    Results 1 to 21 of 21
    Thread: Wheel Torque Specs
    1. Member Ben.Reilly's Avatar
      Jun 20th, 2008
      RI
      2009 Wrong Wheel Drive Crapalier
      10-12-2008 03:54 PM #1
      Hello Everyone!
      I was wondering how important it was to properly torque your wheels when rotating the tires, or mounting the spare? I usually just tighten them, but a friend of mine mentioned that you should use a torque wrench and properly torque the wheels to its specifications.
      Is this true? If so, where could I find the proper torque specs for my car (2009 Chevy Cobalt SS).
      Thanks!
      F1
      RED BULL Racing Formula One
      Final Gear
      "Here's a couple things America got right; cars and freedom"
    2. 10-12-2008 03:55 PM #2
      naw dawg.
      Just jump on it or something.
      Modified by subwoffers at 12:59 PM 10-12-2008
    3. Member Golfotron's Avatar
      Apr 16th, 2006
      Milton, ON
      97 Golf GL, 10AE Miata
      10-12-2008 03:55 PM #3
      It could be in your manual, for my Golf it's 80ft/lbs
      you know why we should use a tq wrench; over tighten and you risk warping the rotors and under tighten...well you know, the wheel usually wins the race.
      Modified by Golfotron at 3:57 PM 10-12-2008
    4. 10-12-2008 03:57 PM #4
      If you really need to Tq them on , you would think your car would include a Tq wrench to change the spare tire ya? You know why there is no tq wrench?
    5. Member Arachnotron's Avatar
      Jun 22nd, 2002
      Friendswood, TX
      2002 Camaro Z28, 2012 GMC Sierra 6.2
      10-12-2008 04:08 PM #5
      I torque the lugs to spec on my Camaro to 100ft/lbs. If you have a torque wrench, why not?
    6. 10-12-2008 04:15 PM #6
      80-100lb/ft on most cars. Stepping on the lug wrench will be safe unless you weigh under 80 lb's
      Oh and don't worry about over torquing it, you can really only do that with an impact gun (most of the time).
    7. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      10-12-2008 04:21 PM #7
      you can always call a dealer
      thats what i did when i needed to know what to torque them to on a mercedes
    8. Member lowredcabrio's Avatar
      Oct 21st, 2004
      Saskatchewan
      1990 BMW 325i
      10-12-2008 05:26 PM #8
      Check your owners manual. Over tightening lugs isn't a problem with steel wheels but with alloy wheels, you can actually damage them. Unlike steel, alloys will not spring back after over tightening, and you can actually crush them.
      My jetta goes to 88ft/lbs. It's not hard to over do. Do it right and learn it the easy way. Buy a torque wrench or find a buddy with one.
      3 + 3 + 3 = NEIN!
      Mar 24th, 2007
      10-12-2008 05:56 PM #9
      Lug tightening torque depends on the lug stud/bolt's thread diameter among other factors.
      So, generally speaking, the larger the lug stud/bolt diameter the higher the tightening torque.
      That all said...Discount Tire's Wheel Torque Chart
      Modified by Dextrobrick at 4:58 PM 10-12-2008
    10. 10-12-2008 05:58 PM #10
      Quote, originally posted by Ben.Reilly »
      Hello Everyone!
      Thanks!
      had my wheels come off many times before...got a torque wrench nd do them to 90lb-ft (I run tuner lugs)
    11. Member smetzger's Avatar
      Oct 21st, 2004
      MD
      2009 Odyssey | 2013 Fit | 99.5 Cabrio + BBM Stage 3 + Shine | 98 Golf 2.0 Beater | 02 Mazda Protege
      10-12-2008 06:00 PM #11
      Quote, originally posted by Golfotron »
      Actually its 81 ft/lb for the VW & 80 for the typical Honda. Thus confirming the rumor that VWs have more torque than Hondas
      Nothing to see here move along.
    12. 10-12-2008 06:26 PM #12
      Quote, originally posted by smetzger »
      Varies by generation.
      3 years back, I threw a "half brick" 50 feet high and it got stuck in the fruit tree.
    13. Member DIAF's Avatar
      Sep 17th, 2005
      2012 Evo GSR
      10-12-2008 07:01 PM #13
      Quote, originally posted by PDong »
      yup, 89 for my mkiv
    14. 10-13-2008 02:32 PM #14
      Quote, originally posted by DIAF »
      Carrera GT 2004-06 407 ft-lbs
      Is that a typo?
    15. Member nobledub's Avatar
      Feb 3rd, 2006
      Orlando
      2012 Honda Fit
      10-13-2008 02:34 PM #15
      Air ratchet always puts them on just right.
    16. Geriatric Member SSLByron's Avatar
      Jul 29th, 2004
      Annapolis, MD
      10-13-2008 02:35 PM #16
      Quote, originally posted by XDrewX »
      Is that a typo?
      Looking for a ratty Miata? My runner and parts car are for sale. PM for details.
      http://www.speedsportlife.com
      Quote Originally Posted by mhjett View Post
      4+ pages and at least 1 death threat in a compact-car comparison test thread - oh wait, this is TCL.
    17. Member DIAF's Avatar
      Sep 17th, 2005
      2012 Evo GSR
      10-13-2008 02:40 PM #17
      Is that a typo?
      I posted nothing about a Carrera GT...where did you get that from?
    18. Geriatric Member SSLByron's Avatar
      Jul 29th, 2004
      Annapolis, MD
      10-13-2008 02:41 PM #18
      He pulled it out of the chart from a couple posts up.
    19. Member VDubby18's Avatar
      Oct 15th, 2007
      Fort Worth, TX.
      10-13-2008 03:36 PM #19
      Call the local tire shop.
    20. 10-13-2008 03:48 PM #20
      it is a single center nut - they give you a gear reduction wrench with the car
    21. Member blue70beetle's Avatar
      Sep 23rd, 2004
      Lafayette, IN
      '00 XJ, '08 N* SRX4 (hers), '70 Beetle (rusty and parked)
      10-13-2008 03:53 PM #21
      Quote, originally posted by VDubby18 »
      Yeah, they'll tell you to check it with a clicker, which is bootleg.
      I've seen it done many times, and no, it doesn't really tell you much of anything about whether the wheel is properly torqued. In fact, it will click if the nut/bolt (depending on your car) is slightly under torqued, and it will click if the nut/bolt is grossly over torqued.
