thats a unique idea
good luck!
#1
MK4/MKIV 2.0L AEG/AZG + 16v head swapThis is a budget build... $35 for 16v head, $50 for pistons/rods, etc
work in progress. I'm lacking some aluminum welding of a TB relocation bend.
t-belt -> 2004 LEXUS GS300 L6 3.0 Liter FI
head bolts -> 91290A560 -> http://www.mcmaster.com (Issam Abed now offers ARP studs for this application.)I swapped 9A pistons and rods into a AZG/BEV block. The pistions had to be machined a bit to clear the oil squiters.
AZG - modified 9A - stock 9A
1.8T hybrid steel bottom oil pan... you never know when you might need an oil return lineAZG/BEV bottom end assembled with 16v 9A rods and pistons. I reused the mk4 rod bearings and piston rings.:
now some attention to the center of the swap, the 16v head:
new stem seals, fine sanded all bearing and lifter surfaces and cleaned all gasket surfaces.
Clean carbon off valves:
head's assembled and time for mockups:
need to relocate TB:
MK4 coolant flange -> 16v head adapter:
I'll be fitting a 20v CPS hall senosr wheel onto the 16v dizzy and use the dizzy as the CPS:Using an earlier AEG downpipe to mate with 16v exhaust mani. Having O2 bung welded on:
Thanks,
Rey
Modified by elRey at 11:39 AM 7-21-2009
#4
tranny separated and old 8v up on stand:front end swung open leaving A/C lines connected, waiting for 16v:
older brother watching, remembering it's awkward swap (mk4 2.0L AZG + turbo from 1.8t):a little fancy hoist driving and 16v is docked:
exhaust connected, coolant hoses, wiring, accesories on:
Modified by elRey at 1:55 AM 9-8-2008
Modified by elRey at 2:06 AM 9-8-2008
#6
man rey, i thought i had the hybrid edge...u have a double-edged sword!![]()
i have transmission ideas for adjusting shift points
u make me wanna keep mine
'11 Routan SE (black), '01 Wolffy (white)
FE ///MotorsportsVCDS Hex-Can, if you need help.
http://mefi.us/images/fuelly/sig-us/128853.png
#8
Watching!
#10
started it up tonight.first I pulled the fuel pump and injector fuse and I disconnected the coil pack and ran the starter for a minute to get the fresh oil circulating.
I then replace the fuel pump fuse and cycled the ign a few times to look for any fuel leaks.
Then I replaced the injector fuse and reconnected the coil pack.
It fired right up. Though, with a major exhaust leak that I knew about and #4 cyl misfiring. I only let it idle for a minute.
The exhaust leak is from a threaded hole in the mani I have yet to find a bolt to plug it. The misfire... I don't know yet. I have to address the pancaking silicone bend after the TB before I start it up again.
.still have to:
1) torque the drive shaft flanges
2) find/fab a dizzy cover
3) figure out intake
4) lengthen MAF wires
5) address silicone after TB
6) find bolt to plug hole in exhaust mani
7) address #4 cyl misfire (God willing, this will go away)
Modified by elRey at 12:44 AM 9-10-2008
#11
awesome job rey. just awesome. we should meet up for a auto 16v ride![]()
#12
Quote, originally posted by rychas1 » awesome job rey. just awesome. we should meet up for a auto 16v ride ![]()
Thanks man. Let me make sure it'll stay together, but after that, sure! But I would never expect it to keep up with yours.
#13
From the noob corner...inspired, you have laid the blue prints for my winter project. I am painting my chariot now and the engine is next. What's the biggest hurdle you have had to overcome so far in this project?
I'll be watching..
#14
Subscibed for a super sweet build. This should have been the base engine in the MkIV!
#15
It been running for 600 miles now:
#16
Quote, originally posted by elRey »
very clean
#17
cool swap![]()
#18
so, what are the difference in feel from the 8V to the 16V ? noticeable ? gas mileage ?
#19
You are my new hero. I was curious about what other people are watching and stumbled across this thread. I honestly had to dig through my ETKA to make sure they didn't actually offer this combo somewhere (besides here). Looks pretty factory to me & for that, I grant you![]()
and a
Mike S.SacWater
'03 20th Anniversary - '96 GTI VR6
'91 B3 Variant - '76 Mk1 - '66 T3 Variant
*Duc*Duc*Hawk(GT)*
The Ranch Run - Wuste2012 "Cogito, ergo zoom!" RIP David E.
#20
Quote, originally posted by microzimmer »
very clean
Agreed. It looks so right.
#21
bump for hp gains, differences before and after, woudl love to do this to my mkiv over winter![]()
#22
Quote, originally posted by 71sbeetle » so, what are the difference in feel from the 8V to the 16V ? noticeable ? gas mileage ? Yes, to the OP please tell us about gains, feel, how it drives, etc.
Modified by randallhb at 8:23 PM 9-28-2008
#23
I was just wondering what plug wires you used and how you went about setting up the dizzy as the CPS ,
#24
gotta see
16V TURBO KIT FS + accessories
PM ME
so bright as headlights loud speakers and my car being lowerd is a bad thing your stupid dude gtfo of here.
#25
Quote, originally posted by sickmind » I was just wondering what plug wires you used and how you went about setting up the dizzy as the CPS , Wondering the same thing myself. SICK build man, congrats.
#26
x2 also did you have to change the intermediate shaft gears and what not like the aba guys? or is this entire motor mk4 minus head pistons rods and timming belt?
#27
Quote, originally posted by 2LTurbo » or is this entire motor mk4 minus head pistons rods and timming belt?
excatly
#28
wtf ?! how! seriously the aba guys say it CANT be done without switching those other things... also how did you tackle the CPS man?
#29
CPS is in the thread....stock 16v distributor + 20v trigger wheel
I cut/grind the 16v trigger wheel down just enough to slide the 20v wheel over it, then tack welded it.
Quote, originally posted by elRey » I'll be fitting a 20v CPS hall senosr wheel onto the 16v dizzy and use the dizzy as the CPS:
#30
elray i love you, why wont you answer my pm'shaha for a turbo setup would you recommend the 9a pistons or can i use my brand new aeg pistons i bought and just notch them?
#32
Quote, originally posted by 2LTurbo » oh also what did you use for head bolts? 91290A560 -> http://www.mcmaster.com
#33
what about using arp head studs. would i use the 16v ones or 8v ones?
#34
sorry i know i must sound like a lil girl. im just excited, but where did you get the MK4 coolant flange -> 16v head adapter:
