VWVortex.com - 02M Steel Billet Flywheels, Sachs & Clutchnet Clutch Kits -Free Ground Lower 48
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 144
    Thread: 02M Steel Billet Flywheels, Sachs & Clutchnet Clutch Kits -Free Ground Lower 48
    1. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      92 Corrado SLC , 92 Audi S4
      10-31-2008 03:35 PM #1
      Thank you for the replies. These are in stock now.
      Call for info or to order.Direct purchase links below.
      $544.99 FX100 Heavy duty pressure plate. Steel-backed organic lined disc. Dampened disc
      $599.99 FX250 Heavy duty pressure plate. dual friction Organic/Fiber Tough disc. Dampened disc
      $699.99 FX300 Heavy duty pressure plate. segmented Kevlar disc. Dampened disc
      $699.99 FX350 Heavy duty pressure plate. Fiber Friction lined disc. Dampened disc
      $649.99 FX400 Heavy duty pressure plate. 6-puck ceramic. Dampened disc
      Cost $1,199.95
      DC 02M Stage 2+ Clutch kit W/SBF
      ON SALE Cost $324.95 FST 240mm L/W STEEL BILLET Flywheel 20 pounds for 02M 6-Speed
      Cost $374.95shipped ground same as alloy ones below.
      FST Steel Billet Flywheel Single Mass steel billet Flywheel. 16.5 pounds with starter ring gear. Comes with 10 Flywheel and 6 pressure plate bolts.
      02M FST STEEL BILLET L/W Flywheel $374.95 Shipped Ground
      FST Alloy Flywheel Single Mass Flywheel 9 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
      02M FST Alloy L/W Flywheel$374.95 Shipped Ground
      Autotech Alloy Flywheel Single Mass Flywheel 9 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
      02M Autotech Alloy L/W Flywheel$374.95 Shipped Ground
      $489.95 OEM Dual Mass Flywheel Dual Mass Flywheel. 27 pounds with starter ring gear.
      02M Dual Mass Flywheel $489.95 Shipped Ground
      $374.95 LUK 02M Clutch Kit Includes Pressure Plate, Disc,Release bearing and alignment tool.
      02M LUK Clutch Kit $324.95 Shipped Ground
      $359.95 Sachs 02M Clutch Kit Includes Pressure Plate, Disc and Release bearing.
      02M Sachs Clutch Kit $359.95 Shipped Ground
      -----02M Clutch Kits 6 Speed-----
      ------Full Clutch Kits contain clutch disc, pressure plate, Steel Billet Flyweels, flywheel and pressure plate bolts,Release bearing and alignment tool----
      $764.95 R32 Clutch kit with 17 lbs Steel Billet Flywheel also fits 24V VR6
      $769.95Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc, 10 flywheel & 6 pressure plate bolts, OE release bearing.
      STAGE 1 KIT
      $674.95Stage 1 OEM LUK Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM LUK Pressure Plate, LUK Unsprung Disc,10 flywheel & 6 pressure plate bolts, LUK release bearing.
      STAGE 1 KIT
      $939.95 Clutchnet Stage 2 CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Full face Disc,flywheel & pressure plate bolts, OE release bearing.
      CLUTCHNET STAGE 2 KIT
      $939.95 Clutchnet Stage 3 CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet 6 puck Disc,flywheel & pressure plate bolts, OE release bearing.
      CLUTCHNET STAGE 3 KIT
      The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site. Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
      Email is better than IM
      sales(AT)fourseasontuning.com*
      Thanks for looking.
      James
      http://www.FourSeasonTuning.com
      :: www.FourSeasonTuning.com
      :: United Motorsport-Wossner-Supertech-Clutchnet-DXD/SBC-Koni-Stoptech-Racingline-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
      :: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
    2. Member Ld7w_VR's Avatar
      Apr 21st, 2006
      Fairfax, VA
      2003 Gti, 2001 Wolfsburg
      11-04-2008 10:28 PM #2
      I would say its a good idea. I would consider it once mine has to be replaced. Singles mass steel flywheel instead of alloy and still cuts a good amount of weight off the crank.
      The Elite 24v VR6 Club: Member #268 "Like 6 cylinder of 15 degree sex"
      (_fishbowl society_)
    3. Member GLgod's Avatar
      Aug 23rd, 2006
      North Wales, PA
      '04 Pathfinder, '08 Mini
      11-05-2008 08:57 AM #3
      I think this is a great idea! I will be all over this in about a month if it is available.... I've wanted a LWFW for awhile, but the 9lb alum ones are a little too light for my DD... How do i know? Try starting and stopping up a snow covered hill
      The Elite 24v VR6 Club: Member #245
    4. Member GRN6IX's Avatar
      Jan 2nd, 2003
      East Windsor, CT
      2012 GTI, 2017 Tiguan
      11-05-2008 09:57 AM #4
      Very interested
    5. Member rajvosa71000's Avatar
      Jun 8th, 2004
      '04 VF Stg.2 24v GTI VR6, '10 B6 Passat 2.0T, '14 B7 Passat TDI
      11-05-2008 08:10 PM #5
      I like that steel LWFW, 16lbs. would be perfect IMO
    6. Awaiting Email Confirmation Veedub_junky's Avatar
      Aug 13th, 2005
      11-09-2008 03:09 PM #6
      I'll be sending you an email. I'm guessing you have it (or can), but I didn't see an OEM sachs clutch option for the 24v o2m on the website. I'll probably be in the market very soon, and it'd be nice to pick up a complete kit - billet steel FW with sachs clutch is what I'm looking at [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member Fugee's Avatar
      Aug 22nd, 2003
      Las Vegas, NV
      06 VW 95 GMC
      11-09-2008 03:35 PM #7
      Thats nice but I preffer no chater. Cant beat the DUAL mass
    8. Junior Member MickyV5's Avatar
      Dec 7th, 2002
      11-09-2008 04:26 PM #8
      Whats the max. torque for the steel flywheel ?
    9. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      11-09-2008 08:42 PM #9
      Quote, originally posted by Veedub_junky »
      A kit like this will be made when the 24V 02M flywheels are ready. The clutch kits are the same, the flywheel is the difference.
      $639.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,10 flywheel & 6 pressure plate bolts, OE release bearing.
      STAGE 1 KIT
      Modified by FourSeasonTuning.com at 2:35 PM 11-12-2008
      Modified by FourSeasonTuning.com at 3:24 PM 2-6-2009
    10. Awaiting Email Confirmation Veedub_junky's Avatar
      Aug 13th, 2005
      11-10-2008 05:55 AM #10
      Sweet - I'll probably be ordering exactly that within a few weeks, depending on how long my slave lasts
    11. Member GLgod's Avatar
      Aug 23rd, 2006
      North Wales, PA
      11-12-2008 09:03 AM #11
      So what exactly is the difference between the stage 1 Unsprung Disc and the Stage 1+ Clutchnet Sprung Disc?
    12. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      11-12-2008 06:38 PM #12
      The solid hub disc's are used with dual mass flywheel from the factory, the disc material is riveted/bonded to a segmented steel material ( where the sprung hub below has a larger steel backing more surface material for the friction material to bond to). This solid type is the OEM disc from your car.
      Sprung Hub steel backed disc's were designed for maximum burst and rotational strength. The sprung hub's six springs lessen shock of engagement, Sprung hub discs (similar design) are also used on the Audi S4/RS4 (2000-2004 era) also 240MM and a 6 spring hub, even with a dual mass flywheel. The RS4 with a factory modified LUK pressure plate and stock S4/RS4 sprung hub disc was rated for 380HP. The sprung hub disc is also used from the factory on almost all single mass clutch setups.The most used street type disc is a sprung hub for daily driving.
      Enclosed is the Kit with the Clutchnet sprung hub disc.
      http://www.fourseasontuning.com/?product=597
      Modified by FourSeasonTuning.com at 6:30 PM 11-12-2008
    13. Member GLgod's Avatar
      Aug 23rd, 2006
      North Wales, PA
      11-13-2008 08:56 AM #13
      VERY Informative... Thank you! [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. 11-13-2008 08:45 PM #14
      So can the rs4 clutch disc be used as a replacement in the stock set up as a upgrade?
    15. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      11-13-2008 09:04 PM #15
      No sorry. We do offer a 240mm sprung hub organic disc for the 02M from Clutchnet in the 1+ and stage 2 kits. The discs can also be sold separate.
    16. Awaiting Email Confirmation Veedub_junky's Avatar
      Aug 13th, 2005
      11-19-2008 10:02 PM #16
      Looks like I'll more than likely be placing an order with you guys tomorrow afternoon.
    17. 11-20-2008 01:02 AM #17
      what flywheel are you getting? if you get the 16 lbs. one let us know how it goes with it [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      11-20-2008 02:37 AM #18
      Here is a recent review from the MK4 Golf & Jetta Forum. It was using the 16.5 Steel Billet Flywheel (1.8T) and a stock 02M Sachs clutch kit.
      $694.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
      STAGE 1 KIT
      Quote, originally posted by TE7two »
      I just wanted give a review and feedback to this clutch kit in case anyone else is interested in buying.
      First off let me say James at FourSeasonTuning does a great job taking care of his customers, and certainly knows his stuff. I had many questions trying to figure out what decisions to make and he didn't lead me wrong!
      After installing the clutch and diagnosing a bad master cylinder in my case, I was able to take the car for my initial spin.
      Pedal feels exactly as it did stock, and as it should since the Sachs kit is an OEM replacement. Engagement with the lightweight flywheel however is very crisp and responsive. The car itself actually runs and idles MUCH better with the 16lb flywheel and believe it or not, the chatter is very, VERY minimal. Any chatter is only audible from the outside of the car, if you listen carefully. To give you an idea of how feint it is, I've heard Miatas with louder valve noise, and Injectors louder than what I suspect is the actual chatter.
      All in all, the price is right, the performance is there and a great upgrade for everyone. Still very daily driveable and i'm very glad I dealt with James.
      I would certainly recommend anyone to James! Thanks again
      Modified by FourSeasonTuning.com at 3:30 PM 2-6-2009
    19. Awaiting Email Confirmation Veedub_junky's Avatar
      Aug 13th, 2005
      11-20-2008 06:01 AM #19
      Quote, originally posted by SilverSurfer337 »
      That's definitely my plan. My buddy should have my car back together enough to tell me this afternoon if my slave is bad too (finishing replacing the master, which was bad). If it is, it's on like Donkey Kong!
    20. 11-28-2008 12:37 PM #20
      aahh! whats the deadline for the black friday sale?!
    21. 11-28-2008 12:49 PM #21
      ok cool im gonna see if i can get it a bit earlier instead of next week. who do i ask for when i call?
    22. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      11-28-2008 01:08 PM #22
      James
    23. 11-29-2008 02:44 PM #23
      Cant wait to install it!
      Thanks James [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    24. Member Rodrigo18's Avatar
      May 20th, 2007
      NOVA AREA
      MK4 24 GLI/ ON BAGS
      01-28-2009 10:38 PM #24
      IM sent
    25. Forum Sponsor FourSeasonTuning.com's Avatar
      Jan 12th, 2005
      Shipping WorldWide
      01-29-2009 12:50 AM #25
      Im Replied
      STAGE 1 KIT
      Modified by FourSeasonTuning.com at 3:25 PM 2-6-2009
