2.0L GL: straight bolt on? how long would you guess the installation takes and software reprogramming?
#106
No Prob!![]()
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
#107
Got to PAY to PLAY!
Rockin' the four-one-four
#109
Waiting for the KO3 to die completely and then I'm gonna pick one of these up. Better start beating on it harder so it dies already!
Your resident pilot
#110
#111
Do want.
#113
So....from reading the whole thread, I've noticed that maybe this isn't quite a whole kit? I could be very wrong on that part. I'm just trying to figure out what to add onto the price if I was to buy the kit...I'm not trying to give you a hard time. I'm just feeling like I would buy the kit and need all this stuff.
-Upgraded injectors
-Upgraded fuel pump
-Upgraded Rods
-Upgraded software
So do I need this stuff to make the kit complete? Also what type of exhaust upgrade would I be needing to run this setup somewhat effectively? The only reason I haven't upgraded my exhaust is because I hate loud exhausts.
Thanks for your time, not trying to be a pain!
#115
all the HARDWARE you need will be there. just pick your SOFTWARE (whichever you prefer) and get what injectors the software calls for along with a walbro 255 inline fuel pump and you will be set. i would say if you're going BT run a 3" exhaust nothing lessbe ready to do a clutch install very soon after LMAO
it's one of those good problems
an upgraded front mount or sidemount ic will be a good idea too
#116
#117
That's quite a bit of dough for your kit, but seemingly value priced for what is offered in the kit. What kind of gains could I expect in terms of hp, torque? I would also consider going to 630 injectors...
#119
I found, after going through the thread, the answer to my query. Thank you and I will be hitting you up again when I'm ready to do the work. I have a lot of work to do! Mostly, beefing up the bottom end to handle the additional power.
#120
I love my CTS KIT
Specializing in Powder Coating and VW/Audi Performance and Maintenance
VAGWERKS PERFORMANCE AND COATING
-Powder Coating -Air Ride Installs - Frame Notches - Coilover Installs - Engine Performance- You name it we will do it, From full swaps to oil changes
#122
#124
#125
A short clip of our fab shop and R&D bay. A glimpse of the men behind turbo kit development and fabrication.![]()
#127
Need a TT225Q or S3 kit for a RHD car? Calling all UK, RSA, AUS, HK residents:
#129
hi ctsturbo, i see the kinetic does fit the RHD cars then i was worried there wasnt room for dp between brake servo is there any other things different the wastegate top mounted to?
#131
OK sounds good so there is alot of room for a 3" DP then?! between the brake servo an the manifold runner, i wasnt sure as my engine is in my house an the car is at my unit so hard to tell if all works without it been in the car. Can you send me a link to buy the relocation pipe can you still run a pipe downwardsie screamer pipe.?
#133
#134
We generally only sell them with kits. If you'd like one please email sales@ctsturbo.com and we'll send you a quote including shipping. We make everything for Kinetic, including their downpipes, kits, etc.
Thanks,
Clay
#136
Tried to go grocery shopping last night.
Cops had other plans.
www.ctsturbo.com
#139
#140
