VWVortex.com - my R36 bigturbo build..
    Page 6 of 117 FirstFirst ... 23456789101656106 ... LastLast
    Results 126 to 150 of 2901
    Thread: my R36 bigturbo build..
    1. Member WolfzGangVR6's Avatar
      Jan 1st, 2002
      SFL
      99 B5 variant 1.8t /87 jetta coupe 16v(9a w/ 2.0Tfsi rods & pistons) / 90 jetta vrT (r.i.p. Nadia)
      12-03-2008 01:13 PM #126
      Quote, originally posted by VR6-GT42RS »
      the one to the left is for my street vr..i will build a new setup with earlyer spool up and 600hp.. i think i can live with out my gt42 setup on my streetcar now when i building the r36..
      i wouldn't mind riding a vespa colored PINK, wearing a pink helmet and green borat thong in the middle of winter, if it meant having a mk2 4WD R36 1000hp+ beast
      hey manifold injection worked for years and some of the biggest HP cars run it that way so why not!
      Quote Originally Posted by nothing-leaves-stock View Post
      if you owe a VW and DON'T have AAA gold...your an idiot haha
      ........... \_________
      ..... ,___/ /___l ___\\_____
      ...... l________l____/_____l
      .......\__( o )_______( o )__/ ........the coupe.....
    2. Member 04RSR32's Avatar
      Feb 20th, 2004
      Out in the Cut, KS
      04 GTI VR6
      12-03-2008 01:51 PM #127
      Sweet build. The only things that raise any questions are the Tranny and Haldex. Can both of these actually handle 1000+ hp? O2M's blow up with 500whp or so.. I don't think anyone has gotten far enough to see how far the haldex and other AWD bits are going to cope. I also remember seeing a few years back where the Haldex has a valve that will not allow you to exceed, i think around 750hp. Is this true?
      Either way, sick build. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    3. 12-03-2008 02:04 PM #128
      Thanks..i can only say one thing to you.. time will show.. i will strip alot of weight out of the car..upgrade to quaife dogbox,dss axles and lsd front and back..we will se what brakes..but low weight helps alot..and i think i will try to hold the torque a little down on this engine..
      R36T AWD 1100HP
      www.ktech.dk
    4. Member 04RSR32's Avatar
      Feb 20th, 2004
      Out in the Cut, KS
      04 GTI VR6
      12-03-2008 02:14 PM #129
      I'm sure it will be a trial and error thing. Best of luck to you!!! With 1000hp do you really need more than 7-800lb tq in a MK II??
    5. Member PhReE's Avatar
      Sep 16th, 2004
      Taylorsville, UT
      2004 Turbo VR6
      12-03-2008 02:18 PM #130
      I doubt he will be revving much past 8,000 rpm, so 1,000hp = 656.5 ft/lb @ 8,000 rpm. It might be nice to go honda styles and rev to like 10k with less tq and make big hp numbers... BUT with 3.6L LOL I dont think there is going to be any shortage of tq...
      -James
      04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
      >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
    6. 12-03-2008 03:09 PM #131
      i will not rev higher then 7600-7800rpm..i dont know what it will put down when im done with it..nobody have build a r36 with a gt45r yet..what i compared it to is a bmw 3,2(not m3) we build with a gt45r.. 1033hp/1009nm@1,7 bar, i dont know if i ever hit numbers close to that,but if i do i will not go higher..
      R36T AWD 1100HP
      www.ktech.dk
    7. 12-03-2008 03:20 PM #132
      video of the bmw im talking about http://www.youtube.com/watch?v=M_V8Q8jTGu0 enjoy
      R36T AWD 1100HP
      www.ktech.dk
    8. Member 04RSR32's Avatar
      Feb 20th, 2004
      Out in the Cut, KS
      04 GTI VR6
      12-03-2008 04:11 PM #133
      Quote, originally posted by VR6-GT42RS &raquo;
      Nice.. You pull 1000hp out of this thing you'll have everyone dropping 3.6L's in there ride!! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Whats the current highest HP VR out right now?
    9. 12-03-2008 04:21 PM #134
      Quote, originally posted by 04RSR32 &raquo;
      Rumor has it that there is a hybrid 3.2 / 2.8 24v outhere making over 1000whp and snapping rods using the same size turbo as this build
    10. 12-03-2008 04:49 PM #135
      1000WHP..or 1000hp..???big diffrence..there are alot of forced rods on the market..not everyone is good for high power.. i have pauter rods in my r36..pauters hold 200-250hp each cylinder..more then enough for my projekt..
      R36T AWD 1100HP
      www.ktech.dk
    11. 12-03-2008 04:56 PM #136
      Intel is that the numbers are whp b/c it came from a dyno.
      VR6-GT42RS - I have confidence you will make similar if not higher power on your setup [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member 04RSR32's Avatar
      Feb 20th, 2004
      Out in the Cut, KS
      04 GTI VR6
      12-03-2008 04:58 PM #137
      Quote, originally posted by pOrKcHoP bOy &raquo;
      Damn.... What do you mean by Hybrid? 2.8l 24v with 3.2 head, sleeved probably too?
      Modified by 04RSR32 at 8:59 PM 12-3-2008
    13. Member
      Sep 22nd, 2007
      Portland, OR
      83' BMW 633 24v MK2 Coupe Project
      12-03-2008 05:18 PM #138
      Torque bends rods.
    14. Member
      Sep 22nd, 2007
      Portland, OR
      12-03-2008 05:19 PM #139
      I think its just punched to 3.0 or 3.1
    15. Member PhReE's Avatar
      Sep 16th, 2004
      Taylorsville, UT
      2004 Turbo VR6
      12-03-2008 05:27 PM #140
      The motor you guys are talking of put down 1000bhp, not 1000whp. Still an amazing build tho !!
      -James
    16. 12-04-2008 11:23 AM #141
      034s motor you are talking about..?or another one..?
      R36T AWD 1100HP
      www.ktech.dk
    17. Member PhReE's Avatar
      Sep 16th, 2004
      Taylorsville, UT
      2004 Turbo VR6
      12-04-2008 12:58 PM #142
      Yeah. 034's
      -James
    18. 12-04-2008 01:00 PM #143
      this is to show that there is always something better out there [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Quote Originally Posted by Us2bA4dr View Post
      seriously, you are 21 years old, and a male, please stop typing like a 12 year old girl....
    19. Moderator DannyLo's Avatar
      Aug 2nd, 2006
      Not Vortex Approved
      12-04-2008 01:04 PM #144
      phree are you sure about that? we haven't seen real numbers yet, but i remember early in the thread like for the shakedown it had already put down 700awhp....i can't imagine 1000awhp being impossible
    20. 12-04-2008 02:19 PM #145
      no updates until after 15.december im going to the states for relaxing and to see pri show in orlando..
      Modified by VR6-GT42RS at 10:20 AM 12-4-2008
      R36T AWD 1100HP
      www.ktech.dk
    21. 12-04-2008 02:22 PM #146
      Remember this is not a build for highest numbers on a vr...
      R36T AWD 1100HP
      www.ktech.dk
    22. Senior Member TBT-Syncro's Avatar
      Apr 28th, 2001
      Vancouver
      92 VR-T syncro GTI, 2011 husaberg FS570, 2014 Aprilia Tuono V4 APRC
      12-04-2008 02:45 PM #147
      Quote, originally posted by L.I. Dan &raquo;
      so you think that it's easy to have an increase of 50% WHp? lol
      i know what it put down, and it is freaking impressive. I'd suggest picking up the new ET when it comes out to find out for yourself.
    23. Member
      Sep 22nd, 2007
      Portland, OR
      12-04-2008 03:12 PM #148
      Quote, originally posted by TBT-Syncro &raquo;
      What a tease... Thanks.
    24. Member obd2vr6's Avatar
      Jul 6th, 2006
      97 jetta 3.0 VRT
      12-09-2008 10:11 PM #149
      bump sick stuff crazy man
      need to watch this
      http://de.youtube.com/watch?v=Yo9reosjxk4
      97 3.0 VRT
      THE BEAST
    25. Moderator DannyLo's Avatar
      Aug 2nd, 2006
      Not Vortex Approved
      12-10-2008 01:42 PM #150
      i still can't find the ET in either Borders or B&N
      but i saw what oit pu down in the thread, i guess 1000whp in my head was me just really wanting to see a 24v making 1000 to all wheels since i love the engine so much ...becaus eyeah now looking back at my post you're right that is a little bit of an increment to make up for in power
