    Any plans to add boost to the R32?
  13. 08-14-2008 12:06 AM #13
    Quote, originally posted by OcelotPotPie »
    Hell to the yes! I've been the most impressed with VF's so far.
  14. 08-14-2008 12:11 AM #14
    VF seems like a good choice. The HPA stuff seems nice but it's like MTM. Expensive and I dunno if it's worth it.
    If I can score an exhaust manifold for a decent price, I may piece one together. I've got the advantage of having AMD out here, so if I can convince Tony to come out and tune it it should work out okay.
    I'm not looking for Stage 3 S4 power levels, but 400HP would be nice.
  15. Member
    Aug 5th, 2002
    Boston, SF, Taipei, and Shanghai,
    2007 R32
    08-14-2008 02:54 PM #15
    Quote, originally posted by S4mig »
    I will chip in how I reduce the vibration when I install all 3 VF mounts on my mk4:
    1. Lose the bolt a bit and start the car. Re-tie them to the the spec tq while the car engine is runing.
    2. test drive and see at what RPM it vibrates
    3. repeat step 1 but this time have your friend keep the rpm to what you found at step 2
    Goofy's euro .:R32
  16. Member
    Sep 17th, 2007
    Texas, USA
    08-14-2008 07:39 PM #16
    Quote, originally posted by IamGoofy »
    I'mm trying to understand the logic behind this exercise...somebody?
  17. 08-14-2008 07:49 PM #17
    Today the vibration is no longer noticeable through the dead pedal and the brake pedal has less felt vibration as well. So I'll up the rating to 9.0 out of 10.
  18. 08-27-2008 07:52 PM #18
    Good DIY thread. I give it a 10
    -Sean
  19. 09-26-2008 01:57 PM #19
    Has anyone tried to replace the rubber in the tranny mount with the mount offered by BFI? I replaced the dogbone insert with the BFI and I could definitely tell the difference.
    [IMG][/IMG]
    These cost about $65 from BFI and are listed to work on the 2.0T and the 2.5L engines but not our engine. These seem like a good econ option to the $200 mounts...
  20. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    01-28-2009 05:43 PM #20
    Great DIY
    OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
    Mk2 16v parts for sale.
    Mk2 Golf_GL 16v @ Streets of Willow Raceway.
    Project Гольф Мк2 (Carbed)
  21. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    01-29-2009 03:58 PM #21
    Quote, originally posted by rysskii3 »
    Great DIY
    Definitely. Thank you.
    I will be keeping this in my bookmarks for future reference.
    MKV | MKIV | AWhiteRabbit| perfect.
  22. 02-19-2009 03:00 PM #22
    ooo i want one now
  23. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    2008 VW R32 :: 2000 MBZ ML55 AMG :: 2006 Mini Cooper S :: 2003 Aprilia Atlantic 500 :: Yam. Morphous
    07-04-2009 08:01 PM #23
    ... Here is where the 13mm swivel socket comes in handy. ...
    It must be immensely satisfying to have *exactly* the right tool for the job. I made do with a 13mm box wrench and a little coaxing from a hammer to break it loose.
    Thanks for a great DIY thread, it was very helpful to me.
    Quote Originally Posted by petef View Post
    ... you have no way of knowing whether the previous owner(s) was a civilized driver or a hoon like Peach.
    Quote Originally Posted by Dave Barry
    Wouldn't "Hoon Like Peach" be an awesome band name?
