VWVortex.com - APTuning Transmission Rebuild and Upgrade Services!!
    Page 4 of 10 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 234
    Thread: APTuning Transmission Rebuild and Upgrade Services!!
    1. Member eip18t's Avatar
      May 3rd, 2007
      SE PA
      04 GTi 1.8t/APR/k04/Fun
      05-03-2010 05:10 AM #76
      will 02j casing work with 02m? both 1.8t
      Pretty sure I spent more fixing it than I did to buy it. Hmph.
    2. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      30 S 5th Ave, Lebanon PA 17042
      GTI s3+ 4mo, R s3+, MK4 R18 s3+, '74 100
      05-04-2010 11:13 AM #77
      Quote, originally posted by eip18t »
      will an 02m accept an 02j casing? both 1.8t
      Nope
      APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
      aptuning.com - tom@aptuning.com - Facebook - Twitter
      APR Stocking Master Distributor - United Motorsport Distributor
    3. 05-22-2010 11:06 AM #78
      Hey guys
      My transmission feels really loose, and the shifter wobbles around and has way too much play. Someone told me its probably the bushings, can you guys sell the parts I need, I cannot seem to find them anywhere and pulling and shipping from GA is not really feasible.
      Incidentally, worst case scenario its not bushings and I need a new tranny roughly how much am I looking at ?
      Thanks for your help
    4. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      05-25-2010 10:25 AM #79
      Def would need more info as I need to know car, trans, etc.
      Unless its an 020 there really are not common bushing failures to say yea replace that. But if you can get me some more info ill try to help best I can online.
    5. 06-05-2010 10:48 PM #80
      hey i have a 2.0 with a 020 che trans in it. first to second shift isnt straight back i have to wiggle to find second then when im shifting from second to third and i push up on the shifter in third to hard it grinds fourth grinds intermititly and fifth is ok but reverse has a chatter/grinding sound when gaining speed. while i was in the shop the other day it was stuck in reverse!! then i lost it for a second but it came back. do you think this is an internal problem or a linkage/adjusting problem in the shifter or in the engine bay? if it is internal how much to rebuild?
    6. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      06-08-2010 11:13 AM #81
      It sounds like something internal judging by the grinding and getting stuck in gear, BUT what conditoion are the bushings and linkage in?
      You can try disconnecting the linkage and see if it shifts better/easier
      Rebuilds are $300 labor plus parts
      Thanks
    7. 06-08-2010 11:11 PM #82
      I have a 2001 Jetta 1.8T wolfsburg. Today it just quit going into first gear. It goes in every other gear just fine. Although reverse grinds almost every time i shift it into it and the other gears grind sometimes too even if the clutch is to the floor. I have a kinetics 6puck clutch with their lightweight flywheel. Transmission is out of a beetle when my last one went out.
      I go to school and need as little downtime as possible. Could I arrange an appointment to bring the tranny to you out of the car if you think you know what the problem is? I live in akron oh so pa isnt that far of a drive. maybe like 6 hours tops depending on where you are.
      Thank you
    8. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      06-11-2010 05:03 PM #83
      yes we can defeinelty do that. Sound like at least the 1st/2nd gear selector hub and maybe some other stuff
    9. Member Schnook's Avatar
      Mar 3rd, 2009
      Eau Claire
      04' GTI 1.8T, 2013 Ram Hemi, 2002 Jetta GLS (about to part out)
      06-28-2010 12:17 PM #84
      Hey APTuning, I got a 04 1.8t with a AWP engine code and a 02Jtransmission with an EHA code with 1st not engaging and believe to have 1st and 2nd syncros gone due to downshifting into 1st would grind as well as shifting to second on a hard pull before 1st not being found. So I'm thinking the gears are worn as well. I am also very insterested in upgrading the diff to a peloquin. Any way to get a rough estimate or what do i need to do to get this ball rolling?
    10. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      06-29-2010 10:09 AM #85
      Really cant give an estimate on the repairs as I would need to see the extent of the damage first.
      The diff would be $795 or $845 depending on if yours is an early or late style, plus $300 for install and repair of the trans(parts would be additional.
      Thanks
    11. Member Schnook's Avatar
      Mar 3rd, 2009
      Eau Claire
      07-12-2010 06:35 PM #86
      Thanks, I talked to Michael and he gave me a better understanding on whats going to happen. Other than that, the crate came, pulled the tranny this weekend and dropped it off at the UPS store today
      Oct 7th, 2000
      Detriot Area, Mi
      1997 DE GTI VR6T
      07-27-2010 09:36 PM #87
      Dear APTuning:
      Here is the situatuion. I have a VRT running 23psi daily and I'm done replacing 3rd gears due to breakage and was wondering what could be recommended. I've been reading all the posts I can find from those using the G Force gearsets and I think this is the way to go. I'm still trying to decide either the 2.67 or 3.0 1st-4th gear set; any input? Because this is driven as much as possible I would opt for the mirco polishing for greater durability.
      I was wondering what it might cost for the following-
      1. Send you a used O2A CCM (trans was in decent working order before removal)
      2. Replace any worn/damaged internals (i.e. bearings, syncros, ect)
      3. Installation of APT gearset 1st-4th (best ratio for power goals)
      4. Intall Peloquin (removed from broken trans) with new bearings and ARP fasteners
      Give me your best options.
      Thanks,
      Tyler
      248-703-0726 cell
    13. Member shgauar_jp's Avatar
      Mar 1st, 2009
      2004 .:R32
      08-08-2010 09:44 AM #88
      i have a pretty big project coming up for my 2000 vrt, so i figured while the engine is ripped apart i might as well pay some attention to the tranny.
      i dont know much about transmissions yet, so im not exactly sure what im looking for. but i just want to replace all bearing, seals, or anything else that would be wise to replace while its out. also if there is anything i should replace due to increased power (max 450hp)
      im a litte far away to bring it in to you guys, but i was wondering how much you would charge for anything i need.
    14. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      08-10-2010 03:17 PM #89
      Quote Originally Posted by YETIface View Post
      hi i have a 1999.5 Audi 1.8t quattro, and was wondering what I would need and approx. how much it would cost to do a 6 speed transmission swap, given i already have a 5..? any help would be great..
      there are somewhat involved and would need the trans, shiftbox, drive shaft, subframe, mounts/brackets, front axles, and spindles.
      this is worst case scenario for the most part as depening on build date what not of the car some may not need subframe, mounts, or spindles. Ive done a couple of these swaps all on the pre '99.5 cars and have needed everything but there are 3 different combinations and some dont need all the parts.
      Cost would be somewhere in the $4000 range if all parts are needed.
      hope this helps.
    15. Semi-n00b
      Aug 22nd, 2009
      west coast
      2000 VW GTI VR6
      08-18-2010 03:58 AM #90
      quick question, i have a 2000 gti vr6 (12v head) that i need a new tranny for. I was hoping there was a 6 speed that would bolt up, I've seen gear sets for sale but would rather buy a complete one. So my question or questions are what ones bolt up? do you have them or where can i find them? what else if anything is needed for the swap? and price or prices? thanks
    16. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      08-18-2010 12:02 PM #91
      Im'd
    17. Member v.dubluv's Avatar
      Jan 4th, 2009
      Bklyn..NY
      92cabby1.8l 04getta2.0l 02allroad2.7T
      08-21-2010 01:13 AM #92
      i need a price on a 5 speed transmission (020).for 92 cabriolet.it grinds when shifting 1st to 2nd and pops out of 5th
    18. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      08-24-2010 06:29 PM #93
      Quote Originally Posted by v.dubluv View Post
      $550 plus core, have plenty in stock
    19. Junior Member DowJetta1998's Avatar
      Dec 7th, 2009
      Charleston, SC and Warwick, RI
      2012 mk6 TDI Golf
      09-16-2010 08:39 PM #94
      Price for a rebuilding a 5 speed manual and cost of shipping etc.
    20. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      09-17-2010 03:56 PM #95
      Quote Originally Posted by DowJetta1998 View Post
      $300 plus parts, shipping would be $100
      Thanks
    21. Member Vdubed13's Avatar
      Jun 6th, 2008
      WEST VIRGINIA
      Bagged -Big Turbo -MK4 and Slammed B6 A4 1.8TQ
      09-17-2010 07:00 PM #96
      i have 01 jetta 5speed wanted to know how much it be if i bought lsd and had you all do the work ill bring the tranny to you and you could ship it back
      Thanks
    22. Member GinsterMan98's Avatar
      May 19th, 2008
      Panama City FL
      96 GTI VR6 08 Hyundai Santa Fe SE
      09-20-2010 01:20 PM #97
      Who do you source your bearings through? Having some trouble finding a few maybe you could help me out? PM me if you can help, Thanks.
    23. 09-20-2010 06:59 PM #98
      I have some concerns about your G-Force sets.Forum Link Page 1-4. Any feedback would be appreciated. Thank you
    24. Forum Sponsor Tom@APTuning's Avatar
      Feb 4th, 2004
      09-21-2010 12:32 PM #99
      Quote Originally Posted by mikemikemike View Post
      Ideally please call teh shop to discuss anything in depth or technical on the gearsets as it would make for quite alot of typing.
      Also those posts are somewhat old and have been a couple revisions and updates to the gearsets.
    25. Member v.dubluv's Avatar
      Jan 4th, 2009
      Bklyn..NY
      09-26-2010 04:27 PM #100
      Quote Originally Posted by APTuning View Post
      Is it possible for me to speak with someone tomorrow about making this purchase. Also I need a 16 valve lightened flywheel but does that mean I need a double pin pressure plate? Please if you know give me a list of what else I need besides the flywheel. I'd like to have everything needed to install tranny right away. Thanks for all your help. Gilbert
      no one has gotten back to me.... (i was told tom would!)
