Page 4 of 81 FirstFirst 1 2 3 4 5 6 7 8 14 54 ... LastLast
Results 106 to 140 of 2827
Thread: my R36 bigturbo build..
  1. 12-01-2008 09:30 AM #106
    almost done with the intake manifold(the tb is a 80mm)..i do not have the injector adaptors yet..but it will come.. maybe i will paint this intake manifold black..
    Modified by VR6-GT42RS at 1:10 PM 12-1-2008
    Modified by VR6-GT42RS at 4:46 AM 12-2-2008
    R36T AWD 1100HP
    www.ktech.dk
  2. Member 29er's Avatar
    Feb 25th, 2007
    Not Fancy
    '12 JKU Rubicon
    12-01-2008 09:34 AM #107
    nahhh polish it, it looks great
  3. 12-01-2008 09:39 AM #108
    thanks maybe i will..as i see it, it can only look nice in black,grey or polish..
    R36T AWD 1100HP
    www.ktech.dk
  4. Member chrisbmx68's Avatar
    Aug 14th, 2003
    Collegeville PA
    2004 r32, 1991 318is
    12-01-2008 09:48 AM #109
    compared to full weight mk4's they are
  5. 12-01-2008 10:03 AM #110
    maybe not..but the rallye im talking about runs the same times or even faster then mk 2s 4motion with r32 turbo with big power.it runs 10,3 on toyos 888..2.1bar on turbonetic t72 and nitrous makes some kind of hp/torque on a vr.
    R36T AWD 1100HP
    www.ktech.dk
  6. 12-01-2008 11:49 AM #111
    Quote, originally posted by chrisbmx68 »
    FWD or AWD?
    My friend's Rallye VRT weighs the same as my Corrado VRT, both full road spec with full interiors, 17" road wheels, big brakes etc etc.... ~ 1300Kg.
    FWD MK4s also weigh ~ 1250 - 1330Kg
    AWD MK4s are ~ 1500Kg.
  7. Member WolfzGangVR6's Avatar
    Jan 1st, 2002
    SFL
    99 B5 variant 1.8t /87 jetta coupe 16v(surgery) / 90 jetta vrT (r.i.p. Nadia)
    12-01-2008 02:42 PM #112
    so are you going to tap ports for your injectors ontop of the custom manifold?
    i see you already welded up the factory FSI ports. this thing is gonna be sick!!! wish i had the money to play around with such expensive engine/turbo setups!!
    good luck as i don't think you'll need it
    Quote Originally Posted by nothing-leaves-stock View Post
    if you owe a VW and DON'T have AAA gold...your an idiot haha
    ........... \_________
    ..... ,___/ /___l ___\\_____
    ...... l________l____/_____l
    .......\__( o )_______( o )__/ ........the coupe.....
  8. 12-01-2008 02:45 PM #113
    Quote, originally posted by kevhayward »
    FWD or AWD?
    even more
    Daniels AWD 2.8L 24 MK4 weight 1680kh and my jetta Mk4 FWD weight 1450kg
    Damn el-leather seats and crap
  9. 12-01-2008 03:09 PM #114
    yes the injectors will be in the runners on the new manifold..like on a 12v vr6..i have not welded the oem fsi injector holes..what you see on the pics is only paper in the holes.. i will have mascined pieces ho fits in the fsi holes.. not weld it..
    R36T AWD 1100HP
    www.ktech.dk
  10. Member
    Sep 22nd, 2007
    Portland, OR
    83' BMW 633 24v MK2 Coupe Project
    12-01-2008 03:26 PM #115
    Quote, originally posted by VR6-GT42RS »
    That should do
  11. 12-01-2008 03:29 PM #116
    i dont think so..
    R36T AWD 1100HP
    www.ktech.dk
  12. Member WolfzGangVR6's Avatar
    Jan 1st, 2002
    SFL
    12-01-2008 07:21 PM #117
    i was on my crappy shop computer at work.. looked like some sloppy welds to me hahahhah. then i should have thought about the quality of the buil and realized it wasn't welded
    that's sick though. even cleaner then just welding it all shut. i can't wait to see this beast in running form. then you better get us some vids!
  13. 12-01-2008 08:16 PM #118
    I dont see how that wont be a source of headaches down the road... Thats alot of pressure against a "plug", if you dont have a plug that seals off the combustion chamber at the very tip you'll have a combustion chamber outside the actual combustion chamber. I would have to imagine theirs a better solution, not to mention all the advantages of direct injection your throwing out the window by reverting back the old ways. Why not go with the direct injection, no injectors? no way of controlling injectors? What are the 2.0FSI guys doing when they step into bigger snails? Its an awsome project, no doubt, not trying to knock it, just thoughts out loud...
  14. Member 05JettaGLXVR6's Avatar
    Jan 24th, 2006
    Annapolis, MD/Stockblocks, NJ
    12-01-2008 10:33 PM #119
    Cause direct injection has a limit and the power that he is running is WAYYYYY past that. The mk5 guys have some upgraded fuel pumps but thats only going to get them so far.
    Lugtronic
    Clutch Masters
    IE
    9.72@148 Stock Block
    9.46@155 JE pistons/IE rods update 9.36@153
  15. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    12-01-2008 10:43 PM #120
    Basically because there arent really parts easily available for tuning the direct injection. No standalone's I know of do it, and then there is the issue of the high pressure fuel pump flow rates, finding big enough injectors, etc.
    -James
    04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
    >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
  16. 12-02-2008 01:05 AM #121
    you can not find big enough injectors.. by the way..i will copy the fsi injectors in ss to block of the holes..thats not a problem at all ,no leaks..
    R36T AWD 1100HP
    www.ktech.dk
  17. 12-02-2008 11:20 AM #122
    New stuff from precision came to me today..
    R36T AWD 1100HP
    www.ktech.dk
  18. Member 16vtblackjetta's Avatar
    Jan 13th, 2007
    WV
    98 porcelain vr
    12-02-2008 12:19 PM #123
    nice can i have the one on the left for my VR?
  19. Moderator DannyLo's Avatar
    Aug 2nd, 2006
    Long Island, NY
    Not Vortex Approved
    12-02-2008 12:49 PM #124
    so simple, yet genious
  20. 12-02-2008 01:05 PM #125
    the one to the left is for my street vr..i will build a new setup with earlyer spool up and 600hp.. i think i can live with out my gt42 setup on my streetcar now when i building the r36..
    R36T AWD 1100HP
    www.ktech.dk
  21. Member WolfzGangVR6's Avatar
    Jan 1st, 2002
    SFL
    12-03-2008 12:13 PM #126
    i wouldn't mind riding a vespa colored PINK, wearing a pink helmet and green borat thong in the middle of winter, if it meant having a mk2 4WD R36 1000hp+ beast
    hey manifold injection worked for years and some of the biggest HP cars run it that way so why not!
  22. Member 04RSR32's Avatar
    Feb 19th, 2004
    Out in the Cut, KS
    04 GTI VR6
    12-03-2008 12:51 PM #127
    Sweet build. The only things that raise any questions are the Tranny and Haldex. Can both of these actually handle 1000+ hp? O2M's blow up with 500whp or so.. I don't think anyone has gotten far enough to see how far the haldex and other AWD bits are going to cope. I also remember seeing a few years back where the Haldex has a valve that will not allow you to exceed, i think around 750hp. Is this true?
    Either way, sick build.
  23. 12-03-2008 01:04 PM #128
    Thanks..i can only say one thing to you.. time will show.. i will strip alot of weight out of the car..upgrade to quaife dogbox,dss axles and lsd front and back..we will se what brakes..but low weight helps alot..and i think i will try to hold the torque a little down on this engine..
    R36T AWD 1100HP
    www.ktech.dk
  24. Member 04RSR32's Avatar
    Feb 19th, 2004
    Out in the Cut, KS
    04 GTI VR6
    12-03-2008 01:14 PM #129
    I'm sure it will be a trial and error thing. Best of luck to you!!! With 1000hp do you really need more than 7-800lb tq in a MK II??
  25. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    12-03-2008 01:18 PM #130
    I doubt he will be revving much past 8,000 rpm, so 1,000hp = 656.5 ft/lb @ 8,000 rpm. It might be nice to go honda styles and rev to like 10k with less tq and make big hp numbers... BUT with 3.6L LOL I dont think there is going to be any shortage of tq...
    -James
  26. 12-03-2008 02:09 PM #131
    i will not rev higher then 7600-7800rpm..i dont know what it will put down when im done with it..nobody have build a r36 with a gt45r yet..what i compared it to is a bmw 3,2(not m3) we build with a gt45r.. 1033hp/1009nm@1,7 bar, i dont know if i ever hit numbers close to that,but if i do i will not go higher..
    R36T AWD 1100HP
    www.ktech.dk
  27. 12-03-2008 02:20 PM #132
    video of the bmw im talking about http://www.youtube.com/watch?v=M_V8Q8jTGu0 enjoy
    R36T AWD 1100HP
    www.ktech.dk
  28. Member 04RSR32's Avatar
    Feb 19th, 2004
    Out in the Cut, KS
    04 GTI VR6
    12-03-2008 03:11 PM #133
    Nice.. You pull 1000hp out of this thing you'll have everyone dropping 3.6L's in there ride!!
    Whats the current highest HP VR out right now?
  29. 12-03-2008 03:21 PM #134
    Quote, originally posted by 04RSR32 »
    Rumor has it that there is a hybrid 3.2 / 2.8 24v outhere making over 1000whp and snapping rods using the same size turbo as this build
  30. 12-03-2008 03:49 PM #135
    1000WHP..or 1000hp..???big diffrence..there are alot of forced rods on the market..not everyone is good for high power.. i have pauter rods in my r36..pauters hold 200-250hp each cylinder..more then enough for my projekt..
    R36T AWD 1100HP
    www.ktech.dk
  31. 12-03-2008 03:56 PM #136
    Intel is that the numbers are whp b/c it came from a dyno.
    VR6-GT42RS - I have confidence you will make similar if not higher power on your setup
  32. Member 04RSR32's Avatar
    Feb 19th, 2004
    Out in the Cut, KS
    04 GTI VR6
    12-03-2008 03:58 PM #137
    Quote, originally posted by pOrKcHoP bOy »
    Damn.... What do you mean by Hybrid? 2.8l 24v with 3.2 head, sleeved probably too?
    Modified by 04RSR32 at 8:59 PM 12-3-2008
  33. Member
    Sep 22nd, 2007
    Portland, OR
    12-03-2008 04:18 PM #138
    Torque bends rods.
  34. Member
    Sep 22nd, 2007
    Portland, OR
    12-03-2008 04:19 PM #139
    I think its just punched to 3.0 or 3.1
  35. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    12-03-2008 04:27 PM #140
    The motor you guys are talking of put down 1000bhp, not 1000whp. Still an amazing build tho !!
    -James
