VWVortex.com - DSG Fluid and Filter Technical Write-Up
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: DSG Fluid and Filter Technical Write-Up
    1. Member Sureguy's Avatar
      Mar 22nd, 2000
      San Jose
      2002 Audi allroad 1990 GLI 1.8T
      08-20-2008 08:24 PM #1
      I haven't seen one done by anyone on here so I am adding mine. Hope it helps someone.
      I decided to do a technical write up on the service you should be doing every 40K miles.
      The transmission has to be cold at start of service in order to adjust fluid level properly. I'd let the car sit overnight so that it gives you time to do what you need to do.
      Parts you'll need
      6x 1L of DSG Oil OE# G 052 182 A2 $18.34/1L
      DSG Oil Filter OE# 02E 305 051 C $43.22
      Tools you'll Need
      Ross Tech HEX-CAN cable and computer
      14MM Allen socket (for drain plug)
      24MM Hex Socket (for filter)
      8MM Allen Socket (for overflow tube)
      T20 Torx (for airbox inlet)
      VAS 6262
      or
      I have this tool
      AST 1000 Fluid system
      with
      AST ATF 106
      First you'll need to remove the upper engine cover/airfilter
      It is difficult to remove this cover because of the way it is held on. I pull up in the back first as it is reinforced. Remove MAF connector, clips for turbo inlet and fresh air inlet. Watch out for J nuts on the airbox inlet, if they come out put them back on the way they came off.
      Next you'll want to remove the filter housing. It is located under the battery and is hard to see at first. Use a 24MM socket with extension to loosen the housing. Reach down and unscrew the housing and tilt it in it's bore to drain the fluid back into the trans. Once it is done draining pull housing out from behind the engine. It is a tight fit and requires patience. Pull filter out same direction. Replace filter in opposite order. The filters do not come with O-rings so reuse old one. I's assume at some point there will be one included with the filter but for now it is okay to reuse. After the filter has been replaced, install engine cover and reconnect MAF harness and clips and torx screws.
      Next you are going to go under the car. With the car properly raised off ground using suitable jackstands or ramps, remove drain plug using 14MM Allen socket. Use a container able to hold approximately 6L of fluid. Once the plug is removed you will notice that not much fluid comes out. Once the initial fluid stops you can use an 8MM Allen or Allen socket to remove the plastic overflow tube inside the drain hole. This is where you will drain 5L of fluid.
      Once the fluid has stopped draining replace plastic overflow tube and tighten to 3 nm.
      Next you will be inserting VAS 6262 Tool or AST ATF 106 tool in place of drain plug.
      The VAS 6262 utilizes the DSG fluid bottles to fill the transmission. It is more time consuming to do it this way but should be cheaper than purchasing the AST system. However if you are doing alot of trans services it pays for itself fast. From this point on I will be talking only about the AST system.
      You will now need to fill the AST bottle with the DSG fluid. It holds about 3.5L of oil so you will need to refill before the engine is started.
      Now connect the AST hose to the fitting you previously inserted into the drain hole.
      Connect VAG-COM to vehicle and access transmission electronics. Go to Data block 19 and monitor Transmission Fluid Temp.
      Pump 5.5L of fluid into the transmission and close off valve. Go to the topside of the car and start engine. Holding brake, move gear selector into each position for 3 seconds and return to park. Now let idle and watch temp on screen. Once the temp is at 35 deg Celcius, remove adapter, hose and allow excess fluid to drain. Once the fluid level is correct it will slow to a drip. At this point replace drain plug with new aluminum washer and torque to 45 nm. Clean off oil and test drive. Enjoy!
      Modified by Sureguy at 11:53 AM 8-21-2008
    2. Member Sureguy's Avatar
      Mar 22nd, 2000
      San Jose
      08-20-2008 08:26 PM #2
      Of course if you don't want to buy the tool you can always make one. http://deviantspeed.com/diy-ds...s6262
    3. Member agpatel21's Avatar
      Jun 21st, 2006
      Greensboro, NC
      06 VW GTI MKV
      08-20-2008 09:24 PM #3
      You should also make sure that when you are doing the final step. To have the car level so the right amount of fluid comes out. This will let you make sure its filled to the proper level and not a little less because the car being on a slope.
    4. Forum Sponsor Arin@APR's Avatar
      Jul 29th, 2008
      Auburn, Al
      S4 3.0 TFSI 6MT & GTI 2.0T FSI DSG
      08-20-2008 09:32 PM #4
      Quote, originally posted by agpatel21 »
      To the OP, this is an important step which according to the photos was not followed!
      GoAPR.com | Facebook | YouTube | Twitter | Instagram
      Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
      Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    5. Member Sureguy's Avatar
      Mar 22nd, 2000
      San Jose
      08-21-2008 01:30 AM #5
      Good point. If you use a set of ramps the trans actually sits pretty level. Otherwise a rack is preferred.
    6. Member Sureguy's Avatar
      Mar 22nd, 2000
      San Jose
      08-22-2008 02:56 PM #6
      Can this get added to the DYI Trans section?
    7. Senior Member MFZERO's Avatar
      Mar 13th, 2002
      Haverhill, Ma.
      2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
      08-22-2008 03:19 PM #7
      Nice work
    8. Junior Member linux_guy's Avatar
      Jul 5th, 2008
      01/13 PASSAT TDI, 08 GTI
      08-22-2008 05:23 PM #8
      I wish I could do it. Besides dealer ships who can do this properly? I assume this is not regular shop kind of stuff?
      And how much is this at the stealerships?
    9. Member Sureguy's Avatar
      Mar 22nd, 2000
      San Jose
      08-22-2008 06:17 PM #9
      It's really not that hard. The biggest hurdle you have to get over is that it is not filled from the top. Once you can conceptualize how the service works it's cake. If you've done one you can do it within 30 min again with the right tools.
    10. 11-13-2008 07:44 PM #10
      UP
    11. Member squitiere's Avatar
      Sep 17th, 2006
      Downingtown, PA
      MkV GTi
      11-13-2008 07:51 PM #11
      sticky, please
    12. 11-13-2008 07:57 PM #12
      Quote, originally posted by squitiere »
      sticky, please
      second
    13. 02-04-2009 11:24 PM #13
      Quote, originally posted by lonepatrone »
      second
      +3
    14. Member f_399's Avatar
      May 8th, 2006
      Dallas-Fort Worth
      2007 VW GTI(SOLD), 2010 Passat Wagon, 2012 Jetta GLI(SOLD), 2011 CC R Line
      02-04-2009 11:39 PM #14
      whats that blue car in the back???
      AJ
      Instagram: aj_p
    15. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      02-04-2009 11:58 PM #15
      Quote, originally posted by f_399 »
      mkiv r32 w/ bbs ch? [IMG]http://*****************.com/smile/emlove.gif[/IMG]
    16. 02-05-2009 12:00 AM #16
      With the CH's?
    17. Member f_399's Avatar
      May 8th, 2006
      Dallas-Fort Worth
      02-05-2009 12:02 AM #17
      yeah looks good even from just that small preview
      anyway back on topic, my bad
      AJ
      Instagram: aj_p
    18. 02-05-2009 05:05 AM #18
      what do you guys mean by leveled? like the car has to be on a lift or on 4 jack stands? also how does the fluid go in if you do it one quart at a time with the other hose?
    19. Member
      Jun 1st, 2003
      Dearborn Heights, MI
      2005.5 MKV TDI
      02-05-2009 06:17 AM #19
      Normally the fluid is gravity fed (think of an IV setup as seen in Hospitals).
      The pump in this write-up is pricey, so I went to Murray's Auto and purchased a $6.50 Valvoline hand pump.
      The threads on this pump don't work on the DSG bottles, but it doesn't matter.
      There is an extension tube on the Valvoline pump that can be trimmed for length. Just attach it to the pump, trim the length until the top of the pump touches the top of the bottle, and hold it in place with one hand, and pump with the other.
      Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
    20. 02-05-2009 12:35 PM #20
      Quote, originally posted by Tim Birney »
      Is this like a gear lube pump for filling differentials?
      I bought the ATF 106 adapter and was thinking about using a bug sprayer to pump in the fluid, but I guess a gear lube pump would work well.
    21. 02-05-2009 01:37 PM #21
      so you are letting the car run after removing the adapter(while letting the excess to drain?
    22. 02-05-2009 05:34 PM #22
      Quote, originally posted by nickg »
      Looks that way. I'm going to bust it out this weekend.
    23. Member
      Jun 1st, 2003
      2005.5 MKV TDI
      02-05-2009 06:46 PM #23
      NO!
      You let the excess drain until it stops. Then you put on the cap (plug) screw. After that you start it and let it warm up to do the Transmission reset via VAG-COM.
    24. 02-05-2009 07:03 PM #24
      NO!
      Actually, from "Procedure for changing DSG transmission Fluid" in the MKV FAQ:
      -Reinstall overflow tube, 3 Nm
      -Install adapter - A - from VAS 6262 hand-tight in inspection hole
      -Shake oil containers before opening fill 5.5 liter DSG oil
      To change bottles, shut-off valve can be closed or oil filler adapter VAS 6262 can be held higher than transmission
      -Move through VAS 5051 until DSG oil temperature is displayed or
      Vag-Com Select 02 Auto Trans go to Meas.Blocks-08 grup 019 and then GO.
      -Now start engine
      -Press brake and shift into each selector lever position for approx. 3 seconds. Place lever in position P again
      Do not switch off engine!
      -Wait till DSG oil temperature riches between 35 ° to 45 ° Celsius
      -Disconnect quick-release coupling of adapter for oil filling VAS 6262 with engine running
      -Let excess oil drain
      -As soon as the oil has run out (it begins to drip), remove adapter for oil filling VAS 6262 and install bolt with new seal
      -Tightening torque: 45 Nm
      -Turn off engine
      Modified by imhondude at 7:27 PM 2-5-2009
    25. 02-05-2009 08:05 PM #25
      the pump he is using looks to be the better route
