VWVortex.com - Jetta rear axle problems
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 41
    Thread: Jetta rear axle problems
    1. 11-03-2008 01:42 PM #1
      I have a Jetta 2004 GLI and have a disturbing problem with my rear axle!!! The inside tread on both my back tires are worn down to the cords. I had an alignment done and both my rear cambers are off by -1.50. Strange?!?!? This means that the rear axle is bent down towards the ground!
      The dealership has no advice. I haven't hit anything. The rear axle is one piece and not adjustable. I have heard of a kit that will essentially put shims in each side but it will not adjust it enough to take care of the problem.
      I am wondering if anyone else has this problem. If so, what can I do?
      Feb 8th, 2000
      Portland, ME
      1973 Porsche 911T, 2006 Ford F150, 2010 VW Jetta TDI Cup
      11-03-2008 01:43 PM #2
      Could jacking the car up from the rear torsion bar cause this problem?
    3. Senior Member urogolf's Avatar
      Dec 10th, 2000
      Somerset, MA
      13 Plug In Prius, 15 Venza
      11-03-2008 01:45 PM #3
      is your car lowerred at all?
      ................................................www.CCCIS.com
    4. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      A6 TDI Quattro wagon, A4 TDI Quattro racecar
      11-03-2008 01:45 PM #4
      That would go the opposite way, and give + camber.
      Thats a really odd problem though. I've not seem shim kits that could correct that much either.
      Maybe you could swap the rear beam with someone who wants to tuck stretched tires?
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    5. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      11-03-2008 01:47 PM #5
      Quote, originally posted by urogolf »
      its the 2004 GLI, its lowered from the factory.
      your car being lowered at all is going to cause the inside tires to wear unevenly. how worn is the rest of the tread ?
    6. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      2016 Sportwagen, 2010 Prius, 2005 Grand Caravan, 2002 Accord
      11-03-2008 01:47 PM #6
      Quote, originally posted by MikkiJayne »
      Lowering the car would not give camber at all, it's a torsion beam. There is no situation where lowering the car would result in positive camber with any suspension design.
    7. Member Benjamin.'s Avatar
      Nov 12th, 2001
      Hanover, PA
      11-03-2008 01:51 PM #7
      Quote, originally posted by ClockworkChad »
      You own a mk4 and still don't understand how a torsion beam works? There should be no increase in rear negative camber from lowering a mk1/2/3/4.
    8. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      11-03-2008 01:51 PM #8
      Wrong quote, but ^ x2 [IMG]http://*****************.com/smile/emthup.gif[/IMG] Lowering a torsion beam doesn't do that.
      Other than a bent beam it would have to be bent stub axles or collapsed bearings...
    9. 11-03-2008 01:56 PM #9
      The tires are pretty much brand new! In other words the tread is fine. I put them on at the beginning of summer and not more than 6,000 miles on them.
    10. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      11-03-2008 02:49 PM #10
      Quote, originally posted by mynameisphunk »
      It's amazing how much this comes up...
      Quote, originally posted by frandrs23 »
      Are they Z rated tires? Do you spend a lot of time cornering? What's the tread wear rating? Did you buy you car used, as maybe the beam is bent, but that's doubtful since the readings were the same for both sides. You drive a VW.... get used to eating tires. And it's amazing what proper rotation can do for tire life.
    11. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      11-03-2008 02:51 PM #11
      ive had 3 mkIII's and 1 MKIV.
      factory had normal tire wear, when i put coilovers on them the inside of the tires wear. if you look at a lowered car from the rear the wheels point in at the top. im not a mechanic nor do i have a mechanical engineering degree, but i dont think that that is
    12. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      11-03-2008 02:54 PM #12
      If you put a bone stock 1.8t GLS next to a lowered 1.8t GLS, both with LBs side by side and view from the rear you'll see the camber is the same. It looks different on lowered cars because the reference points (wheel/tire and fender) are closer to each other. It's a classic optical illusion. I'll try to find pictures to illustrate.
    13. Banned
      Jan 13th, 2008
      11-03-2008 02:59 PM #13
      Our rear beams do not exhibit camber even when lowered unless if the beams are bent, add shims or something is off center, or have crapped out stub axles (could be result of a bend, etc). Our rears cannot be aligned. The only thing it does when being lowered is sit closer to the front of the wheel well.
    14. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      11-03-2008 03:12 PM #14
      My car with Fat Fives 17x7:
      My car, same drop but now with 18x10 twists:
      Shots aren't the best, but as you can see, it *appears* that with the twists I have more camber, but alas, I do not.
    15. Senior Member urogolf's Avatar
      Dec 10th, 2000
      Somerset, MA
      11-03-2008 03:49 PM #15
      Lowerring the rear will generally toe the rear wheels slightly in with an extreme drops
      shims are required to correct this but are a pain to do (not difficult but labor intensive)
    16. Member TheMarkP's Avatar
      Jul 24th, 2002
      Long beach CA
      bagged turboed R32
      11-03-2008 04:08 PM #16
      Quote, originally posted by tmvw »
    17. Member mbg_euros's Avatar
      Feb 14th, 2008
      Enola, PA
      mk6 mk2
      11-03-2008 04:11 PM #17
      exactly, and when the wheel sits closer to the fender it makes the camber(if there is any) more visible that's it
      INNFAB
      Low Jambs Drop Shop
      RMiller
    18. Member TheMarkP's Avatar
      Jul 24th, 2002
      Long beach CA
      bagged turboed R32
      11-03-2008 04:13 PM #18
      all the rear beam does is make the wheel go forward and back...there shouldnt be camber if there is theres a prob...
      and if there is goin forward and back doesnt effect it.
    19. Senior Member urogolf's Avatar
      Dec 10th, 2000
      Somerset, MA
      11-03-2008 04:14 PM #19
      Quote, originally posted by KraCKeD-GTI »
      I didnt mention camber I mentionned toe.. the inward and outward alignment of the wheel measured at the ft of the wheel (NOT THE TOP)
    20. Member TheMarkP's Avatar
      Jul 24th, 2002
      Long beach CA
      bagged turboed R32
      11-03-2008 04:17 PM #20
      I didn't mention camber I mentioned toe.. the inward and outward alignment of the wheel measured at the ft of the wheel (NOT THE TOP)
      forward and back...that's all it does...hows it gonna effect toe if there's no pivot point up and down that's all the rear beam does which translates to forward and back that's it...
      forget caster forget camber forget toe none of these are affected by the height of the rear....that's why its a solid rear axle
      edit...ok caster yes but who cares right?
      Modified by KraCKeD-GTI at 10:19 AM 11-3-2008
    21. Senior Member urogolf's Avatar
      Dec 10th, 2000
      Somerset, MA
      11-03-2008 04:33 PM #21
      have personally aligned maybe 10 lowerred vws and have lowerred at least 30 with my own hands but what do i know
    22. 11-03-2008 05:45 PM #22
      So is everyone telling me that there is nothing I can do? Has anyone heard of this problem before? A friend works for an auto body shop and he said that he has heard of this problem before and says it may be a factory problem but there are no recalls or programs with VW.
      Help! What can I do?
    23. Moderator aar0n.'s Avatar
      May 7th, 2004
      PNW
      MK4 R32, F30 320i
      11-03-2008 05:56 PM #23
      Replace the rear beam with a new one
    24. Member
      Jul 6th, 2004
      Lakeville, MA
      11-03-2008 08:27 PM #24
      I'm glad to see there is so much misinformation in this thread. When you lower say a mk2 or mk3, whatever you choose with a solid rear beam it most definitely effects camber and toe. I have had my car on the alignment rack countless times with coilovers, cup kits, etc etc. and Just think about the geometry of it. The rear beam has slightly negative camber from the factory. The mounting surface for the rear stub axle is NOT mounted perfectly perpendicular to the beam. So, when you now rotate that beam off it's intended axis it brings the toe in, and also the camber. I know for a fact that before lowering my mk2 i was running in the area of -1.0 camber in the back. After dropping my mk2 in the rear i was running -2.1 on the left and -2.5 on the right. I did not touch anything except put a coilovers in it. And you know what, the lower you go and the more negative camber, the more the toe is off also. I am actually running shims now and am running -3.7 and -4.1 for camber in the rear.
    25. Member
      Jul 6th, 2004
      Lakeville, MA
      11-03-2008 08:35 PM #25
      you are 100% wrong.
      Edit: #1 there is no such thing as caster in the rear. #2 For anybody who thinks the rear beam is bent then thrust angle would be all messed up. Thrust angle ( how "straight" the rear axle is) should be no more then plus or minus .25. Which i bet if he had a printout from his car thurst angle would be well within spec. #3 Question for the OP, you say that your rear camber is off by -1.5 degrees. Do you mean that the camber in the rear is -1.5, or the camber is -1.5 degrees from spec? I ask this because i garauntee that spec for rear camber is somewhere in the ballpark of -.8 degrees with probably a positive or negative tolerance of .25 or .5 . I can find out exactly what it is tomorrow at work.
      Modified by 92g60gti at 8:49 PM 11-3-2008
