VWVortex.com - Seat leon 1.6 lambda fault
    Results 1 to 6 of 6
    Thread: Seat leon 1.6 lambda fault
    1. 10-06-2008 12:50 PM #1
      Hi all, this is my first post so please go easy...
      I have done a vagcom scan after eml appeared on a 2005 seat leon 1.6 (BSE engine i think) and unsure if it is just a lambda straight replacement or some thing else causing the fault as these sensors seem to more expensive than usual lambdas i would like to be 100% before purchasing one.
      19058 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit: Open
      All help appreciated
      Thanx
      Modified by 2hot2trot at 8:52 AM 10-6-2008
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      10-06-2008 01:26 PM #2
      I have some guesses but we need further information from that ECU. Please post a full scan from that ECU/vehicle.
    3. 10-06-2008 01:30 PM #3
      Will do !
      Will have to be later in the week as not got car here with me at the momment !!
      Cheers
    4. 10-07-2008 09:46 AM #4
      Hi done the full scan. Here are the results.
      Tuesday,07,October,2008,13:28:13
      Chassis Type: 1P - Seat Leon
      Scan: 01 02 03 08 09 0F 15 16 17 18 19 25 36 37 3D 42 44 46 47 52
      55 56 57 62 69 72 76 77 7D
      VIN Number: VSSZZZ1PZ6R013256
      Address 01: Engine
      Part No: 06A 906 033 FF
      Component: SIMOS71 1.6l 2V 7004
      Coding: 0000071
      Shop #: WSC 06441
      1 Fault Found:
      P2626 - 008 - Implausible Signal - Intermittent
      Freeze Frame:
      RPM: 1472 /min
      Mass Air / Rev.: 81.8 mg/str
      Voltage: 5.100 V
      Bin. Bits: 00000100
      RPM: 1824 /min
      Mass Air / Rev.: 92.6 mg/str
      Voltage: 5.100 V
      Bin. Bits: 00000100
      Readiness: 0010 0000
      Address 03: ABS Brakes
      Part No: 1K0 907 379 P
      Component: ASR FRONT MK70 0105
      Coding: 0000641
      Shop #: WSC 06441
      No fault code found.
      Address 08: Auto HVAC
      Part No: 5P0 820 047 H
      Component: Climatic PQ35 010 0201
      Address 09: Cent. Elect.
      Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
      Component: Bordnetz-SG H37 1002
      Coding: 008C0F2F00041000001D00000000000000007B075C
      Shop #: WSC 06441
      Part No: 1P0 955 119 A
      Component: Wischer SE350 012 0403
      Coding: 00056272
      Shop #: WSC 06441
      Address 15: Airbags
      Part No SW: 3C0 909 605 E HW: 3C0 909 605 E
      Component: T8 AIRBAG VW8 027 2421
      Coding: 0021560
      Shop #: WSC 06441
      Address 16: Steering wheel
      Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
      Component: Lenksäulenmodul 634 0070
      Coding: 0000002
      Shop #: WSC 06441
      Address 17: Instruments
      Part No: 1P0 920 904 B
      Component: KOMBIINSTRUMENT VO3 0618
      Coding: 0000401
      Shop #: WSC 06441
      Address 19: CAN Gateway
      Part No SW: 1K0 907 530 F HW: 1K0 907 951
      Component: Gateway H10 0120
      Coding: 3D0F0340070203
      Shop #: WSC 06441
      Address 25: Immobilizer
      Component: IMMO VO3 0618
      Address 42: Door Elect, Driver
      Part No: 1T0 959 701 B
      Component: Tuer-SG 024 2352
      Coding: 0000688
      Shop #: WSC 06441
      Address 44: Steering Assist
      Part No: 1K2 909 144 J
      Component: EPS_ZFLS Kl.5 D04 1606
      Address 46: Central Conv.
      Part No: 1K0 959 433 AK
      Component: KSG 0401
      Coding: 19C000BC09000505485B863004CC
      Shop #: WSC 06441
      Part No: 1P0 951 171
      Component: Innenraumueberw.010 4971
      Coding: 00000000
      Shop #: WSC 00000
      Part No: 1K0 951 605 C
      Component: LIN BACKUP HORN H03 1301
      Component: NGS n.mounted
      1 Fault Found:
      01135 - Interior Monitoring Sensors
      004 - No Signal/Communication - Intermittent
      Address 52: Door Elect, Pass.
      Part No: 1T0 959 702 B
      Coding: 0000688
      Shop #: WSC 06441
      Address 56: Radio
      Part No: 1P2 035 152
      Component: Radio BNO 0035
      Coding: 0020400
      Shop #: WSC 06441
      End --------------------------------------------------------------------------------------------------
      Although looking at measuring block 32 the second lambda reading on the vagcom screen shows a constant 0.8% is this correct ?
      Thanx for your help
    5. 10-08-2008 09:22 AM #5
      Help anyone please
    6. Member
      Feb 11th, 2004
      Magdeburg, Germany
      10-08-2008 10:32 AM #6
      Before you do anything else, let the dealer update the ECU to 06A-906-033-FF @ 9435.
