Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 134
Thread: Transmission Removal Clutch Replacement diy Quick Version
  1. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    10 VW GTI 2.0T, 04 VW Turbo R32, 06 Audi A4 Avant, 1990 VW Corrado
    09-25-2008 11:01 PM #1
    Clutch Replacement
    First off I wanted to make this to show everyone that you don't need a huge shop with a lift to do this. Also as some others have mentioned before you do not need to drop the subframe whatsoever. People always ask me if it can be done in their garage and it can. I tried to take pics of every step and be thorough in my descriptions. This should take you around 3 hours if it is your first time. If you are an experienced mechanic it should only take around 1.5 hours. I took me 3 but I was taking pics and writing this diy <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> I do not take any responsibility for you breaking anything. If anyone with lots of experience feels that I have left anything out please let me know. PM me if you have any questions and enjoy! Also special thanks to my wife Nina for taking the pics.
    -Gabe-
    Bluewater Performance
    1. Secure front car on jack stands. Make sure the car is raised enough that you will be able to drop the transmission out.
    2. Remove air intake or factory air box I will not go into to much detail because if you can’t remove this then you probably should not be replacing the clutch.
    3. Remove battery and battery tray with 10mm socket to give yourself enough room. There is 4 10mm Bolts holding the tray in.
    4. Remove shifter, shift cable and shift mounting bracket using a 13 mm socket zip tie all shift components together out of the way When removing the main body of the shifter be sure to pull equally at both sides. Do not pull one side and then the other back and forth. Shaft is shown in Blue circle
    5. Using a flathead screwdriver, remove the clip that holds shift cable mechanism on. Be sure to not lose the two plastic bushings. I placed the bushings back onto the shaft and then put the clip back on as to not lose anything. As a side note. I replace every bolt or nut that I can as to not lose them. Also it will tend to not have a pile of bolts just laying around on a box.
    6. Remove Hard Line From Engine/Transmission Mount
    7. Remove ground strap from connecting bolt at top of engine/transmission
    8. Disconnect connector for back up lights and other connectors on top of the starter
    9. remove 13mm nut from cable bracket then remove cable bracket from starter
    10. Remove upper starter securing bolt located in the same place as the cable mounting bracket was
    11. Unclip and remove hose to slave cylinder. To unclip pull the metal retaining clip up and just pull back on the line.
    12. Use electrical tape to plug off hose removed from slave cylinder. Make sure you don’t touch the clutch pedal otherwise fluid will come out.
    13. Remove connector on back of transmission. The wires are covered with a heat shield wrap.
    14. Remove both front wheels
    15. Underneath the car, remove the lower dog-bone mount. Replace stretch bolts
    16. Disconnect lower ball joints( three 16mm nuts)
    17. Remove the 6 axle bolts on each side and pull axles out of the way. To do this you will need a 12 point 12mm socket. I zip tied mine up out of the way.
    18. Remove three 13mm bolts from shield on passenger side around axle Sorry No Pics.
    19. Remove four 16mm bolts connecting transfer case to transmission Be patient. These can take some time and be a pain but they all are accessible
    20. Remove 2 16mm bolts holding the mounting bracket from the transfer case to the engine.
    21. Remove 6mm Allen Bolt from inside the passenger side drive shaft. This requires a long extension and a 6mm allen socket. Regular allen wrenches will not work. This is a hard one to find.
    22. You should now be able to easily pry the transfer case away from the transmission.
    23. Remove the lower starter mounting bolt and remove starter
    24. Remove All but one of the engine to transmission bolts. I usually prefer to leave one of the easy to access bottom bolts on. There are a couple of hidden ones. One is facing the passenger side and is right next to the top right transfer case to transmission bolt if you are facing the drivers side standing on the passenger side.
    Passenger side near transfer case bolt
    25. Stabilize the motor and transmission with separate jacks that way you can lower the motor and tranny separately.
    26. Remove the drivers side fender liner and splash shield. The fender liner does not have to be fully removed. I usually just unbolt the front half and move it out of the way.
    27. Remove the driver side engine mount. This will require removing the 3 bolts that attach to the transmission along with the 2 stretch bolts on the mount itself. Then remove the mount and set it to the side.
    28. Begin to lower the engine and transmission together but make sure that the motor is not lowered to where it could potentially fall out of the passenger side mount. Make sure it is lowered enough that it can clear the front stub/subframe
    29. Now comes the awkward and frustrating part. Remove the last engine to trans bolt and start to pry out. Work it slowly away from the engine and transfer case. Eventually it will pull out far enough to where it looks like it is going to hit the lower subframe. When it gets to this point start jacking up or push up on the rear of the transmission so it clears the subframe and it should simply drop out.
    30. Now go have a beer
    31. Next remove the pressure plate bolts. These are 12 point bolts. They require a 11/32 12 point socket.
    32. Remove all flywheel bolts. These bolts are removed using the same socket as you used to remove the axle bolts.
    33. Replace all stretch bolts including the engine mount bolts and the dog mount bolts. Also replace the pressure plate bolts and flywheel bolts.
    34. Replacement Part #s
    a. Socket Head bolt with inner multipoint head/Flywheel Bolt N 909 294 01 x10
    b. 12 point head pressure plate bolt +N 903 207 01 x6
    c. Rear Main Oil Seal b 021 103 051 c
    d. Clutch Release Bearing 02M141671B
    e. Clutch Master Cylinder N/A
    f. Clutch Plate and Pressure Plate b o22 141 015 t(or)tx
    g. Stretch bolts for dogbone mount and drivers side engine
    mount (Drivers Side Engine Mount N 102 096 03 x2)
    (Dogbone Mount n 102 683 02 X2 N 102 466 04 X1 N 905 970 02 x1)
    h. Replace seals/o rings between transmission and transfer case 02M 409 203 & N 904 837 01 & N 028 222 2
    Torque Specs
    Engine to Transmission and Transmission to Transfer case
    1. M12 Bolts - 80NM
    2. M10 Bolts 45NM
    Transmission Mount to Transmission
    1: 50NM + 90degree turn
    Transmission Mount to Chassis
    1. 100NM
    Pressure Plate to Dual Mass Flywheel
    1. 22NM
    Modified by xbluewaterx at 10:30 AM 7-29-2009
  2. 09-25-2008 11:22 PM #2
    Thank you
  3. Member Spoolin1X's Avatar
    Feb 25th, 2005
    NYC
    HPA FT465 R32 RIP, 1964 Impalas (2)
    09-25-2008 11:34 PM #3
    WOW!
    Hitting switches in NYC.
  4. Member Daemon42's Avatar
    Feb 9th, 2001
    colorado
    04 R32T, 95/98 4runner
    09-25-2008 11:35 PM #4
    Great job! Adding to the FAQ/DIY thread.
    ian
  5. Member robocopywriter's Avatar
    Jun 17th, 2004
    Los Angeles
    Mk IV R32, Mk II 16v Gti
    09-25-2008 11:43 PM #5
    Cool!!!
    Rent my house in Greece.
    http://kastro-greece.com
  6. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    12 VW Golf R, 01 Audi A4 1.8T Quattro, 04 VW R33T(SOLD)
    09-25-2008 11:52 PM #6
    good stuff man though if i may add you should also replace the o-rings between the transfer case and the trans.
  7. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    09-25-2008 11:57 PM #7
    Thanks I did replace those but forgot them in the parts list. It is hard to remember everything typing it all out at once
    They are now added.
    Modified by xbluewaterx at 9:03 PM 9-25-2008
  8. Member scharged's Avatar
    Sep 8th, 2004
    Houston Tejas
    old S wagon an M3
    09-26-2008 12:21 AM #8
    a god among Rmen
  9. Member schmuck's Avatar
    Jun 21st, 2002
    naptown
    04 dbp r32, 98 gti vr6
    09-26-2008 01:10 AM #9
    many many thanks, this will come in very handy. best informative post on here in a while
  10. 09-26-2008 03:16 PM #10
    This isn't as daunting as one would think. Following these steps makes it easier than I initially thought it would be. If you take your time and follow the directions (getting a second set of hands helps with pulling the tranny and makes sure you don't have your beer alone ) it is just as easy as the pictures make it look.
    Gabe
  11. Member tjm0852's Avatar
    Jun 10th, 2004
    Cortlandt Manor, NY
    '04 .:R32
    09-26-2008 03:30 PM #11
    Good stuff right there
  12. 09-26-2008 03:52 PM #12
    this is great, thanks! although i think i would just pay someone to replace/install my clutch cuz it would probably take me all day to do this.
    plus i can't afford to get all scarred up and caloused. i'm a hand model.
  13. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    09-26-2008 04:15 PM #13
    Quote, originally posted by 1-UP »
    Serious?
  14. 09-26-2008 04:17 PM #14
    Like... really? Wow!
    Awesome write up! Can't wait to see the pictures, I'm at work and I can't see sh*t.
  15. Banned Bolan Vdub's Avatar
    Apr 23rd, 2008
    09-26-2008 05:22 PM #15
    BRAVOOOOOOO!
  16. 09-26-2008 06:11 PM #16
    Quote, originally posted by xbluewaterx »
    ...If anyone with lots of experience feels that I have left anything ut please let me know...
    I have little or no experience but you left out an "O" but it was left out of "OUT" so maybe that was on purpose.
    Epic post! Thanks so much and I'm sure this will help many who are at the point of clutch replacement now and in the coming years.
    Awesome contribution to the .:R Forum
    many=
  17. 09-26-2008 06:48 PM #17
    Great DIY... I have 74k and eventually will need a clutch and nobody touches my baby but me
  18. Member fleabag's Avatar
    Aug 3rd, 2004
    2010 Jetta TDI CUP
    09-26-2008 06:49 PM #18
    Give that man a prize!
  19. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    09-26-2008 06:56 PM #19
    I am the same way. Nobody but me ever touches any of my cars!
  20. Member peace's Avatar
    May 5th, 1999
    Richmond, VA
    2004 VW Golf R32
    09-26-2008 06:59 PM #20
    Awesome DIY!!! 1000x better than a Bentley manual.
    Also props to Nina on the pictures.
    Printing to PDF next for safe keeping.
    2004 DBP .:R32
  21. Member beachball6's Avatar
    Apr 21st, 2003
    Nolanville, TX
    04 R, 05 Silverado, 08 D675, 06 GSXR600(track bike)
    09-26-2008 07:03 PM #21
    Good write up looks just like any other VW transmission R/R but more of a PIA.
    Shawn
    Converted BMW Fan boi 98.5 Dakar ///M3 Dinan stg3
    I hate Volkswagens.
    .:Racing is easy just remember Fast in slow out....or was it the other way around.
    Turn signals are your friends, and exist for a reason
  22. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    09-26-2008 07:36 PM #22
    Yes, doing this with no tranny lift makes you hate life. I got it out fast, finished the work fast, however getting it back in... Man I was pissed.
  23. Member climbingcue's Avatar
    Feb 2nd, 2001
    Morristown NJ
    08 Kawasaki Teryx, 2012 VW GOLF R 12.58@106 mph on 93 Octane
    09-27-2008 10:21 AM #23
    Nice work, I am going to have to drop a trans on an R32 sooner or later so this post will be a big help
    CAT 2
    Skela official test driver
    Texas Mile October 2010 171.6 mph
  24. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    09-29-2008 12:14 AM #24
    Well I got the transmission bolted back up again tonight. Thanks to scharged for the helping hand. I can't wait to test out the new Streetwerke clutch.
  25. Member scharged's Avatar
    Sep 8th, 2004
    Houston Tejas
    old S wagon an M3
    09-29-2008 12:24 AM #25
    woot for apple pie and vanilla bean ice cream
  26. 09-29-2008 10:50 AM #26
    This is the kind of helpful information that you can expect in the future. Also, expect our website up in the near future!
    Thanks for the positive comments!!!
    Gabe
    G&G Motorsports
    Modified by VTEC976 at 6:53 PM 9-29-2008
  27. Member R32R1's Avatar
    Jul 1st, 2008
    South County, RI
    project roided wookie
    09-29-2008 01:53 PM #27
    somebody get this guy a 12 pack for this write up!!
  28. Member G2VR6Man's Avatar
    Nov 28th, 2002
    Montréal, Canada
    2 Scion Toasters
    09-29-2008 09:42 PM #28
    Awesome write-up!
    ''Women, you can't live with 'em.........Pass the beer nuts.'' Norm
    Old Username: Dubguyvr6
  29. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    10-18-2008 02:27 PM #29
    Bump for someone asking about this.
  30. Member robocopywriter's Avatar
    Jun 17th, 2004
    Los Angeles
    10-18-2008 06:51 PM #30
    For whoever was asking its worth remembering that this is now in the FAQ DIY thread right there on the first post.
  31. Member Navydub's Avatar
    Sep 29th, 2006
    Pleasant Prairie, WI
    Saab STi and a Land Rover
    10-18-2008 11:56 PM #31
    Fantastic write up
    Turbo Unicorn | HS Tuning | 42DD | Cabin Krew
  32. 10-20-2008 12:52 AM #32
    Great write-up dude!
    When I read this the first time, somehow I missed the part that said the woman in the picture was your wife. I thought she was you and posted this herself. I thought the other posters were referring to you as a man because they were stupid. I was actually thinking of contacting her to marry her so she'd do my clutch replacement until I went to her (your) myspace link and saw you were a man and reread the top of the post and found out she was your wife! Already taken, and not as mechanically inclined as I thought anyway! But there has to be some woman out there that likes this kind of heavy duty mechanical work like us men do. I need to find her before my ECS clutch arrives Wednesday, or bite the bullet and do it myself as sort of planned.
  33. Banner Advertiser xbluewaterx's Avatar
    Jul 20th, 2006
    Denver, CO
    10-20-2008 09:39 AM #33
    My wife does like to help out with mechanical work. Well at least sometimes. There are some good ones out there! Just few and far between. Good luck with the job.
    -Gabe-
  34. 10-20-2008 09:49 AM #34
    Great write up, wish you would have done this a couple months ago!!
    The above bolt was a huge problem when we pulled my transmission, thank god Qbn called and told us about this one...
  35. Member VpfinnersW's Avatar
    Jun 14th, 2005
    Clouds and rain
    Candy White Tadpole
    10-20-2008 10:02 AM #35
    this is seriously an awesome write up. I know it must have been a pain in the ass to take pics (well, your wife took them, but still a nuisance I'm sure), write out the DIY steps, remember all the parts replaced, etc on top of just doing the car work alone, so thank you for your knowledge and patience.
