Page 1 of 2 1 2 LastLast
Results 1 to 35 of 40
Thread: best coilovers for a MK2 VR6 ???
  1. 08-24-2008 04:44 PM #1
    What are the best coilovers for a mk2 vr6 ???
    In terms of stance and handling please help !
    pics welcome to see how they seat.......
  2. 08-24-2008 04:49 PM #2
    please any advice ??
  3. Senior Member Jman5000's Avatar
    Nov 8th, 1999
    Columbus Ohio
    1988 Audi 90 Quattro (out to pasture), 1992 GTI 16V, 2010 Audi TT S-Line
    08-24-2008 05:02 PM #3
    Try "mk2 vr6 suspension" in the archives.
  4. Member dossantos25's Avatar
    Mar 17th, 2005
    Toronto
    05 GLI, 09 CBR600RR
    08-24-2008 05:04 PM #4
    well im sure everyone has their own preference when it comes to Mk2 Vr suspension. Running a set of coilovers designed for a Vr6 mk3 are your best bet as they are valved for a heavier front end. However im sure just about any coilover using a quality strut insert (like koni) would do a very good job at whatever you need the suspension to do. In terms of handling the Bilstein PSS9s are very nice but expensive, and height and dampening coilover should help you out in the handling department. if you want stance the B&Gs and well as the H&R ultra lows will ensure your scrapping lip,oil pan and whatever else you want. If your running the suspension in areas with salt, i would consider coilovers with a stainless steel finish (FK silverline Plus X). Most coilovers will run you low enough and still have coils left, oil pan clearance will be your biggest worry but other then that take a look in the suspension forum or get online to the many vendors out there. good luck.
  5. 08-24-2008 05:06 PM #5
    any pics of mk2 vr6 with coilovers ????
  6. 08-24-2008 05:47 PM #6
    HR ULTRA LOWS
    i still can go lower
  7. 08-24-2008 05:48 PM #7
    Quote, originally posted by Gaby16v »
    Quote Originally Posted by Pineapplegti ! View Post
    Brand enthusiasts are idiots.
    Klutch Republik - Live Fast , Drive Hard
    SCCH Cylinder Heads & Suspension Components
    OSD #16
  8. 08-24-2008 05:49 PM #8
    if your talking to me it is vr and i think you know that ,
  9. Member flippinvws's Avatar
    Jan 27th, 2006
    nor-cal/nj
    90 GLI vr-T, 04 .:R 32T
    08-24-2008 05:53 PM #9
    h&r ultra lows, many many turns left...
  10. 08-24-2008 05:54 PM #10
    what brand are those coilovers 90dub ?
  11. 08-24-2008 05:55 PM #11
    sorry saw the answer >>>.. how much those run for ????
  12. Senior Member trip permit's Avatar
    Mar 18th, 2008
    Puyallup, WA
    92 GTI 07 Rabbit
    08-24-2008 05:57 PM #12
    KW V1 Coilovers:
  13. 08-24-2008 06:02 PM #13
    new anywere from 1100 to 1500
    http://autosportstyle.com/shop...id=12
  14. 08-24-2008 06:06 PM #14
    Quote, originally posted by 90dub »
    whatevahs .
    I wish I had a vr with coils.
    So i could spin em all the way up and take a pic. and it will still be a mk2 vr on coils.
    You think I can fit et 15 16x8"s on H&R coils?
    OSD #16
  15. 08-24-2008 06:10 PM #15
    hell i dont know
  16. 08-24-2008 06:22 PM #16
    for street use you guys think bilstein pss9 would be too expensive or overrated ???
    just want to have a tight handling...... and I 16x9 so they dont rub....
  17. Member mk2 16v turbo's Avatar
    Apr 2nd, 2006
    SLC
    01.5 S4,03 W8
    08-24-2008 06:50 PM #17
    i've got a cup-kit on mine, it's pretty firm, but of course non-adjustable.
    http://www.lowrangeoffroad.com/
    4 rings to rule them all.
  18. 08-24-2008 06:51 PM #18
    hell i dont know
    It's a joke...
    OSD #16
  19. 08-24-2008 07:01 PM #19
    how about B&G who sells those ?????
  20. 08-24-2008 07:03 PM #20
    If you have the money buy Koni.
  21. 08-24-2008 07:08 PM #21
    for mk2 vr6 is the mk3 vr6 a direct fit ??? or should I buy mk2 coils with vr6 spring rate ???
  22. Member mk2 16v turbo's Avatar
    Apr 2nd, 2006
    SLC
    01.5 S4,03 W8
    08-24-2008 07:10 PM #22
    I've heard that with the added weight of the vr, mk3 coils work better.
  23. 08-24-2008 07:21 PM #23
    do vr6 mk3 coils would be a direct for a vr mk2 ???
  24. Senior Member cyclops594's Avatar
    Sep 28th, 2005
    NorCal(Mudville)
    1991 Jetta GLI 16V
    08-24-2008 07:47 PM #24
    Quote, originally posted by dossantos25 »
    legit answer.
  25. 08-24-2008 08:32 PM #25
    cut springs
    /thread
  26. 08-24-2008 08:41 PM #26
    as always , talking bs people any other advice ???
  27. Member dossantos25's Avatar
    Mar 17th, 2005
    Toronto
    05 GLI, 09 CBR600RR
    08-24-2008 09:01 PM #27
    well check out KONI, FK, B&G, H&R and see what your budget is. thats some advice to start. do you want cheap ****, or quality ****. do you want it to have a good warranty in case something brakes, or go to **** within a few years. driven all year round or only in nice weather. the list goes on. do some searching and youll find plenty of info
  28. 08-24-2008 09:52 PM #28
    who sells bilstein pss9's ???
  29. Member Gaets's Avatar
    Feb 7th, 2005
    Easton, Maryland
    1991 GTI 24v
    08-24-2008 09:58 PM #29
    b&g's
  30. 08-24-2008 10:14 PM #30
    who sells b&g ????
  31. 08-24-2008 10:44 PM #31
    Koni Coilovers and MK3 VR6 strut mounts/bearings
  32. 08-24-2008 10:47 PM #32
    who sells b&g ????
    http://www.mjmautohaus.com/cat..._5106
    OSD #16
  33. 08-24-2008 10:47 PM #33
    who sells b&g ????
    i had B&G in my mk2 vr6 gti and i hated them i then had H&R and i will never ever go to any other kind of coil
    H&R FTW
  34. Member sleepygreen2's Avatar
    Jun 2nd, 2006
    PNW
    B5 A4
    08-25-2008 12:51 AM #34
    weitec
    vr6 bearings
    Modified by sleepygreen2 at 9:54 PM 8-24-2008
  35. 08-25-2008 07:25 AM #35
    is it mandatory to run vr6 bearings or it just sits better ?????
