VWVortex.com - 1broknrado's "One Day" Project Build Thread
    Page 1 of 61 123451151 ... LastLast
    Results 1 to 25 of 1515
    Thread: 1broknrado's "One Day" Project Build Thread
    1. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      24v Corrado, 07 Ram 1500 sport 4x4
      10-03-2008 09:58 AM #1
      So yet again, the motor is coming out of my corrado.
      after the rebuild g60, the 16v, the vr6, now the vr6 coming back out again...
      here is a list of to do's:
      262 cams w/giac chip
      timing chains
      rear main seal
      neuspeed pulley set
      masontech crackpipe kit
      somewhat wire tuck
      new radiator,
      new fans
      battery relocated to the trunk
      mk4 headgasket set
      metal waterpump
      new "steel enforced" oilpan
      clutch? depends if oil got on it from the rear main seal (only has 10k on it)
      tdi 5th gear - if you have any info please tell me (ordering, DIY etc etc)
      polished manifold
      stainless steel exhaust studs
      SS braided fuel lines from dubnutz.com
      mild port/polish headwork
      so far, i pulled the motor out. So far on order = timing chains, rear main seal, mk4 headgasket set, waterpump, new radiator.
      i have alot to do so this is going to be a slow process because college takes up most of my time
      i'll post pics as they come!
      things already done to the car:
      patec coils
      r32 bushings
      10lb flywheel
      bfi stg2 motor mounts
      stainless steel brake lines
      crossdrilled and slotted rotors
      girling g60 calipers
      smoked tail lights
      euro ecodes w/ 4300k hids
      ronal r15s 15x6.5 et 35
      neuspeed shortshifter
      some stereo work (going to be redone)
      repainted engine bay w/ removed seam sealer
      o2a billet shifter bushings (verdict motorsports)
      My 24v Vr6 Corrado Build Thread
      Instagram: @instimgramm
    2. 10-03-2008 10:12 AM #2
      Corradomagic can fulfill that entire list (just about at least)
    3. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-03-2008 10:16 AM #3
      what do you mean by fulfill?
    4. 10-03-2008 12:18 PM #4
      I mean Keith can get you all that you need [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. 10-03-2008 12:22 PM #5
      you are doing something wrong if your car need that many motors in that short of a time
    6. Member VJVR6's Avatar
      Nov 8th, 2002
      08 A4 2.OT Quattro
      10-03-2008 02:21 PM #6
      we need pics!!!
    7. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-03-2008 03:50 PM #7
      i admit the first 2 were my fault and lost of interst, but the 3rd was not my fault...at all. but i have to fix the problem anyways..
    8. Member paste's Avatar
      Dec 26th, 2004
      93 slc, 02 tt, 01 m5
      10-03-2008 04:06 PM #8
      hope it all goes good this time around [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. Member Snowhere's Avatar
      Jul 26th, 2007
      BV Colorado
      one Chevy, one Audi, one VW, one Beemer, dead but not forgotten, and one Suzuki
      10-03-2008 04:07 PM #9
      I am also planning on a tdi 5th gear swap. Currently I am running 3K rpm at 70 and 3.5K at 80. We can go 65 and 75 on our highways here so I am safe from tickets at these speeds. I have looked at Kerma's kit online and they say one of their kits will drop the rpm 800. I still do not know if all I need is the gear or anything else. They want $350 for the gear too, so I would like to figure out what is needed and see if it could be found at a junk yard. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-03-2008 04:07 PM #10
      it will. i know that much. just when is undecided because of $$
    11. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-05-2008 12:44 AM #11
      does anyone have a writeup or something i can use to start tucking some wires? im not doing a bathtub...just want to move some things.
    12. 10-05-2008 04:44 PM #12
      got my 5th gear from TDIparts.com good guys to talk to about what to go with and it is a pretty easy install. You need the 5th gear and the selector gear.
    13. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-05-2008 05:11 PM #13
      autotech.com has them. also performance cafe. they have the .72 gears
    14. 10-06-2008 11:03 AM #14
      i went with this one ---> http://www.tdiparts.com/catalo...d=520
    15. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-07-2008 01:03 AM #15
      Modified by 1broknrado at 11:41 AM 2-4-2009
    16. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-08-2008 03:57 PM #16
      got alot of nothing done tonight since the power washer broke...
      Modified by 1broknrado at 11:39 AM 2-4-2009
    17. Member myglimk2's Avatar
      Oct 15th, 2006
      Shelton,CT 06484
      09' Tig S, 10' Tig S, 92 Jetta, 00 Jeep WJ
      10-08-2008 09:50 PM #17
      Poor Timmy, this thing sits more than you have driven it! lol, anyways sell me your steering wheel!!!!!!!
    18. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-09-2008 01:16 AM #18
      lol NO!
      no pics because ralph forget the camera but...dash is out, wiring is almost all seperated and de-taped. holes are drilled inside the cab for the wiring. tomorrow going to clean up a bit, finish unwraping the wires and label all the connectors with alot of reading of diagrams to see what all those extra clips and cut wires are that i didnt know about!
      will post pics tomorrow.
      any have some suggestions about how to run the fuel lines?
    19. Member myglimk2's Avatar
      Oct 15th, 2006
      Shelton,CT 06484
      10-09-2008 08:00 AM #19
    20. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-09-2008 09:49 AM #20
      ok so fuel lines in OEM position, where to extend the o2 harnesses to?
    21. Member Toffeerado's Avatar
      Aug 3rd, 2003
      Vancouver, Canada
      10-09-2008 10:45 AM #21
      get to work so do you remove engine same way i do un-bolt everything and push the car backwards?
      Quote Originally Posted by Radvr6T View Post
      A true built car is one in which the owner alone has done its work intirely!
      Not had a shop build the motor,Not had a shop paint it ,Not had a upolster do the interior,Not just supplied money for work of any kind for the vehicle!
      According to this guy no one builds cars.
    22. 10-09-2008 11:51 AM #22
      That's the worst beer you can possibly drink.
      Good luck getting the car back together.
    23. 10-09-2008 11:54 AM #23
      Quote, originally posted by Dreizehn »
      I rarely turn down free beer, but that is one I would
      the easy part is done, now you are in for the fun [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      get it done
    24. 10-09-2008 12:54 PM #24
      Tim, you know this dude?
    25. Member 1broknrado's Avatar
      Jul 6th, 2005
      Charlotte NC
      10-10-2008 12:48 AM #25
      haha yea he lives in stratford. name's junior. bought the car from up near groton.
      its a g60. nothing special, guy doesnt know too much about it.
