VWVortex.com - 1994 Jetta GL, new instrument cluster error code.. help!
    Results 1 to 5 of 5
    Thread: 1994 Jetta GL, new instrument cluster error code.. help!
    1. 08-14-2008 11:25 AM #1
      I've always loved the mk3 jettas, and I picked one up from a friend for 500 bucks a few months back and I've been slowly fixing it up as time/money will allow.
      When I got it there were a variety of electrical issues (shorted relays, no brake lights, no turn signals, dead instrument cluster) and I believe I've worked them all out. I recently got a replacement instrument cluster from a friend which turned out to be bad (tested on another mk3) but when you turn the key before ignition, the odometer read "2(upside down U)(space)02". I picked up a working cluster from a junkyard last weekend and installed it last night, the cluster works perfectly, but I'm still getting that error code.
      Google has failed me in finding out what that means, does anyone here know? Do I need to get a code reader to find out what's really going on?
      Other than the error code the car is running great. I've focused on the mechanical/electrical to start with, now the exterior and interior need to be fixed up.
      It's a labor of love really.
    2. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      golfs on junior cupkits with a side of chalet sauce... lifted Jeep Wrangler
      08-14-2008 11:40 AM #2
      that's not an error code it's a service reminder indicator..
      doesn't mean **** [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote Originally Posted by Paul Harley
      yo, is that a wolf?
      MODS IN THE SIG: MY MODS IS IN THE SIG!
    3. 08-14-2008 01:12 PM #3
      Thank you so much for that info, I've been worried about it
      I just replaced the A/C system yesterday and other than that warning, everything is golden.
      Now to work out the dings in the outside
    4. Member brobs is back's Avatar
      Jan 22nd, 2008
      gravel pit, IA
      08-14-2008 01:18 PM #4
      there is a way to reset that service reminder but i don't know how..
      my 97 jetta has an obd1 cluster so it has that thing too when you first start it up
      yo, is that a wolf?
    5. Senior Member Dan J Reed's Avatar
      Jul 26th, 2004
      NJ - AKA - Earth's armpit.
      Too many
      08-14-2008 05:14 PM #5
      Here are the instructions for reseting and programming the service reminder
      for the Golf ///, Jetta /// and other such car for the oil servie OEL, and the
      service intervals IN1 and IN2.
      This information has been obtained from a german repair manual for the cars and
      has been tried successfully on the authors 1994 Golf GL, US Model.
      Displays:
      IN00 - no service is required; this is the standard display
      OEL - when 7500miles have been reached before the yearly service interval
      IN01 - indicates it is time for the yearly service including oil change
      IN02 - indicates it is time for the 15,000mile service with extra checks
      The computer has counters that count not only the miles from the odometer to
      flag for services but also counts time to flag for servies.
      TO RESET THE INDIVIDUAL INDICATOR COUNTERS:
      1. Turn on ignition (do not start the car)
      2. Press the trip-reset button on the odometer (the trip value will not be
      reset to zero but will reappear when the procedure is completed)
      3. Turn off the ignition and then release the trip-reset button.
      In the LCD display, you will see the display "OEL".
      Using the button to set the MINUTES (lower one) of the digital clock, you will
      reset the OEL interval counter. Press it, hold, release. Five (5) horizontal
      lines will appear in the LCD display.
      4. Press and release the trip-reset button
      In the LCD display, you will see the display "IN01". Repeate the process under
      step 3 above to reset this counter when required.
      5. Again press the trip-reset and reset the IN02 counter if necessary.
      If doing an oil change, ONLY reset the OEL counter.
      If doing the IN01 service, reset BOTH the OEL and IN01 counters.
      If doing the IN02 service, reset ALL of them, the OEL, IN01 and IN02 counters.
      6. Turn on ignition (do not start the car).
      7. After the appearance of the "IN00" display, turn off the ignition.
      8. You are done. The trip counter should read as it did before you started.
      PROGRAMMING THE SETTINGS OF THE VARIOUS SERVICE COUNTERS.
      It is possible to program the current settings you want for the counters.
      This used if the speedometer console is replaced or if you want to set your
      intervals to a shorter value than the factory. For example, you can set the
      computer to display OEL after only 3000 miles.
      1. Turn on the ignition (do not start the car)
      2. Depress the trip-reset button on the odometer.
      Also depress the button to set the MINUTES of the digital clock (lower one).
      3. The LCD display should read "OEL 1,S", where the S indicates SET.
      4. Using the trip-reset button, you can call up the following counter banks
      for the service intervals in sequence:
      OEL 1,S - distance counter for oil change (ie 7500 miles normally)
      OEL 2,S - time counter for oil change (ie 12 months)
      IN 01,S - time counter for yearly service interval (ie 12 months)
      IN 02,S - distance counter for special service (ie 15,000 miles )
      5. Using the button for setting the MINUTES on the digital clock (lower one),
      you can display the value of the counter. Repeated pressing of the button will
      select a subsequent lower value of the counter and at the lowest level, it will
      reset to the highest level and begin to decrease again. The step sizes are
      blocks of miles (500 miles, I think) and months (the time setting for the
      yearly service is a bit strange as I think it can be set to 1,2,3,4,5 or 6.
      Maybe it counts in 2 month blocks? Does anyone know?).
      6. Once you have set each counter to the value you want, turn off the ignition.
      7. Work is done.
