Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 36 to 70 of 173
Thread: APTuning Transmission Rebuild and Upgrade Services!!
  1. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    30 S 5th Ave, Lebanon PA 17042
    MK6 GTI S3+, MK6 Golf R, MK4 R18, Q5 3.0T
    04-27-2009 11:03 AM #36
    Quote, originally posted by MikeMac »
    What kind or warranty do you provide for stock rebuilds?
    All stock rebuilds come with a 3month parts warranty and lifetime workmanship warranty.
    The problem with having a longer warranty is the diff. As most anyone that knows VW trans knows diffs are totally unpredictable
    APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
    aptuning.com - tom@aptuning.com - Facebook - Twitter
    APR Stocking Master Distributor - United Motorsport Distributor
  2. Member vwheadz1's Avatar
    Oct 26th, 2008
    Wilson NC
    96 gti auto
    05-05-2009 02:39 AM #37
    Yes I have a '03 gtiae with cracked and chipped 5th and 6th gear. How much would it be to replace both gears plus sync rings? Do I pay s/h to and from you and about how long would it take? I live in North Carolina 27893. Thanks David
  3. 05-06-2009 01:05 AM #38
    Hi, I have a 99 Jetta 2.0 AEG manual. There is a crackling/clanking noise coming from under the car when it accelerates. The car also hesitates when in all gears but especially when in 1-3. When it first takes off it will hesitate and then just take off out of no where. Shifting in and out of gears is no problem and there is really no vibration. The noise only happens when the car is accelerating but it seems fine when the car has been sitting for a while and fine for the first 2 or 3 shifts and then gets really bad. Also, I took it to a local transmission shop and they said they will not touch VW's anymore. Is this a trans/clutch problem or more of and engine problem? Thanks
    Modified by rocketbails at 10:07 PM 5-5-2009
    Modified by rocketbails at 10:08 PM 5-5-2009
  4. 05-08-2009 08:04 PM #39
    I need to replace my FBW code 02J. I know the case is cracked, and the diff failed. Can you PM the price for a rebuild?
  5. 05-19-2009 08:18 AM #40
    Will a clutch from a 02A/G60 corrado bolt up to an 02M 6speed? if not what will and how much would it cost?
    Modified by jrtatonka at 5:11 PM 5-19-2009
  6. Member DubbleTrubble's Avatar
    Dec 14th, 2001
    Philadelphia
    MK3 GTi VRT, mk4 R32
    05-26-2009 12:35 AM #41
    These guys rock!, I wouldnt take my transmission to anyone else. They out in a pelequin about 5000 miles ago and I have had no problems.
  7. Member BiH's Avatar
    Nov 27th, 2000
    Fairfax, VA
    1990 JETTA VR6T, 2003 JETTA 1.8T, 2010 TOUAREG TDI
    05-29-2009 10:27 PM #42
    can you guys source a 3.94 R&P and tdi fifth for my 02A CCM VR6 trans? I would like it rebuilt with wavetrac as well!
  8. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    06-04-2009 01:59 PM #43
    It has been extremely busy here at the shop lately and don't the time I usually do to get on here.
    So if possible please IM or email any questions it will definitely be much quicker response
    Thanks
    Tom APTuning
  9. 06-15-2009 04:40 PM #44
    i have a 97 glx vr6 needs a rebuild. automatic transmission. 180k on the clock. my other question is how long till i would have to do an engine rebuild? and if you can please pm the price quote for both. thanks.
  10. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    06-17-2009 12:06 PM #45
    Quote, originally posted by PYRO_ZOOTS »
    Please call or email as this is way to involved to reply on a vortex pm
    Thanks
    Tom
    717-272-0916
    tom@aptuning.com
  11. Junior Member Bundschuh's Avatar
    Jan 22nd, 2009
    Washington NJ
    01 Wolfburg 1.8
    06-24-2009 05:37 PM #46
    I recently purchased a 2001 Volkswagen Jetta Wolfsburg Edition. The transmission wound up dying on me the fourth day i had it. (it was a 500 dollar car w/ 171k miles). My dad and i bought an engine and transmission with 80k on it and are looking to replace it ourselves. If you can help me out with step by step instruction how to replace it that would be greatly appreciated.
    - James
  12. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    06-25-2009 05:38 PM #47
    Quote, originally posted by Bundschuh »
    - James
    Sorry cant do that. If your looking to repair the car yourself I would recommend purchasing a bently manual
    Thanks
    Tom
  13. 07-10-2009 02:34 PM #48
    what is a god stage 2 racing clutch for my 04 gti without changing the flywheel
  14. 07-23-2009 06:11 PM #49
    I have a vr6 trans o2a I believe its called and would like to fix my 5th gear because when the trans was in the car it would pop back into neutral, install a 3.94 ring and pinion and a peloquin diff. I have the r&p and diff and would like to know how much it will cost for the parts and labor for you guys to install everything and provide the 5th gear.
  15. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    07-25-2009 08:45 AM #50
    Rebuilds are $300 plus parts(labor for rebuilding trans only not R&R from vehicle)
    For anything more specific please please email or call the shop as in many cases it gets way to long for a reply on vortex.
    Thanks
  16. 07-30-2009 02:39 AM #51
    do you guys have any 5 speed o2j transmissions with a limited slip differential in stock? my old diff decided to commit suicide and take the bell housing with it.
  17. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    07-30-2009 01:03 PM #52
    Quote, originally posted by 1.8turblow »
    We have 02J's and diffs but dont have them already together but can in a day.
    Price varies depending on the trans code. Please call or email to get a specific price.
  18. Member Rabbit Farmer's Avatar
    Sep 21st, 2003
    Earth
    MK1-MK1-MK4-MK4-WRX-Ford
    09-07-2009 01:15 AM #53
    IM'ed on gear options.
    Steve
  19. Member Rabbit Farmer's Avatar
    Sep 21st, 2003
    Earth
    09-08-2009 01:32 PM #54
    Quote, originally posted by Rabbit Farmer »
    Steve
    Need reply. In a bit of a rush as my next race is two weeks away.
    Thanks
    Steve
  20. Member littlenumnuts's Avatar
    Sep 3rd, 2009
    Big Apple
    1995 VW GTI(SOLD) 2002 VW GTI 1.8T(RIP) 2005 VW GTI 1.8T
    09-24-2009 07:12 AM #55
    How much to rebuild 020 5 speed tranny, my reverse is gone.
  21. 09-26-2009 11:53 AM #56
    I believe my reverse idler is bad(ratcheting/rumbling in revers pretty loud but works OK and all forward gears are smooth and quiet)...If it is just this problem, how much over the $300 base price would you guess at? Its a 2000 cabrio stock. Thanks
    Do you put new reverse gears(better than originals) in your rebuilds for this model since they are known to be less reliable due to the engine load on newer vw models that use these tranny's?
    How much for a replacement rebuilt tranny...., if I go that route?
    Modified by Ruditchka at 11:18 AM 9-26-2009
  22. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    10-01-2009 09:25 AM #57
    pm'ed
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
  23. Member arismkv's Avatar
    Jun 16th, 2008
    Bronx NY
    06 MKV GLI
    12-11-2009 06:20 AM #58
    im looking for a stage 2+ or 3. for my mkv gli. i need the full clutch. with flywheel. if its an aluminum one that will be great. let me know on pricing
    Instagram Arismkv
  24. Member Lord_Verminaard's Avatar
    Apr 6th, 2004
    Mt. Vernon, OH
    01-27-2010 03:27 PM #59
    Question, want to know what you guys recommend for modifications to an 02J tranny.
    Will be in a Mk1 chassis, ~1800lbs full weight
    Support 250-max hp, 300-ish ft-lbs torque,
    Be used for some distance driving but mostly Track and Auto-x for fun.
    I don't need custom ratios or dog-engagement, but I want the tranny to last and be reliable.
    Cost is always an issue of course, but what would you recommend to fill this role? Obviously a diff, but what about synchros, what weak parts can I eliminate, etc...
    Thanks for the information. You can PM me if you want.
    Brendan
    '81 Scirocco 'S <-- TDI swap, someday...
    '05 New Beetle TDI
    '86 Golf Diesel, built w/ turbo (Wife's car)
    '93 Corrado SLC <-- currently under the knife...
  25. Member cuesoccer24's Avatar
    Nov 15th, 2009
    South Carolina
    1996 VW Jetta GLS
    02-05-2010 03:47 PM #60
    would it be possible to swap a manual trans into an automatic jetta gls 1996?
  26. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    02-06-2010 11:15 AM #61
    Quote, originally posted by cuesoccer24 »
    Yes
  27. Member cuesoccer24's Avatar
    Nov 15th, 2009
    South Carolina
    1996 VW Jetta GLS
    02-07-2010 03:17 PM #62
    how would i go about doing that and what would it cost me?
  28. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    02-07-2010 03:47 PM #63
    We can do the swap using used 020(what originally came on a manual 2.0) parts for about $1750
    or
    We can do the swap using all new parts with 02A cable shift trans for $3500
  29. Member
    Feb 20th, 2009
    Missoula, MT
    05 PG GLI
    02-14-2010 07:34 PM #64
    i am looking to get an audi a4 1.8t (current VW GLI) but i think i would miss my 6 speed a lot. is there a 6speed transmission i can swap into an a4 1.8t without too much hassle? and how much would that set up usually run?
  30. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    02-17-2010 03:33 PM #65
    Quote, originally posted by ryans05gli »
    Alot of B6 A4's can be had with the 6speed. If swapping to a 6spd its not that terribly difficult but its not cheap as they are not that easy to come.
  31. Member steve-o 16v GLI's Avatar
    Jun 25th, 2005
    Lancaster PA
    94 Jetta GL 1.8t(FS/parting) 04 Audi TT 225 Roadster
    02-26-2010 06:55 PM #66
    Bump for some great guys.brought my trans to them with no notice.They tore it down in front of me to let me know where I stood, and they rebuilt it in less than 4 days.Sourced me a 3.3 ring n pinion and a quaiffe.They will also be doing the 02a swap to replace the diff vomitting 020 in my mk3 1.8t.lol Thanks again guys
    It's his right to go off on whoever he wants. Etiquette isn't a requirement in America. It's his right as an American to be a douchebag. :-) You don't hate America, do you?
  32. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    03-05-2010 05:50 PM #67
    Thanks for the positive feedback steve
  33. 03-11-2010 06:46 PM #68
    Just a question, and I don't expect you to fix my car for Free. My 1990 . 90 Quattro 20V is very sluggish in first gear, it is strong 2nd through 5 but 1st is weak, does this sound like a transmission type problem to you?
    MB
  34. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    03-12-2010 10:19 AM #69
    If by sluggish you mean slow it sounds like a power/running issue nothing to do with the trans.
  35. Member VDUB MKIV's Avatar
    Jun 13th, 2008
    North Carolina
    1996 GTI VR6
    03-14-2010 09:22 PM #70
    Hey would a 1.8T EHA trans from a 04 GTI bolt up to my 2003 2.0 Mk4? I got the trans for free and all it needs is a bearing replaced and I was considering having you guys rebuild it for me. Please let me know when you get a chance.
    Thanks.
    Modified by VDUB MKIV at 6:23 PM 3-14-2010
