VWVortex.com - Sale: 02M Steel Billet Flywheels, Sachs & Clutchnet Clutch Kits, Free Ground Lower 48
    Page 3 of 7 FirstFirst 1234567 LastLast
    Results 51 to 75 of 173
    Thread: Sale: 02M Steel Billet Flywheels, Sachs & Clutchnet Clutch Kits, Free Ground Lower 48
    1. Member aadosx's Avatar
      Aug 24th, 2008
      Auburn
      MkIV BMP .:R32
      05-04-2009 11:38 PM #51
      Quote, originally posted by FourSeasonTuning.com »
      The dish and offset of the 5 speed and 6 speeds flywheels are different and do not interchange.
      The only mfg that uses a VR6 pressure plate for A 6 speed 02M application is Eurospec Sport. The kit uses a 228MM 11 pound custom cast steel flywheel and a modified (for extra clamping force) VR6 pressure plate . It uses a stock Sachs 228mm full face disc w/ 23 spline center (from Audi 80) as opposed to the 28 spline for the 5 speed cars. We have had Clutchnet make us other discs for this application that would be stronger than the OE disc supplied in the ESS kit. ARP bolts are supplied with the ESS kits.
      If you don't mind a little noise at idle then one of the ESS kits will be better on your budget.
      I'm confused, in your OP the ESS kits don't come with 11 pound flywheels.
      Also I have a few other questions.
      1) In the stage 1 kits, the Sachs is cheaper than the LUK. But in the stage 1+ kits, everything is the same except for the pressure plate, and the one including a Sachs cost more.
      2) Will a higher clamping force pressure plate cause a slave cyl. to fail any faster?
      Looks like I'm just trying to decide between the State 1+ and the ESS 240mm kit, based upon chatter. Also how do the discs in those two kits compare? Is the ESS disc closer to the OE one or the Clutchnet one?
      Thanks!
      John
      .:R32 : flickr : vimeo
      Quote Originally Posted by Redapex View Post
      The 599 GTO runs on leaded liquified platinum and the only by product of the exhaust is $100 bills... And whats that glorious sound coming from the tailpipes? Why its Kanye West telling you that your Merc is scrub status.
    2. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      92 Corrado SLC , 92 Audi S4
      05-05-2009 12:04 AM #52
      The ESS kits were revised and now have 20 and 26 pound FW options.
      We get a better deal on the Sachs Kits Vs the LUK.
      The stage 2-3+ are made to work with the OE release bearing.
      Have not heard the Noise from a 20 or 26 pound ESS kit.
      The stage 1+ has a fully covered steel sprung hub disc, so this would be better than the un-sprung oe disc or the ESS type when using a single mass flywheel. The Noise varies from car to car. The heavier steel flywheel makes less noise than the sub 11 pound types ( the most noise is at idle with clutch pedal out).
      Stage 1+ kit linked below.
      http://fourseasontuning.com/?product=593
      :: www.FourSeasonTuning.com
      :: United Motorsport-Wossner-Supertech-Clutchnet-DXD/SBC-Koni-Stoptech-Racingline-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
      :: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
    3. Member aadosx's Avatar
      Aug 24th, 2008
      Auburn
      MkIV BMP .:R32
      05-05-2009 01:25 AM #53
      I'm sorry but could you please elaborate on this? Thanks in advance!
    4. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      05-05-2009 01:48 AM #54
      The solid hub disc's are used with dual mass flywheel from the factory, the disc material is riveted/bonded to a segmented steel material ( where the sprung hub below has a larger steel backing more surface material for the friction material to bond to). This solid type is the OEM disc from your car.
      Sprung Hub steel backed disc's were designed for maximum burst and rotational strength. The sprung hub's six springs lessen shock of engagement, Sprung hub discs (similar design) are also used on the Audi S4/RS4 (2000-2004 era) also 240MM and a 6 spring hub, even with a dual mass flywheel. The RS4 with a factory modified LUK pressure plate and stock S4/RS4 sprung hub disc was rated for 380HP. The sprung hub disc is also used from the factory on almost all single mass clutch setups.The most used street type disc is a sprung hub for daily driving.
      The Clutchnet disc has fully covered the springs for extra strength.
    5. Member Three3Se7en's Avatar
      Jul 1st, 2007
      Mississippi
      02 337. 08 F150
      05-08-2009 12:57 AM #55
      I have the 1+ kit. It seems like the engagement is a lot higher up in the pedal's travel. Is this normal?
      Not good for me. 6' tall and having to high step sucks.
      Great product though.
      2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
    6. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      05-08-2009 02:12 AM #56
      The pedal travel should be similar to stock. Both the alloy and steel flywheel's have the same step height as the OE flywheel and are compatible with the OE clutch kit. A few users have diagnosed a faulty clutch master cylinder as the culprit and or improper bleeding.
    7. Member bobbybrown's Avatar
      Oct 8th, 2003
      Pacific North West ...
      05-10-2009 04:34 PM #57
      You mentioned the following ...
      "The dish and offset of the 5 speed and 6 speeds flywheels are different and do not interchange.
      If you don't mind a little noise at idle then one of the ESS kits will be better on your budget."
      As far as the chatter is concerned ... you basically only hear it when standing outside the car. However, I noticed on the one I had installed for me that there is more chatter when I accelerate off the line ... and this I can hear on the inside. It lasts for a few seconds and then it's gone.
      Is this normal?
      Thanks ...
      Bob
    8. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      05-10-2009 08:25 PM #58
      The ESS kits started at $620 a few years ago ( before we started making our own steel billet flywheels and they raised their prices) so at that time they were the best value for sprung hub complete kit.
      The noise varies from car to car. Idle noise is the most noticeable with clutch pedal out. Some users have mentioned a slight noise in 1st and 2nd before 3K ( no performance issues reported).
    9. Member Murphyman20thGTI's Avatar
      Oct 5th, 2008
      Worcester MA
      2003 VW 20th Anniversary edition #2082
      07-09-2009 02:09 PM #59
      Ok i have a 20th, BT gt2871r, with Unitronics 630cc file. I had recently had 1st and 2nd syncros replaced and new clutch installed, 2,300$ later still paying it off! Relized that put in stock clutch! and had a southbend stage 2 clutch inthere thought they swapped it with the same but NO they didnt, So dont know how long mine is going to last so i have been taking it easy on it, which is realy fustrating since its built for speed.
      Which do you think would be the best set up for me that you offer. And fairly Not to costly, since i am in a hole as it is! If you can do any specail deal Let me know (IM me to keep private) if that is best for you. Thanks man
      Possibly looking to trade/Sell my 20th Gti check the link below
      http://forums.vwvortex.com/showthrea...MASSACHUSETTS.
    10. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      07-10-2009 12:54 AM #60
      IM sent with questions.
    11. Member mpatterson's Avatar
      Jun 25th, 2009
      Hamilton Ontario Canada
      2005 Jetta GLI
      07-21-2009 11:11 AM #61
      ok, i know i'm getting due for a new clutch, i've got a 6spd sitting around 260hp/280lbs There are so many options listed here my head is spinning. It's my daily driver, but i am planning on taking it to the track for laps, not sprints, what would you suggest?
    12. Member TooLFan46n2's Avatar
      Oct 18th, 1999
      Lancaster PA
      '08 Jetta 2.5 '02 GTI 337 '97 BMW 328i
      08-03-2009 07:51 PM #62
      Just got my Southbend Stage III clutch installed w/ the 16lb steel flywheel. Drives great and engages smooth. I am a little bit dissappointed w/ the clatter at idle. It sounds like a loud diesel except the noise comes from the bellhousing. Going to try and bump the idle up to help remedy. Overall though I am happy [IMG]http://**********************/smile/emthup.gif[/IMG]
      GTi 337.:R
      {PPT T3/T4 50 TRIM .63 Haldex Kit - Eurodyne Maestro - 630cc Injectors - IE Rods - AEB Head w/ VVT - CAT Cam Gear - Walbro Inline - Audi S3 Gearbox - Peloquin Diff - SouthBend STGIII Clutch - .:R32 LCA's/Spindles/Rack - Ksport Coilovers - Swaybars - Porsche BBK - Eurojet FMIC - FSI Coils - 2 Stage Boostvalve - HKS SSQV }
    13. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      08-04-2009 12:41 AM #63
      Anytime you go from a Dual Mass to a Single Mass Flywheel the noise will be more audible. The heavier flywheels make less noise than the lighter ones.
    14. Member CrossFlowGolf's Avatar
      Feb 5th, 2002
      Asheville, NC
      2003 VW 20th IY GTI
      08-06-2009 10:49 AM #64
      I have 20th with minor mods, chip, intake, TIP, DV, and I plan on getting TB exhaust and FMIC. That is it, nothing major, no crazy hp. I have to get a new clutch, pressure plate and bearing. Do you have a kit with the A slightly better than stock clutch, without a flywheel. My flywheel is fine, and i am not interested in upgrading it. Let me know asap, I will place a order today if you have what I need!
      Thank you for your help!
    15. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      08-06-2009 10:53 AM #65
      IM sent
    16. Member CrossFlowGolf's Avatar
      Feb 5th, 2002
      Asheville, NC
      2003 VW 20th IY GTI
      08-06-2009 02:57 PM #66
      Just want to say, I ordered some stuff from these guys and it was great dealing with this company. They deff knew their stuff on VW's!!!
      Thanks again! [IMG]http://**********************/smile/emthup.gif[/IMG]
    17. Member Murphyman20thGTI's Avatar
      Oct 5th, 2008
      Worcester MA
      09-02-2009 08:57 AM #67
      Ok i have a 2003 20th AE gti 02m Trans 6 speed, with gt2871r turbo running at 20 psi which its running at 300hp+. i had a southbend stage 3 clutch, then had syncros replaced and clutch but the shop put in a stock clutch!? now starting to hear clicking when let go of the gas, and starting to slip if at 4500rpms if shifting and accelerating even in 6th so it is time for a new/Better one!
      I am looking for a clutch kit for 02m 6 speed with 350hp rating but comes complete with all parts needed for swap, so a price and details would be great! thanks for your time.
    18. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      09-03-2009 02:27 AM #68
    19. 09-25-2009 02:42 AM #69
      I'm looking at getting the clutchnet stage 2 i'm not running bt or anything just the normal mods(flash, exhaust, intake, etc.). what do you think. Also how many miles are you getting out of stage 2 kits on a normal daily driver as compared to the stock clutches?
      (O8o)=337==\X/=====(o8O)
    20. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      09-25-2009 12:11 PM #70
      Clutch mileage is driver dependent. The friction materials are both organic, so the difference would be in the pressure plate. The stage 2 is really not needed for your car.
      Here are a few kits that use a sprung hub disc ( from stage 2 kit), OE pressure plate and Steel Billet Single mass flywheel.
      STAGE 1+ KIT
      STAGE 1+ KIT
    21. 09-25-2009 04:01 PM #71
      would it be easier to buy the stage 2 now if i decide to go bt or hold off until that point?
    22. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      09-25-2009 06:44 PM #72
      Yes, that would save the labor and the cost of an extra pressure plate.
    23. Member waabaah's Avatar
      Jun 24th, 2006
      Fairbanks, Alaska
      04 .:R32; 20th a.e.;87 rattled black Toyo;94 AWD caravan;97 Gti Vr6T;82 924 porsche
      09-26-2009 04:34 AM #73
      two concerns..im interested in just a disc. problem is im in alaska and i onyl have a pobox to give. i can give another address but it wouldnt match my CC. thanks..ive been subscribed to this thread for way to long
    24. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      09-26-2009 01:47 PM #74
      We can send to a P.O. box. IM me your tel # and a phone order will solve the address issue.
    25. Member waabaah's Avatar
      Jun 24th, 2006
      Fairbanks, Alaska
      09-29-2009 06:54 AM #75
      IM sent with contact info for you.
