Page 18 of 26 FirstFirst ... 8 14 15 16 17 18 19 20 21 22 ... LastLast
Results 596 to 630 of 905
Thread: show me your trunk
  1. Member VAGwhore's Avatar
    Nov 12th, 2004
    Texas
    2006 Bagged B6 Passat , Hers:2008 Bagged CW R32
    07-11-2012 01:47 AM #596
  2. Member Mike GoFast's Avatar
    Mar 6th, 2006
    MA
    08 Jetta
    07-12-2012 10:08 AM #597
    s888
    s13
  3. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    South Burlington, VT
    335i
    07-16-2012 01:17 PM #598
    Quote Originally Posted by Mike GoFast View Post
    s888
    that woodgrain!
    - Call us at: 802 . 735 . 2574 - Email us at: sales@bagriders.com - - // - - We're open: Monday - Friday 9:00 - 5:00 Eastern -
  4. Member savphili's Avatar
    Jun 4th, 2004
    Scottsdale, AZ
    2003 VW Jetta
    07-17-2012 02:50 AM #599
    Where do you buy the fittings that thread the airline through the metal? (4-pieces in the picture)
    Thank you,
  5. 07-17-2012 03:18 AM #600
    They are bulkheads and Will at BagRiders above has them.
  6. Member
    Jan 3rd, 2009
    hewlett harbor NY
    2008 audi rs4 .... 2012 bmw 335..... 2010 mercedes sl63 ...... audi q7....1997 gti vrt
    07-18-2012 09:56 AM #601
    Quote Originally Posted by bboy_jon View Post
    My new trunkish setup
    one of my favorite hardline setups
  7. Banner Advertiser Will@BagRiders's Avatar
    Feb 19th, 2010
    335i
    07-18-2012 10:05 AM #602
    Quote Originally Posted by savphili View Post
    They're called bulkhead unions.
  8. Member ZLEB's Avatar
    Dec 9th, 2010
    LI-NY
    2012 Tiguan S
    07-18-2012 01:50 PM #603
  9. 07-20-2012 10:07 PM #604
    gotta question guys. ive messed with air before but never hardlines. are you guys running push to connect bulk heads for hardlines? ive only used plastic lines before didnt know if hard lines work in push to connect?
  10. Member wagner17's Avatar
    Oct 19th, 2009
    baltimore
    jazz blue 20th # 427
    07-20-2012 10:08 PM #605
    Most use ptc
    SoIAteAPancakeToday
    i have a really small penis so i lowered my car so people will look at me
  11. 07-20-2012 10:19 PM #606
    ok thanks, not sure if ima run hardlines yet and show off the tank and the hardlines, or just show off tank and just use plastic lines.
  12. Member bboy_jon's Avatar
    Jan 19th, 2010
    Columbia, MO
    2002 1.8t GTI
    07-20-2012 10:28 PM #607
    well, actually. I feel like most people (with hardlines) use compression fittings. I used ptc fittings with my old set up, and there are many others who also use them, but compression fittings are just better
  13. Member wagner17's Avatar
    Oct 19th, 2009
    baltimore
    07-20-2012 10:32 PM #608
    Also more expensive and cleaner looking
    SoIAteAPancakeToday
  14. 07-20-2012 10:45 PM #609
    no doubt compressions are cleaner but quick searches on google of bulkheads, all ive seen is ptc bulkheads.
  15. Member bboy_jon's Avatar
    Jan 19th, 2010
    Columbia, MO
    2002 1.8t GTI
    07-20-2012 11:47 PM #610
    swagelok or parker fittings. They can get pricey quick.
  16. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-21-2012 04:03 PM #611
    Instgram: D_HANKEN
    Butter my bread and call it Toast
  17. 07-21-2012 06:06 PM #612
    Quote Originally Posted by CoopersVR6 View Post
    This is pretty much exactly what I was gonna do when I get my setup. Was it difficult to do? And does tge compressor get enough air?
  18. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-21-2012 06:49 PM #613
    Wasnt to bad, basically cut a piece of wood to mount in there and attached the compressor to that and ran wires/lines behind the carpet, i've seen people put em in smaller spaces so air shouldnt be a problem in there, sometimes i leave the door open on hot days...
    Instgram: D_HANKEN
  19. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    07-21-2012 09:07 PM #614
    Man that must get super hot in that compartment when the compressor is running. That is a 380 correct? That thing runs for such a long time in such a heated environment that isn't going to be ideal for it. I would add 2 computer cooling fans to that area, one to supply air and one to suck hot air out
  20. 07-21-2012 09:17 PM #615
    can you take pics of how you hung your tank? im thinking of just bolting the tank stray to the tray above. but the tanks i got is bigg. like 8 gallon i think. bitch is heavy.
  21. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-21-2012 11:00 PM #616
    Quote Originally Posted by MechEngg View Post
    its a 400, would like to put a 444 in there, that was my exact plan was to use comp. fans...ive had it like this for a month so far and havent had any problems, ive had this same compressor in my last car too for 2 years prior, would like to upgrade soon, dont know the dimensions of 444 so not sure if itll fit or not
    Instgram: D_HANKEN
  22. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-21-2012 11:03 PM #617
    Quote Originally Posted by bagged00 View Post
    its bolted strait to the tray along with the v2 manifold and relay, this is a 5gal from bagriders, full spare/tools still in the spare tire compartment too, that was my goal was to not have any air ride stuff on the floor of the trunk
    Instgram: D_HANKEN
  23. 07-21-2012 11:17 PM #618
    ^nice, so it didnt pull that tray down any? i plan on doing a fake wall then running air management between the fake wall and seats that way its still accessible if i have any problems. my neccesities are cleanliness,easy accesible spare tire, easy accessbile air management and trunk space.
  24. Member CoopersVR6's Avatar
    Jul 30th, 2007
    Rip City
    07-22-2012 01:26 AM #619
    It's attached to the metal that's under the rear shelf, I just removed the shelf and drilled holes
    Instgram: D_HANKEN
  25. Member mveitenheimer's Avatar
    Sep 1st, 2007
    Sturbridge,MA
    80 diesel caddy, 05 GTI
    07-24-2012 09:25 PM #620
    just the beginning of the install but am very pleased with the compressor location it's quiet as hell inside the car.
  26. Member vwguygti98's Avatar
    Aug 14th, 2003
    Hazard County, MD
    2003 VW gti BAGGED
    08-14-2012 05:20 PM #621
    here is my recent setup...nothing to fancy but they are real crystals and the tank is hand painted...
    Quote Originally Posted by briggs rabbit View Post
    I really dont think N.W. A. is to blame nor Slick Rick... and easy mtyhr fukn E is dead. The blame lies within the lyrics of Slayer, W.A.S.P., Megadeath. And Irion Maden Brain washing The younger generation into ASSHATERY.ex. drinking using drugs and ofcourse regressing into early stages of toddler hood ( whinning).............. But thats why the forums are here
  27. 08-15-2012 05:42 PM #622
    the keg is a guinness keg
    i just trimmed it all in leather to match the s-line seats, but need to trim tyhe sides and rear of the seats aswell
    what you guys think??
  28. Junior Member
    Aug 3rd, 2011
    West Michigan
    2003 Audi A4
    08-18-2012 11:25 PM #623
  29. Junior Member arclight1's Avatar
    Feb 22nd, 2011
    Maryland
    2009 GLI, 2004 B6 A4
    08-19-2012 03:01 PM #624
  30. Member bboy_jon's Avatar
    Jan 19th, 2010
    Columbia, MO
    2002 1.8t GTI
    08-19-2012 10:58 PM #625
    ^^^ Nice and clean! Would look sick with hardlines
  31. Member BLKSUNSHINE's Avatar
    Sep 20th, 2007
    Long Island, NY
    Bagged MK5 & MK6 TDI JSW
    08-20-2012 07:02 AM #626
  32. Member Burth's Avatar
    Oct 14th, 2010
    socal
    le variant
    08-20-2012 01:37 PM #627
  33. Junior Member arclight1's Avatar
    Feb 22nd, 2011
    Maryland
    08-20-2012 04:39 PM #628
    Thanks! I agree, however, I was was trying to keep the number of connections (aka potential leaks) to a minumum so I stuck w/ the 3/8" tubing for now.
    Lets see what next season brings.
  34. Banner Advertiser Andrew@ORT's Avatar
    Nov 23rd, 2008
    Malvern, PA
    V8 + 80mm Snail.
    08-21-2012 08:59 AM #629
    Quote Originally Posted by arclight1 View Post
    Tom, your V2 install is by far one of the cleanest I've seen. It was great meeting you at VAG Fair and I look forward to seeing you in OCMD!
    If you want to change up anything, drop me a line and I'll make sure you get taken care of
  35. Member glimark's Avatar
    Jul 31st, 2007
    847 IL
    04.5 BMP GLI/ 81 Caddy <3/b7 passat
    08-23-2012 03:05 PM #630
    Trunk for now need to repolish the tank. Future holds hardlines with a floating gauge and a quick disconnect hose fitting .
