krazy!
#1
Hello
Well i am sure most of you know my car, its been in eurotuner issue august of 07. I bought the car August of 06. but the story was done previously with the opriginal owner. So as soon as i got it i started making it own since i am not used to buying finished cars, in fact this was the very first that i had bought that was modded by someone else.I shortly got rid of the VF SC kit and turboed it with a gt35r and c2 software which then turned into a gt4088r and then shortly to a fully built motor and streetwerke clutch and built trans, i used EIP FMIC and made it work on my setup.
Well not too long ago i sold most of the setup to upgrade once again, now i have redone the whole setup again, i am runing the gt4088r along with custom intercooler and IC piping and Unitronic software for there biggest injectors. So i just installed the HPA short runner made my new piping nad a lot of other things that you will see in pics below, i decided to go stealth and clean look as usuall its still not done as i am waiting on a few other things.
Check it out and let me know what you think, the car ran 12.3 at 115mph which was on a 1 bar spring and making about 12psi in the intake, the new plan is to run about 25+ psi and runing low 10's at 138mph or so. Of course this will be with Water meth and a very good tune from unitronic.
Intercooler 32x12x3.5
Gasket matched the Pag parts manifold
Moved the Airpump infront of the tire
Turbo mounted, i also used 1.8t heater hoses for a better fit and with the heat resistant sleeve
1.8t Coolant lines with the stock heat wrap
Making the hot pipe
MAde a 180 degree pipe to mount the WG on top and to go back into the DP
Downpipe wrapped and coated with head protectan paint
Made a aluminum pipe to go under the exhast manifold to the water reservoir
Put it back together thinking that its in there for good
Wiring tucked away and made look cleaner1000cc injectors, 4 inch MAF and Unitronic software woohooo
The BOSCH MOTORSPORTS 413 fuel pump came in today from USRT woohooo
A few parts i decided to get powdercoated for a cleaner look
I also got the fuel rail modded with 6an fitings to be used with a fuel surge tank, freshly powdercoated as well....
Got the car back together for good minus a few things, looks good
Making the intake 90 degree coupler accept a fitting so that i can recirculate the bov
Engine pics, looking more complete with the intake i just made....will be powdercoated to match later with the heat shield.....
I instsalled the surge tank and the 413 fuel pump
#2
krazy!
Originally Posted by Zhine
#3
Very sweet set-up and i wish you luck and i am watching
-JAMES-
Daily Drive /Beaten/Built /UM Turbo R - VR NATION
#4
Damn Im jelaous! Make me a surge tank setup like that man!!!![]()
#5
gaaaaaaaaaaaaaaaaaaaaawd daaaaaaaaaaaaaaaaaaaaaaaaaaaaaamn!
#6
that thing is a beast...call the highlander ! nice work ! keep us posted with lap times and some 3/4 view picts.JD
Modified by docs_r32 at 3:52 PM 9-25-2008
#7
all the cars you build are nuts![]()
#9
was it difficult getting that 4" inlet to fit?
I "ruined" a limited edition .:Race car
R32 Turbo Build Round 2! Faster, Lower, Smoother.
Integrated Engineering
#10
looks sick...let see some videos of this beast![]()
@jakevr6
#11
Looks like it's close to time for you and I too hook-up at BeachBend, While there we could discuss doing something similiar to my .:R???Project is looking great
If you need a film car for any testing
let me know
#12
Quote, originally posted by Harepower » Looks like it's close to time for you and I too hook-up at BeachBend, While there we could discuss doing something similiar to my .:R??? Project is looking great
let me know
You got a deal, Im me if you want meet up again man.
I am having a minor issue with the software i think the ecu was damaged either when C2 removed software or when unitronic was uploading it. The problem is that the car takes about 5 to 6 times to start each time and that i had to disconnect the intake vvt because the ecu never shuts it off once it has been activated. So the ecu will be shipped out to Unitronic to get it checked out but i will have the ecu back on wednesday. Cant wait to get that worked out and get the remaining stuff powdercoated and be done with the project.
#13
Insane! The powdercoated items really make it look great. Nice work.![]()
#14
sickkk. great documenting.![]()
#16
I honestly get excited to see new build threads with your screen name on them. This looks like another great one for sure. Good luck and keep us updated!
#17
awesome project
cannot wait to see how it turns out
keep up the good work
#19
#20
Wow, great project, that car is a beastI can not wait to see some videos of the setup
#21
Nice rims, I trade you those for my 18 CH's![]()
#22
Tint the windows on that beast asap. I have a BMP R with 20% all around, helps the look of the car sooo much![]()
#23
Is the CF splitter 1 or 2 pieces? It looks like 2 from the pics?
#24
The windows are tinted, the pics dont show it and the splitters are out of 2 pieces....
#25
Quote, originally posted by tsagan » Tint the windows on that beast asap. I have a BMP R with 20% all around, helps the look of the car sooo much ![]()
20% is ridiculous...you can't see **** at night
I wish my BMP had no tint
#26
I think mine is 35% all the way around i love it.....
#28
Any updates on this?
#30
Hey Haris, you not worried about the connector(for the bov recirculation) on the blue 90* pipe Leaking boost? my experience with things like that its hard to get a good silicon to metal seal
ME7.1 & ME7.5 ecu tuning,readiness dtc deletes, immo off, etc.. if you need any of this cheap email coreyj03@gmail.com
#31
The car is done and haulling A$$ i will make a few new videos..Corey
well there is no boost there only a bov recirculation and its real tight and it has sealant on it so it wont ever leak.
#32
I demand a video![]()
#33
one sweet ride, more plz, esp of engine bay..
dyno sheet, vids etc are welcmed too
#34
o... ok i dont know what i was thinking... since its "recirculation" lol
#35
