VWVortex.com - aba brakes on a mk2?
    Results 1 to 10 of 10
    Thread: aba brakes on a mk2?
    1. 08-18-2008 11:32 PM #1
      i have a stock mk2 gti 8v with 9.4 vented brakes... now what will i need to upgrade to aba 10.1 brakes?
    2. 08-18-2008 11:37 PM #2
      There should be info in the DIY at the top of the page. I think you need the spindles that attach to the control arm and to the shock assembly and IIRC they fit right up.
      You can also use the rear axle for 4-wheel disc, but it's just an 8v. I have all OEM stuff all around.
      Modified by ninjamunky at 10:38 PM 8-18-2008
    3. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      08-18-2008 11:40 PM #3
      GLI, Passat 16v, 4 cyl. MK3 (Both GTI & Jetta) all have the same brakes.
      Modified by Capt.Dreadz at 11:35 PM 8-18-2008
      Everything VR6Turbo & Supercharged The world is ours!!
      Follow us on Instagram @ Everything_VR6turbo_SC
      FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    4. 08-18-2008 11:59 PM #4
      might as well get mk3 lower tabs with mk3 tierods, that would widen your car a bit at the same time.
    5. Senior Member ratdub's Avatar
      Jan 16th, 2005
      hamilton township, nj
      stock TSI & stage 2 FSI
      08-19-2008 12:02 AM #5
      Quote, originally posted by calyp_so_fine »
      you would need a'lot more than that to widen your stance...
    6. 08-19-2008 12:06 AM #6
      whats a mk3 lower tab?
      Anyways you need calipers and carriers, I believe that the knuckles from 9.4s will work with the 10.1 carriers. If you see a 10.1 set up youll understand what youll need. If Im wrong about 9.4s working with 10.1 carriers than youll need the 10.1 knuckles too....IVe got the whole set up if youre that interested. If you want to widen the stance you need the longer axles, control arms, and tie rods.
    7. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      08-19-2008 12:12 AM #7
      Spindles, Carriers, Calipers, rotors........thats it!
    8. Senior Member ratdub's Avatar
      Jan 16th, 2005
      08-19-2008 12:14 AM #8
      do upgrade from 9.4's to 10.1's (as on late model a2 gli's and aba a3's) you will need:
      knuckles(w/ wheel bearings)
      calipers
      caliper carriers
      rotors
      pads
      hardware
      19mm tierod end
      it is a very easy swap if you have a donor car avail. to you...
    9. Senior Member skidplate's Avatar
      May 4th, 2004
      Beaverton, OR
      2012 Golf R 1990 Audi Coupe Quattro
      08-19-2008 12:18 AM #9
      Quote, originally posted by Capt.Dreadz »
      GLI, GTI, Passat 16v, 4 cyl. MK3 all have the same brakes.
      Mk2 GTI's never had 10.1's
      Flickr
      Quote Originally Posted by Mr. Knappy View Post
      We really need breeding standards like they have with dogs.
      Quote Originally Posted by pete@blackforest View Post
      I remember when people modified their Volkswagen to enhance the driving experience. What ever happened to Fahrvergnugen? Bags are for kids that grew up watching Pimp My Ride. Turbo is for all of us that enjoy actual motorsport.
    10. Senior Member Capt.Dreadz's Avatar
      Jun 3rd, 2003
      Long Island, NY
      VRT's & 2.7T's
      08-19-2008 12:36 AM #10
      Quote, originally posted by skidplate »
      fixed
      Kids, Don't post and talk on the phone at the same time. You might eff up not paying attention
