Page 5 of 5 FirstFirst 1 2 3 4 5
Results 141 to 173 of 173
Thread: APTuning Transmission Rebuild and Upgrade Services!!
  1. 11-12-2011 02:04 PM #141
    I just replaced my clutch/flywheel in my '04 jetta tdi. Thanks to you all, I was able to undertake this task. I have one problem. Before replacing the clutch, I was having trouble with 5th gear and forced it the shifter into 5th. Well, it did not grab and remaind in neutral. Now that the clutch has been replaced, all gears work great except for 5th which remains in neutral. Anyone have any ideas why?
    Thank you for all you assistance prior to this
  2. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    30 S 5th Ave, Lebanon PA 17042
    MK6 GTI S3+, MK6 Golf R, MK4 R18, Q5 3.0T
    11-14-2011 10:38 AM #142
    Quote Originally Posted by sole7718 View Post
    Sounds like something may have broke with the linkage when it was forced in.
    I would pull the end cap off and see if there are any broken pieces in there
    APTuning LLC, 30 s 5th Ave, Lebanon PA 17042, (717)272-0916
    aptuning.com - tom@aptuning.com - Facebook - Twitter
    APR Stocking Master Distributor - United Motorsport Distributor
  3. 11-16-2011 08:55 AM #143
    By the end cap, i imagine you mean the cover at the end og the transmission near the driver side front wheel. I did open it and when i spin the wheel, the gear turns while in neutral. There are no loose pieces in there and nothing broken as far as I can tell. Do I need to remove the transmission again? Thanks again for any advice
  4. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    11-16-2011 10:31 AM #144
    Your gonna have to put it in 5th and see what is happening.
    In nuetral only the one gear should spin free, do they both spin free?
  5. 03-11-2012 09:10 AM #145
    What is your suggestion to fix the common torque converter lock up clutch error code on Tiptronic transmissions?
  6. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    03-12-2012 11:48 AM #146
    Quote Originally Posted by vtraudt View Post
    sorry we don't do much with the autos but I believe the issue is usually the convertor or pump.
  7. Moderator PsyberVW's Avatar
    Jul 10th, 2000
    California
    Blog Entries
    5
    03-21-2012 03:54 AM #147
    Quote Originally Posted by Tom@APTuning View Post
    may be something with the shifter linkage/cables but that would be the lucky thing, other more likely issue is probably something with the 3/4 selector hub
    I had the same issue up until december when something snapped and the car got stuck in 3rd gear. I haven't seen the car since then, and just this week had a chance to check it out. I'm fearing it's this problem and will need a rebuild - just hoping it didn't leave loose pieces in there to damage the rest of the components
  8. 03-31-2012 02:16 PM #148
    My wife's 99 Cabrio Auto with 246k miles has a problem with the diff. It shifts ok, but the humming sound get louder with speed. Do you sell the differentials separate from the trans? If so, how much? If not, do you rebuild them and at what price?
    Thanks,
    Nacho
    Sent from my myTouch_4G_Slide using Tapatalk
  9. n00b
    Apr 3rd, 2012
    Hanover, Pennsylvania
    1997 VW 2.0 GTI
    04-11-2012 10:48 AM #149
    Do you guys have conversion kits or do you guys do transmission swaps? I wanna convert my auto to a manual. How much would it cost? 97 2.0L MK3 GTI.
    It's gonna scrape!
  10. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    04-11-2012 12:58 PM #150
    Quote Originally Posted by Scrapin94 View Post
    We can do conversions, please email me - tom@aptuning.com - to get a quote on something of that nature
  11. Semi-n00b
    Feb 27th, 2012
    Fort Worth, TX
    1985 VW Cabroilet Wolfberg Edition
    05-04-2012 10:25 AM #151
    My daughter was driving her 85 Cabriolet last week and she lost 4th gear. She told me there was no loud kind of sound. She was shifting from 3rd to 4th and missed 4th and hit 2nd. She then shifted back to 3rd and proceded to 4th and there was no 4th.
    The next day I re-bushed the linkage and replaced the linkage rods. I was not too worried about the "no 4th" gear problem thinking that when I replaced all the shifter linkage bushings, it would go away.
    I finished up the linkage bushings and adjusted the shifter and I have the same problem. The shifter does feel better than it did though....
    I manually moved the selector through each gear and the tranny did engage in all gears but 4th. There is a different feel when you manually select 4th compared to the other gears. You can hear and feel the shifter move the gears on all but 4th. When it goes to move to 4th, it feels like it is just the selector moving, nothing else.
    When the car is moving, you can't move the shifter into any of the other gears without the clutch but it will fall right into 4th no problem.
    I found two 9a's, a FN and a FF tranny but I like the idea of rebuilt tranny better than a used tranny, any chance of getting a price quoate to rebuild or swap the 9A?
  12. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    05-14-2012 04:19 PM #152
    Monday afternoon bump
  13. 06-04-2012 01:05 AM #153
    I have an 2002 vw gti vr6 5-speed, 02j I believe.
    The pendulum mount point has worn lose and had to be heliocoiled several times, It is now 3/4 inch. Can you brace the transmission in another location or reinforce the hole? I'm afraid that if I wear it out again I'll dig into the case.
    I have VF mounts all around. Some people have said the pendulum mount is to stiff for this application and wheres the hole.
    What can you do for me and how much?
  14. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    06-04-2012 11:52 AM #154
    Quote Originally Posted by poopsonu View Post
    Ive seen this happen but not anything specific to the the mounts.
    It can be fixed, please email me and I can get a quote together tom@aptuning.com
  15. 06-04-2012 01:47 PM #155
    E-mailed Thanks for the fast response on here.
  16. 07-15-2012 09:40 PM #156
    I've got a whirring noise coming from the gear box. I did a gear oil flush with it as per a tech bulletin i had come across. I'm not sure if the gears are going bad or if its the diff. any ideas?
  17. 07-15-2012 10:01 PM #157
    Quote Originally Posted by supersporttdi View Post
    I had good luck (also with synchros) by adding 'moly'.
  18. 07-16-2012 10:55 AM #158
    Part of the problem is I don't know where the whirring is coming from. Is it the diff or is it the shift gears themselves? I found some shavings when I went to drain and replace the fluid. Gear box has about 100k miles on it now.
  19. Junior Member
    Apr 1st, 2012
    northern virginia
    96 MKIII Jetta Trek. MKIII Jetta Vr6 (race build all motor)
    07-25-2012 06:02 PM #159
    I have a 1996 MK3 Jetta Trek 2.0L that now has a quickly failing transmission in it and i would like to have it rebuilt with better than stock parts. I plan to upgrade my engine or atleast its performance making the car have much more hp than stock obviously. What would it cost to have you guys do a complete rebuit of the engine and tansmission to make this car almost untouchable by other tunners on the street?
    And I would also like a quote on just reubiling the tranmission with better than stock parts and an idea of how long this would take. OR..What would it cost to have you build me a new better than stock tranmission so i can continue to drive the car while its built? Would you offer any discount to me if i gave you the old tranmission out of the car once i recieved the new one and had it installed?
    Thank you
    Mike
    Please feel free to call with any questions, this is a serious inquiry
    703-945-8691
    DüB-CHKD
  20. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    07-26-2012 01:39 PM #160
    Quote Originally Posted by mtymowczak10@gmail.com View Post
    Thank you
    Mike
    703-945-8691
    Please email me as this is way more in depth and beyond the scope of this thread
  21. Junior Member hashagen7's Avatar
    Feb 5th, 2009
    berwick PA
    Kellison, 69 ghia, 66 bug, manx(real one)74 sedan, 74Baja, 63 notch, 93 Eurovan, 01 vr6 Jetta
    10-28-2012 08:05 AM #161
    Will a 5 speed manual from a 1995 vr6 jetta work in a 2001 vr6 jetta?
    i cant feel my toes
  22. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    10-29-2012 09:02 AM #162
    Quote Originally Posted by hashagen7 View Post
    No
  23. 11-15-2012 10:22 PM #163
    I am completely rebuilding the shifter on 91 GTI. The book calls for Molybdenum Disulphide grease.
    I have some paste from Hondaline that is 60% MoS2, however it cautions against use on plastic. Since the shift ball is essentially a plastic bearing, I am concerned. Anyone has any experience to share or advice what I can use safely long term.
    Thanks
  24. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    11-16-2012 12:53 PM #164
    We typically just use standard heavy duty automotive grease, the shift linkage isnt that high tech and have not seen an issue by using different kinds.
  25. 12-10-2012 11:23 AM #165
    Just sent my transmission to these guys last week. So far it has been a good experience with them. Tom has always taken my calls and answered any questions I have had. I will def keep you guys up to date when I get my transmission back. So far so good.
    Btw Tom I just sent you that email with the part that I am needing to replace on the transmission.
  26. Member Three3Se7en's Avatar
    Jul 1st, 2007
    Mississippi
    02 337. 08 F150
    12-27-2012 06:10 PM #166
    Emailed with some questions
    2.1L, 1000cc, Maestro, CompTurbo 5558, CTS, IE intake, Scat rods, more to come..
  27. Junior Member cobra1's Avatar
    Nov 10th, 2012
    Lakewood, Co
    1987 scirocco 16V wolfburg
    12-29-2012 12:43 PM #167
    I'm looking to up grade it to a new ver any help or the cost of a rebuilt
  28. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    12-29-2012 01:11 PM #168
    Quote Originally Posted by cobra1 View Post
    Im sorry you are upgrading to a new what?
  29. 01-09-2013 08:18 AM #169
    Finally got my new transmission into my 95 Jetta. So far so good. Tranny seems to be great. Mine was so busted that Tom told me I would have to replace it, so he sent me a new one. He helped me out with any question I had and most of the time it was in a timely fashion. Would def recommend these guys. Thanks Tom.
  30. 01-10-2013 08:50 PM #170
    Hi, I am looking for a new or rebuilt 2H / 4K like close ratio 020 transmission for a MK1 8V or a reference to a reputable source. Thanks.
  31. Semi-n00b
    Mar 4th, 2008
    Marietta, PA
    88 Jetta GL (oh yea!)
    02-02-2013 05:46 AM #171
    Quote Originally Posted by evileagl View Post
    Thanks
    Why not rebuild with smartshift from USRT no need to worry about corrosive greases
  32. Member SlammeDEur0's Avatar
    Oct 29th, 2012
    L.I Ny
    94 MK3 jetta
    05-19-2013 03:35 PM #172
    2002 gti 1.8t o2j trans
    I can't get into 1st gear , should I send it to you guys for a rebuild , or its this a much less expensive fix
    All other gear work fine including reverse- no slips no grinds nothing unusual
  33. Forum Sponsor Tom@APTuning's Avatar
    Feb 4th, 2004
    05-20-2013 09:23 AM #173
    Quote Originally Posted by SlammeDEur0 View Post
    Def gonna need a rebuild, sounds like the 1/2 hub is damaged. Feel free to contact me tom@aptuning.com and we can arrange getting the trans to us.
