i have a 1988 cabrio how can i tell if i have a hydro or solid lifters i want to buy a cam and is asking me if its hydro or solid.
#106
#107
#108
check the head4 caps = hydro
5 caps = solid
Karma's Law - For every action there is a multiplied reaction!
1993 Mitsu Pajero GLS 3.0 V6 LWB - SOLD
2000 VW Passat 1.8T - SOLD
2001 Gen3 Pajero Di-D LWB
#109
Quote, originally posted by fourie_marius » check the head 4 caps = hydro
5 caps = solid
what do you mean caps? where are they located?
#110
the caps that keeps the cam connected to the head. check out mine. it is a hydro cus there is 4 caps
Modified by fourie_marius at 10:15 AM 6-12-2009
#112
help please.
i purchased a 90 cabriolet back in november. at the time it was running fine but needed a new tranny. i was able to drive it up onto the dolly though when i bought it. it sat over the winter and in the spring i did the tranny swap plus some other upgrades to the brakes and suspension. nothing though to the engine. now i can't get it to run. it tries to fire but it isn't getting any fuel. the pump is working fine. i disconnected the fuel line to the rail and had a friend hit the key and gas squirted out so that's fine. i've got good spark to all the plugs but it appears that the electric fuel injectors aren't working. any ideas on what could be causing them not to receive a signal? i'd appreciate any help. m_shea@hotmail.com
thanks
mike
#113
Gas mileage on the 1.8L 8v GTI's? Looking to pick one up, currently have a 2000 lexus es300 that gets round 20mpg :-( such a hog. Might consider turboing a 8v my buddy has. Thanks for your help and hopefully I become a Vdubber soon enough!
#114
Question..What will replacing my stock 1.8L cam with a 2.0 L cam do? Hp? etc... pro's and con's
#115
lots of info on 8v's spec and technical info herehttp://forums.vwvortex.com/zerothread?id=3958581
and diagnostics here
http://forums.vwvortex.com/zerothread?id=3963112
#116
I have got scirocco cam with stamp on it N, what N means? is N better than G? help please
#117
if i have a 1.6 8v gas engine, can i turned into a 16v??? a friend of mine is selling the 16v head from a scirocco 1.8..... i really appreciate if you can help me with that info...
#118
I'm looking for a 1.8 8v timing belt procedure for a 89 Golf 1.8 auto. First link in this FAQ doesn't work and I didn't do well searching.I found an excellent procedure for the 2.0 here but now I need a 1.8.
Recommendations/links please.
Thanks,
Dave
#119
Quote, originally posted by davebugs »
I found an excellent procedure for the 2.0 here but now I need a 1.8.It's the same procedure.
#120
Thanks for the response.In the meantime I had found this link in another thread that was helpful:
http://www.vwgolfmk1.org.uk/mo...art=0
I'm almost done. Just borrowed the tensioner tool to complete the job.
Dave
#121
wow what a great forum. i have a question.i have a 1.8 8v CIS-E engine. i originally wanted to build a jh head with 270 cam, autotech valve springs, techtonicts header, all on a 2.0 block.i have recently been told that i can put all my goodies into a stock 2.0 crossflow engine and wont have to do any wiring. is this true??????
MY BUILD THREAD http://forums.vwvortex.com/showthrea...nt-VW&highligw
http://www.4everkustoms.com/ <=THE BEST
#122
Quote, originally posted by Mean ’n Green86 » wow what a great forum. i have a question.i have a 1.8 8v CIS-E engine. i originally wanted to build a jh head with 270 cam, autotech valve springs, techtonicts header, all on a 2.0 block. i have recently been told that i can put all my goodies into a stock 2.0 crossflow engine and wont have to do any wiring. is this true??????
If you are going to stick with the JH head (or any counterflow head with CIS) then you won't have to do any extra wiring. The fuel injectors, intake manifold, and related plumbing will stay the same if you swap a 2.0L block underneath.
However, if you are looking to use the 2.0L block with it's crossflow head, then there will be several modifications necessary. Most people that continue to use the CIS injection do not use the crossflow head, due to the amount of modifications needed. In the end, it's a lot of work for virtually no gain.
For Sale / Trade: - VW Mk1 & Mk2, 8v Engine and Misc. trim parts:
#123
thank you sir thats all i needed to heari'm sticking with the counterflow then head on the 2.0 block
#124
i have a 1985 golf 2 door 8v motor the car wont start i was told that it could be the ignition switch so i changed all that everything turs on when i turn the key but the car wont start and the heater and the stereo wont turn off when i take the key ou...can enyone help with this problem
#126
This thread is not being used properly. Please post only information (ANSWERS) to question that are commonly asked. If you have question, search for it first, then if you cannot find a valid answer start a new thread in the appropriate forum.Locked pending cleanup/revision.
